I was lucky enough to see C-X's post and snag this neat little flashlight before anyone else had a chance. I have been researching AAA and AA form flashlights for several weeks and this came along at just the right time. Pic below is the flashlight as it looked when I received it:
Well the first thing a flashaholic wants to do on receiving a new light is to pop in a battery and test her out. Wayne did an over the top job of making sure this thing got to me in one piece. I kid you not, it took me 10 minutes to unpack everything just to get to the light and batteries. This thing sure is bright, a real pocket rocket! I'll get to more about performance in a minute, but first, a few additional photos.
Not that big a fan of GITD, so after I disassembled the light to inspect, I changed all the O-Rings back to the black ones provided with the light:
SE-1 in front of (L-R) Fenix L2D, Balder BD-2, N-Light ST50, Yezl Z1
Size comparison with big brother:
And some pictures of all the flashy bits:
Product Details
The light came with the original Balder plastic packing case, user manual, spare o-rings, tail cap boot, metal clip (removed) and spare lens. Wayne was also nice enough to supply two protected Ultrafire 14500 batteries to get me started. As luck would have it, my LightHound order for two AW IMR unprotected 14500s arrive the same day.
First impression is this is one solid little light. Fits well in the hand, easy to grip and hold. Finish is nice, but a little worn on the tailcap knurling. While it's nice, quality is not quite up to that of the BD-2, but this is Balder's budget entry and it does cost only 1/2 as much. Interesting that the SE-1 does not share styling cues with the BD-1, -2 or -4, which all look somewhat like different sized versions of each other.
The SE-1 uses a forward clicky, which is a surprise and opposite of the BD-2's reverse clicky. Nevertheless, it is solid and functional and does have mode memory and thankfully no disco modes. Switch protrudes, so no tailstand.
H-M-L are well spaced. I have no idea on lumens, but it is comparable to the BD-2 on high although it is more floody, so it doesn't appear as bright. OP reflector is pretty deep so it has some throw, but it's more for close up work anyway. Beam is very smooth, with minimal rings, no artifacts and crisp white tint which is my preference. Threads on the head and pill are smooth, but the tailcap threads are gritty and rough, nothing a little oil can't fix. I was told to expect 17-18 minutes run time on high, 55-60 minutes on medium and 6+ hours on low. Honestly, other than wow, medium and low are more than adequate for everyday use.
As mentioned above, Wayne installed a new driver and heatsink. The pill is noticeably heavy. He also installed a copper spacer ring to the bottom to prevent the battery from crushing the chips on the pill bottom. This seemed to have done the trick - the light starts getting warm within a minute of turning on in high and pretty hot (but not uncomfortable) within 3-4 minutes. Interesting note on this: Using the UF protected batteries, the light gets much hotter, much faster. The AW IM unprotected cells are Lithium-Manganese and they seem to generate less heat. The copper spacer also means the head cannot screw all the way down, so I'll be keeping this one away from water, and the small gap lets some aluminum show through the black - adds a nice accent to my eye and helps it look a little more like it's brothers in the BD series.
I am thrilled with this light. My first EDC, it's a good size for jacket or jeans pocket, although too big for dress pants. That's ok by me, as I have new AAA and AA lights on the way to handle the fancy pants. Great deal too: A new SE-1 runs about $25. C-X shipped it to me with all mods and two batteries for $39. It definitely has potent wow factor, everyone (including me) is amazed at the amount of light coming out of this small package. Thanks to Chicago-X for making this great little light available to me.
Thanks for reading,
Dave
