Hello,I’m trying to get a couple bulbs for my old tacstar flashlight but can’t seem to find any info. Can you please help? this light uses 2 cr123 batteries. Thanks a lot, what about bob
I wasnt expecting photos in color with that question;)
That is a streamlight scorpion bulb
Thanks a lot AlexGT
Does the glass bulb easily remove from the white part? If so you could probably just use the streamlight bulb.
Does the whole module look like this? https://www.tactical-store.com/ts-fq-ws-1081377.html
It looks like that is listed as being for your light. If the module looks like that, it might fit a p60 dropin with little to no work. That would open up a whole host of incandescent and led replacements.
I hope that helps.
Thanks Superstocker, the glass bulb just pulls out of the white part. It doesn’t look like the p60. It looks like the streamlight bulb that AlexGT said it is. I’ve got one of those on the way from amazon. WAB
Ok, good. I hope it works out well for you.
The streamlight 85914 is the correct bulb. Thank you much! WAB
