CRX Underground Mechanical Mods
20 posts / 0 new
CRX
CRX's picture
I quite liked the look of this one from Ali-Ex. Underground MCM mechanical mod.
This is a stackable 21700/ 18560 mechanical mod, comes in various coloured coatings and the extension stacking piece is just a few dollars more so I bought the two as I saw potential in both pieces.
These are well made solid chunks of brass for the price and come with copper button derlin cell holders, silver plated ultem switch and a clip sealing plastic foam lined box.
I did order the plain brass version but it was out of stock so accepted the black coated instead.
Main unit with extension piece:
The painted coatings are not very durable and scratch fairly easily. I used acetone to soften it then wire wool to take most of the coating off from the outer shells leaving some black in the machined grooves.
So what can I do with these things?... Smile
Main MCM Underground mechanical mod build:
CRX Underground MCM Triple Nichia 219C 5000K - Lxl TA Driver - 18650 - Piston Drive E-Tail Sw - 2430lm.CRX Underground MCM Triple Nichia 219C 5000K - Lxl TA Driver - 18650 - Piston Drive E-Tail Sw - 2430lm.Triple Nichia 219C 5000K emitters
LED4P Copper DTP MCPCB
Carclo 10508 optic
22mm x 1mm ARC glass
Hand made GITD dual colour glow gasket
Lexel 22mm E-switch driver
Anduril firmware
Copper pill
Copper lined body
Copper tail switch internals
Piston Drive electronic tritium tail switch
Max - 2430lm
Throw - 122m
Length - 90mm
Width - 28/ 31mm
Weight - 260g (With 18650 cell)
CRX Underground MCM Triple Nichia 219C runtimes:
This was a difficult build due to the size restriction of 90mm but I managed to make it a piston drive, the electronic switch is mounted on the driver board so the cell is the piston to operate it.
Copper lined throughout for mass and heat distribution.
Part two, extension piece build:
Again I stripped off the black coating and cut off the protruding front thread to use as the screwed bezel for the piston drive light.
I took some build pictures with this part.
The lights are built pretty much the same way with copper tube throughout.
Pill:
22mm x 1mm copper tube pill housing, brass centre pill with driver retaining ring, 22mm x 1mm glass, 22mm brass bezel.
Convoy 8x7135 driver with brass button, Nichia 219C 4000K 90CRI emitter.
Body liner section:
22mm copper tube, felt lined with brass insert for o-ring placements.
This extra copper helps transfer the heat from the pill all the way down the body of the light and provides good fitment for the 18350 cell.
Tail switch unit:
I potted the reverse clicky tail switch into some 22mm copper tube and soldered to the brass 510 hybrid threaded piece so we can have a screwed tail cap.
This unit butts down onto the body section compressing the 22mm o-ring on the brass tube insert.
The brass 510 threaded piece has some nice shapes cut into it so I filled them with a thermochromic/ GITD powder mix.
At cold temperature the inserts look black but with some heat and applied light glows bright green.
In order to have something to grip when tightening the tailcap down I installed four brass pillars around the switch, filling the already present vent holes.
These are 2mm hollow brass tubes filled with aqua blue glow powder.
Parts:
Complete:
CRX Underground MCM Nichia 219C 90CRI - C-MK 3A - 18350 - Rv Clicky Tail Sw - 600lm.CRX Underground MCM Nichia 219C 90CRI - C-MK 3A - 18350 - Rv Clicky Tail Sw - 600lm.Nichia 219C 4000K 90CRI emitter
Copper DTP MCPCB
22mm x 13mm OP reflector
22mm x 1.5mm ARC glass
Hand made GITD glow gasket
Convoy 8x7135 3A driver
Biscotti firmware
Copper pill
Copper lined body
Copper tail switch housing
Thermochromic Black/ GITD tail
Reverse clicky tail switch
Max - 600lm
Throw - 128m
Length - 75mm
Width - 28/ 31mm
Weight - 232g (With18350 cell)
CRX Underground MCM Nichia 219C 90CRI runtimes:
CRX MCM Undeground Mods
Other Mechanical vaping mods I have made into flashlights:
CRX RV Titan I Triple Nichia 219C – Anduril – 18650 – E-Tail Sw – 2200lm.
CRX RV Titan I Triple Nichia 219C - Anduril - 18650 - E-Tail Sw - 2200lm
CRX RV HammerHand Nichia 219C 4000K - LD-A4 - 18500 - Halo Tail Sw - 740lm.
CRX RV Titan II LH351D 5000K - LD-A4 - 18500 - Halo Tail Sw - 1200lm.
Edited by: CRX on 10/21/2020 - 10:16
xevious
xevious's picture
Last seen: 1 hour 55 min ago
Really cool looking, CRX!
What’s the advantage in going with a piston drive?
Btw, link you provided fails on AliExpress: https://www.aliexpress.com/item/33053814317.html?spm=a2g0s.9042311.0.0.7...
Specialsteve
Specialsteve's picture
Last seen: 1 week 2 hours ago
From another World….thanks for Showing Shocked Thumbs Up
Your Skill has no Limit Crazy
WillyD
Thank you for posting this more detailed thread on these builds. I absolutely love both of them, and I really want to try that GITD powder now.
pinkpanda3310
pinkpanda3310's picture
Last seen: 2 days 12 hours ago
Awesome conversions CRX. Your attention to detail is always impressive, I really like the look of that glow tail switch.
Without the black trim it would look a lot like your other builds made with brass nuts.
G0OSE
G0OSE's picture
Last seen: 4 hours 12 min ago
So we going into business now then lol Silly , I find the hosts you do the mods – like wheeler dealers! (I presume you’ve watched that, I love it lol)
Just kidding lol, mate it’s awesome – a true chunky munkey!
You always inspire, and it’s true seeing your stuff has made me pull my finger out and actually start doing stuff – bending your ear along the way obviously!
So glad people like you, PP and all the other wonderful modders keep this place alive – it would just be lights for sale and off topic chatter otherwise.
Well done. Thumbs Up Beer
Marc E
Last seen: 1 week 2 days ago
That MCM logoed light looks amazing, in fact it might be the best looking light i know of. Nice!
CNCman
CNCman's picture
Last seen: 18 hours 11 min ago
Beautifully designed and crafted lights. Thumbs Up
MRsDNF
MRsDNF's picture
Last seen: 1 month 1 week ago
Simply wow. Nice work CRX. Beer
Rat_Racer
Rat_Racer's picture
Nice work, as usual sir.
And to think, I’ve been tossing my dead vape mods all this time. The Pico is my favorite travel vape, and use the 21700 versions when out and about.
CRX
CRX's picture
Btw, link you provided fails on https://www.aliexpress.com/item/33053814317.html?spm=a2g0s.9042311.0.0.3...
Link should be fixed.
I did intend to go the usual route of an e-switch in the tail with a signal tube but was too limited in length, I had to bore out the end cap to take some of the 18650 cell so it was easier just to mount the switch on the driver.
Beer
Thumbs Up
Yes I like the contrasting black, breaks it up a bit Thumbs Up
Yeah you’re annoying but have some good ideas too so I tolerate Big Smile
You’re right, this place is getting like social media sites with all the nothing to do with flashlight junk threads.
That’s partly why I post my stuff too, to show what you can do with some simple hand tools and perseverance.
I used to watch wheeler dealers until Edd left. Mike does my nut in Big Smile
Yes, I like it too, something a little different Thumbs Up
Beer
Thumbs Up
Send your broken vape mods to me Big Smile
MtnDon
MtnDon's picture
Last seen: 36 min 17 sec ago
Way cool! Great stuff. Looks like there is no end to your imagination and workmanship. Thumbs Up
CRX
CRX's picture
Same with you Don Wink Thumbs Up
NeutralFan
NeutralFan's picture
Last seen: 2 days 15 hours ago
Awesome job CRX – that’s a cool looking flashlight! Beer
I’d rather use my flashlight around the house than turn on the lights.
CRX
CRX's picture
Smile Thumbs Up
grin
Last seen: 2 days 10 hours ago
That switch!! do you need a kidney?
CRX
CRX's picture
No I’ve got some on order from alibaba LOL
Lane32x
Last seen: 3 months 4 weeks ago
So…..will you be offering these any time soon? Love the look (and the ability to stack them). I’d be interested.
Also, AliExpress link appears to still be broken.
CRX
CRX's picture
What!? I just fixed that. LOL
Maybe you need to be logged in for it to work.
I think the true price of making these to sell would scare people here.
Parts alone are around £60 and 10hrs labour for the triple. About £40 & 8hrs work for the single emitter light.
Hit me with a number if you like and I’ll tell you higher or lower Big Smile
djmcconn
djmcconn's picture
Last seen: 15 hours 43 min ago
Beautiful as always
