Sofirn Aliexpress Store Sales & Codes update! IF22A Sliver/SP10V3/SP40A New release
304 posts / 0 new
how crazy is this
Last seen: 47 min 37 sec ago
Tried code NHFJSAECM9BT for the silver IF22A and it did not work for me. Would like to get one. Thanks
Jackie
Last seen: 2 hours 27 sec ago
IF22A updated new code :Q7OLHRALGIKZ
Nooner
Last seen: 3 hours 28 min ago
Jackie wrote:
Nooner wrote:
The SP40A is very interesting. Will Sofirn sell the TIR optic alone?
yes, we could update the link of this TIR OPTICS on sofirn.aliexpress.com after we back from the national holidaysmile
That’s great.
Thank you Jackie!
I’ll definitely order some when its listed (plus other stuff I’ve been meaning to get).
Jackie
Kos70
Last seen: 6 hours 22 min ago
Interestingly, the SP-40A is not equipped with a head mount, or is it a typo?
Sillen
Sillen's picture
Last seen: 25 min 47 sec ago
Hi Jackie, has the Sofirn SF11 4x AA been discontinued?
Jackie
it is a typo, come with headband
Jackie
yes, it has been discontinued
darosk
darosk's picture
Last seen: 14 min 10 sec ago
Hi Jackie, will there be any new updated version of Sofirn 4xAA light?
I know it’s not as popular as other lights, but I like the shape of it
My Lights (Updated: June 20, 2021)
Jackie
darosk wrote:
Hi Jackie, will there be any new updated version of Sofirn 4xAA light? I know it's not as popular as other lights, but I like the shape of it
seems we do not have a plan till 2022 of a 4*AA lightsurprised
Jackie
Q8 PRO discount price now $69, could use a code as well
https://www.aliexpress.com/item/1005002801966537.html?spm=5261.ProductMa...
Sillen
Sillen's picture
So none at all left in stock anywhere? I wanted to get some for Christmas presents.
It would be nice to get some notice before products end productions so I can hoard some Big Smile
Fescron
Last seen: 8 hours 20 min ago
Any plans for the IF22A to come with Anduril 2?
Jackie
It sounds not badcool
Nooner
Hey Jackie.
Is it possible for me to buy the SP40A tir optic alone?
Earlier in this thread you said you would make a listing on aliexpress.
Thank you.
Jackie
Nooner wrote:
Hey Jackie. Is it possible for me to buy the SP40A tir optic alone? Earlier in this thread you said you would make a listing on aliexpress. Thank you.
Hi, i have updated a link, photos will update soon:
https://www.aliexpress.com/item/1005003403886037.html?spm=5261.ProductMa...
Jackie
SC21 20% code :3IXIOYXLLR8R with more tint for choice now 2700k.4000k,5000k
Kos70
8 degrees ?! A toss instead of a spill, or a typo again?
d_t_a
Last seen: 22 hours 32 min ago
Jackie, would you happen to have a tool to help in unscrewing the SP40 bezel?
I have removed the bezel from an earlier SP40 (XPL-HD) before (it got a few scratches).
but when I tried to remove a newer SP40 (LH351D), I had trouble removing it (I do not want to scratch the bezel..)
Kos70
d_t_a wrote:
Jackie, would you happen to have a tool to help in unscrewing the SP40 bezel? I have removed the bezel from an earlier SP40 (XPL-HD) before (it got a few scratches). but when I tried to remove a newer SP40 (LH351D), I had trouble removing it (I do not want to scratch the bezel..)
Try to turn on Turbo for a couple of minutes, and unscrew it by resting on slippers or a rubber mat ... I did just that, and it was with SP40 (LH351D)
mattlward
mattlward's picture
Last seen: 12 hours 47 min ago
Can you tell me about the PWM on this SP10V3.0? I had one of the older AA/14500 lights and the PWM was so bad that I gave it away, gave me a headache.
EDC rotation:
FW1A, LH351D 4000k (second favorite)
FW3A, LH351D 3500k
FW3A, SST20 FD2 4000k
FW3A, Nichia 4000k sw40 r9080 (favorite light!)
FW3A, Cree XP-L Hi 5A3
Emisar D4V2, SST20 4000k
S2+, XM-L2 T6 4C
Jackie
will check with our engineer on Monday
Jackie
get a reply now : about 20khz
Serlite
Last seen: 9 hours 13 min ago
Pressing it into the bottom of a mouse pad or a rubber jar opener has worked well in my experience.
I started off using snap-ring pliers, and also scratched the bezel. Then I found out friction is often enough, and it made modding a lot easier.
Jackie
15% code work for SC21 :
3IXIOYXLLR8R
Jackie
max
max's picture
Last seen: 1 hour 12 min ago
 max
Jackie
thanks for support smile
Jackie
IF22/IF22A/TS21/SC31T/LT1/SC21/SP36PRO/Q8PRO/FC12/DL10R/SD05/HD20/SD01PRO/HS05/WK30/S11
Code for all models above : L9BWVAC5IN0T
Majoroverkill
Majoroverkill's picture
Last seen: 2 hours 5 min ago
The old code did mot work. Do you have a new code for the New SP10V3? Thank you Smile
Doug S.
