Ultrafire UF-T70 Triple XM-L
236 posts / 0 new
Hikelite
Last seen: 10 months 3 days ago
There's a new small Triple XM-L form factor on the market.
http://www.ebay.com.au/itm/Ultrafire-UF-T70-3x-Cree-XM-L-T6-LED-18650-Fl...
Size: Length 17.5cm, Diameter 6.5cm
Weight : 830g
http://ultrafire.net/showproducts.asp?id=201
Edited by: Hikelite on 01/24/2012 - 09:36
JohnnyMac
JohnnyMac's picture
Last seen: 2 days 23 hours ago
Bun of a sitch!  And I just bought my DRY!!  This body is SO much nicer than the DRY with the knurling and finning details. If the driver is up to snuff this would be one hell of a light.  I wonder what it will end up selling for?  Could always put a DRY driver in it and have performance AND looks. Cool
I'm going to have to start saving up now to get one by summer time.  I really like the looks of this over the DRY/Brynite.  With the larger head it may throw better too if the individual reflectors are wider.
JohnnyMac
JohnnyMac's picture
HKE is already selling it for $99.  Looks like the DRY is the budget model in this format.  Can't wait for someone to purchase the T70 and give it a full review.
Hikelite
The design is definitely a nice one.
HKE says Max 2500 Lumens (factory rated)
Ultrafire says 2400 Lumens (Manufacturer rated) ...
This photo says 1800 lumens (1800流明)
The DRY is the budget model in this segment because it's the easiest to manufacture, the machining time is short, so the price is accordingly, fortunately.
E1320
E1320's picture
Last seen: 11 months 7 hours ago
That light is awesome. I just ordered a couple extra Dry drivers from Ric because I can see this one in my near future plus they are the best triple x driver I have found and only 5 bucks each.
I am already visualizing the duct tape over your mouth.
xed888
Last seen: 11 months 19 hours ago
Seems like a 350m throw as well. nice...
HKeq says H-L-Strobe but Ultrafire.et says H M L. I hope its H M L!!!
yavi
Last seen: 11 months 1 day ago
Looks great, let´s see how good is the heat management, I will keep an eye on it.
Hikelite
This one is supposed to be 830 grams, quite much more heavier than the DRY, 350grams. It will be very interesting to know how is it dealing with the heat, but considering the 2.6A, probably it will be fine.
xed888
http://www.tv-japan.com.hk/UltraFire.htm
The translated website says that the T70 is 532g and has 65mm head.
Hikelite
That must be it. 830g seems too much.
They say 2000 lumens. Appear that everybody specs lumens differently for this flashlight.
how2
Last seen: 1 month 1 week ago
Here is the descripition on ultrafire shop
Description
  • UltraFire UF-T70
  • CREE T6 XML  White LED x 3
  • 2400 Lumens (Manufacturer rated)
  • Emitter Color: White
  • Smooth Reflector
  • Tailcap Switch
  • Model: High , Mid, Low
  • 3 mode Change
  • Lens:Coated Glass Lens
  • Type III hard-anodized finish
  • Battery Configurations:UltraFire  18650 x 3
  • 177 mm(L) x 65mm (Diameter) Head
Mode Lock
Battery cap fully close - mode lock
Battery cap not fully close - mode change
Price  $ 110.00
xed888
If it has the same beam characteristics as the Jetbeam RRT3 XML, i will be buying one. it has similar head diameter: 65mm vs 67mm (UF:JB).
gen1.3_
gen1.3_'s picture
Last seen: 8 years 10 months ago
Wow..very nice! Price is not too bad if it turns out to be a good one.
dthrckt
dthrckt's picture
Last seen: 1 week 12 hours ago
Mode lock sounds pretty cool, but I'm guessing that would be lost of stock driver was swapped for dry driver?
Having toyed with my DRY for a few days, I no longer think the turbo is just for wow and wasting batteries - it is actually quite useful, despite the limited duration.
I like the look of this light, but would have preferred they just round out the body of the T60 for the additional cell Smile
motodeficient
Last seen: 6 years 2 months ago
Hmm that is nice, hopefully the price will come down though.
xed888
Anyone order this yet? Big Smile
sweeps
Last seen: 5 years 8 months ago
for about a week now
xed888
great! do keep us updated!
Richie086
Richie086's picture
Last seen: 13 hours 19 min ago
Looks like Ric has the best price so far.
http://www.cnqualitygoods.com/goods.php?id=1355
Richie
keltex78
keltex78's picture
$82 ($10 off) if you purchase 5+. Maybe someone should try to setup a GB? I really like the look of this light but it's more than I can justify spending right now so I wouldn't be interested; maybe others would though once a couple of members have posted their impressions...
Keepin’ the “B” in BLF
Don wrote:
It sounds like the XM LEDs won’t really be suitable for flashlight use. Pity…
dthrckt
dthrckt's picture
VFMaddict
Last seen: 1 year 11 months ago
I've never been a fan of lights using >two lith. cells, so I've never been into the DRY.   But there's something about this light that truly tempts me.  The pics at Ric's suggest that this could have high build quality, rather like the MCU-C88.   I think that I'll be putting some funds aside just in case I can't resist the temptation after its been reviewed.
"You are making progress if each mistake you make is a new one."
Remember - Most great discoveries start with maki
Richie086
Richie086's picture
I'm very interested to see how this new Ultrafire UF-T70 stacks up against the DRY 3xCREE XM-L T6  and TrustFire TR-J12.  It would also be nice if the Redilast 3100mAh  protected cells would work.
Richie
sweeps
i also have tk70 and 4 random triple cee xml s so i feel i am a reasonable judge . i would say its a winner   build quality amazing  i never use them for long so not sure how hot it gets but for a living i am a chimney sweep so i feel i know much more about spill and contrast between hot spot than many users but lack in depth knwledge on testing output , and yes i have terrible grammer but just back from pub so its a very bright whits not blue but compared to say tk35 its very white  , in  fact due to deeper reflectors its very simular to the tk35 beam pattern , i have the sky ray 5 xml  and i would say this is now my best light in fact i will sell my tk70 with batts if any one wants it pretty cheap with good batts , oh one negative the battery  unit has springs both ends i guess for flat top cells one of them bust off when i tried to remove a battery but still works with my  cells , in the past  people have complained about my posts i dont mind doing some pics and answering questions but please ignore this poste rather than  replying with some  over critical response
sweeps
sweeps
harry25175
harry25175's picture
Last seen: 8 years 5 months ago
Ordered !
2100
Last seen: 3 years 2 months ago
harry25175 wrote:
Ordered !
You need to spend 25 bucks on a light meter and supply us with information on all your lights! Sealed
Toppel
Last seen: 3 years 8 months ago
Will the Dry Drivers with Step-Down fit in this light?
Chicago X
Chicago X's picture
Last seen: 8 years 6 months ago
The DRY drivers are on the small size, among 3xT6 drivers.
Without seeing the light, I would guess a very firm 'probably'
http://wardogsmakingithome.org/index.html
War Dogs, Making it Home - Rescue Dogs for Returning Vets
xed888
Go on then, post some pics! Smile Also could describe how the modes car changed on the torch?
Edit: Tried ordering one but it costs extra $20 to ship to uk! Sigh, group buy anyone?
