For an emergency use or little use which type of battery should i use?
42 posts / 0 new
mortuus
mortuus's picture
Last seen: 11 hours 33 min ago
i would say double AA or even AAA would be the best for emergency situations. plenty enough lights coming from such flashlights.
...where Frugal meets with Flashlight!
              つ ◕_◕ ༽つ
xxo
Last seen: 2 hours 30 min ago
Yup, AA’s and AAA’s are easy to scrounge out of things like clocks, remotes and toys and are easy to find on the road for a light kept in a vehicle. Plus energizer ultimate lithiums are just as good if not better than CR123’s for long term storage and performance in extreme high and low temps.
wle
wle's picture
Last seen: 11 hours 22 min ago
alkaline and carbon-zinc -> leak
energizer ultimate lithiums -> i have had odd results with them, mostly they do not seem to have a high current drain capability they will shut down at random no, i was not using during extreme heat or cold
    Daniel Behrman, "The Man Who Loved Bicycles".
-Greg Lemond.
xxo
The L91 is rated for 2.5 Amp continuous load and a 4 Amp pulse load which is lower than typical Li-ion and NiMH cells, but higher than what a CR123A cell is rated for – 1.5A continuous/3.5A pulse.
wle
wle's picture
what i have seen is, they test ok on a battery tester, meaning that they can deliver 100ma ok but in a camera or something they don;t work
maybe what is going on is, my particular cell was almost dead but for some reason still indicated a high open circuit voltage, as well as delivering 100mA ok, but the max current has fallen off, and the tester just can;t test for that…
-Greg Lemond.
xxo
Sounds like you were using dead batteries. Ultimate lithiums should have open circuit Voltages of 1.79-1.83V fresh out of the package and when they get below 1.70V they are dead. If you are using a Voltage based battery tester intended for alkalines, they will test “good” long after they are dead.
snakebite
snakebite's picture
Last seen: 3 weeks 2 days ago
wonder if they passivate like cr types?
you just run them a bit and they recover.
wle
wle's picture
oh!
good to know
they don;t exactly publish that info!!
wle
-Greg Lemond.
snakebite
snakebite's picture
as for 9v lights make one from a dead 9v.
tear it apart for the connector.
2 white leds and a 100 ohm 1/8w resistor makes a decent light.
can use 1/4 &1/2w too but i ordered 1/8w since i build these 100 at a time for preppers.
2 leds in series with the resistor.
clear 5 minute epoxy,hot glue,ect to protect it.
extra credit for using yuji or other high cri leds.
no switch just snap it on.
Oli
Last seen: 6 hours 1 min ago
With outdoor temperature ranges of 0 to 100F, -18 to 38C, I keep multiple flashlights with 18650 battery’s in all vehicles. Charge typically to 4.1V, never in the vehicle. I also keep battery operated tools in the same conditions. If I am slightly shortening the battery life, then so be it.
FollowspotDude
Last seen: 12 months 1 day ago
In all of my cars you’ll find 9v PALights. Their continuous glow makes them easy to find and is a reminder that the battery is still functional. I’ve never had a problem with storing 9 volt batteries in the car, even in Florida. And as others have mentioned, in an emergency 9 volt batteries are plentiful when everything else has been exhausted.
