Test/review of Hohm 18650 Work2 2547mAh (Black-white)
4 posts / 0 new
HKJ
HKJ's picture
Last seen: 17 hours 46 min ago
DSC_2413
Official specifications:
  • Capacity: 2547mAh
  • Max Charge Rate: 3.82A
  • Max Charge Voltage: 4.2V
  • Continuous Discharge Rate: 25.3A
  • Max 80oC | 3.2V cut-off: 35.8A
  • Pulse | Peak6: 42.4A
  • Cycle Life Retention: 500 Cycles (69%), 1000 (58%)
  • Chemistry Type: QSP Li-NMC
Hohm%2018650%20Work2%202547mAh%20(Black-white)-info
DSC_2405
DSC_2406
DSC_2407
DSC_2408
DSC_2409
DSC_2410 DSC_2412
DSC_2414 DSC_2415
DSC_2416
DSC_2417
DSC_2418
Hohm%2018650%20Work2%202547mAh%20(Black-white)-Capacity
The specifications for the battery sound fine and the two cells match very nicely in the discharge curve, but a internal fuse blows at 15A discharge current
Hohm%2018650%20Work2%202547mAh%20%28Black-white%29-Temp-10.0
Hohm%2018650%20Work2%202547mAh%20%28Black-white%29-Temp-15.0
The battery is not hot on the outside when the fuse blows.
Hohm%2018650%20Work2%202547mAh%20(Black-white)-CapacityTimeHours
Hohm%2018650%20Work2%202547mAh%20(Black-white)-Energy
Conclusion
The batteries looks fine at low current (That is 10A), but something is wrong with the current rating or the batteries. The overload fuse burns out way below rating.
Notes and links
The batteries was supplied by Hohmtech for review.
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
Dlux
Last seen: 7 hours 32 min ago
Not so insane drain after all.
Thanks for the review! Beer
Superstocker
Superstocker's picture
Last seen: 4 hours 23 min ago
Thanks HKJ! Much appreciated.
CRX
CRX's picture
Last seen: 6 months 16 hours ago
Invaluable testing as always Thumbs Up
