Ampsplus 18350 NMC 1150mAh (Black) 2020
Official specifications:
Battery Size: 18.30mm x 35.00mm
Nominal Voltage: 3.70V
Nominal Capacity: 1200mAh
Min rated Capacity: 1150mAh
Charging Method: CC/CV 4.20V
Discharge Voltage: 2.00V (Average Cut Off)
Charging Current CC: 500mA
Rapid Charging Current: 1000mA max.
Continuous Discharge Current: 10A
Max. Short Discharge Current: 15A
Weight: 25 gr . max
Colour: Black , Red , Silver
Version: Flat Top
Protection Circuit Board / PCB: No / Unprotected
Type: Rechargeable , NMC , IMR , INR , High Drain
A high current and high capacity 18350 battery from Ampsplus.
The two cell match nicely and can deliver about 10A before they have problems.
Conclusion
This cell is from the fairly new generation of 18350 cells that can deliver a lot of current and have lot of capacity (for the size).
It is is good battery.
Notes and links
The batteries was supplied by Ampsplus for review.
Graphical comparison to other LiIon batteries
Table with all tested LiIon batteries
