The hottest hot rod?
31 posts / 0 new
Agro
Agro's picture
Last seen: 2 min 6 sec ago
I compiled information about a few lights, modded or stock, that excel in the output they produce for their size.
The spreadsheet is editable for anyone, available here:
https://ethercalc.net/we4jch9r0apm
The hottest hot rod on the list so far is Vollsion SP11vn with XHP50.2 3V which does 1400 lm while being one of the smallest AAA lights.
Not surprisingly, the top of the list is dominated by mules and near-mules.
10440 and 18350 sized lights seem to top the list. I’m surprised I couldn’t find any serious 14500 contender.
Edited by: Agro on 11/21/2020 - 03:09
richbuff
Last seen: 1 hour 14 min ago
Thanks for bringing up this fascinating topic. Your list shows that the hottest hot rods are also among the smallest ones.
I am working on collecting the hottest single cell 18650 and 21700 hot rods. The most hotness per given size, and the smallest size per amount of hotness: Fascinating! Added bonus: The hot rods also have normal modes for normal runtime and normal heat generation.
Not to brag or anything, but I'm kind of a big deal to my flashlights.
CRX
CRX's picture
Last seen: 6 hours 26 min ago
I did a Tool AA 14500, FET driver & SST-40 that put out around 1900lm.
Relight Mokume Gane 14500, XP-L HI, 1200lm.
JetBeam Element E3S, 14500, SST-40, 1600lm.
FourSevens Mini AA, 14250×2, XHP50, 1700lm.
Thrunite T10T 14250×2, XHP50, 1700lm.
DQG Hobi Ti 10250×2, XHP50, 1600lm.
BLF 348 10180×2, MT-G2, 700lm.
I might fill out some details later.
I’m sure DB Custom did some crazy output 14500 lights.
Xandre
Xandre's picture
Last seen: 2 hours 32 min ago
Maybe like this :
http://budgetlightforum.com/node/37832
Regards Xandre
The_Driver
The_Driver's picture
Last seen: 1 week 3 days ago
Interestting!
Just a small correction: the unit of the hotness rating doesn't fit the numbers. It should be klm/cm3
Agro
Agro's picture
It seems correct to me…*k*lm/mm³.
Or lm/cm³. Which seems more natural…and I switched the spreadsheet to use it.
Yokiamy
Yokiamy's picture
Last seen: 1 hour 27 min ago
CRX, that Tool must be HOT !
CRX
CRX's picture
Yeah I changed it soon after to a 7135 driver I think.
dave1010
dave1010's picture
Last seen: 1 hour 12 min ago
It’d be interesting to add a couple of bigger ones on here, to see how they compare per cubic centimetre (such as Imalent’s MS18 at 100,000 lumens).
Some other single 27100 lights, around 9000lm:
  • Nitecore TM9K
  • Imalent MS03
  • Nightwatch NS53A
The Astrolux EC03, Lumintop FW21 Pro and Fireflies E07 are all around 6000lm, so probably won’t make this list.
Could a single 18650 the size of a D4 drive 3 XHP50.2 LEDs over 10,000lm?
https://davestechreviews.wordpress.com/ / Email: <my BLF username>@gmail.com
led4power
led4power's picture
Last seen: 17 hours 39 min ago
You could also add lm/gram unit, but also unit which would tell how long those lumens can be sustained (for ex. before OTP kicks in, or brightness drops below 90% of initial max. lumen, whichever happens first), units could be lm*sec/cm3 , and lm*sec/gram.
richbuff
dave1010 wrote:
It'd be interesting to add a couple of bigger ones on here, to see how they compare per cubic centimetre (such as Imalent's MS18 at 100,000 lumens). Some other single 27100 lights, around 9000lm: * Nitecore TM9K * Imalent MS03 * Nightwatch NS53A The Astrolux EC03, Lumintop FW21 Pro and Fireflies E07 are all around 6000lm, so probably won't make this list. Could a single 18650 the size of a D4 drive 3 XHP50.2 LEDs over 10,000lm?
The three bullet pointed lights that you mention: The first and third fit right in my hot rod collection, among the hottest rods for their size. The second one: I ordered two of them from my favorite USA supplier.
Lumintop FW21 Pro, 3 x XHP50.2 3V: Neils website says  ~10,000 lumens, I submitted a serious inquiry to my fav light guy for three of them, he says he is checking on latching onto a batch of them.
Y, t a h n m f n r a n h g! Yay!
Agro
Agro's picture
You’re welcome to add these columns. Smile
Agro
Agro's picture
  • Nitecore TM9K
  • Imalent MS03
  • Nightwatch NS53A
Thanks, MS03 made it to the top of the list!
I’m not a fan of this brand but nevertheless I’m impressed.
Does anyone know tailcap diameters of TM9K and NS53A?
dave1010
dave1010's picture
Added the NS53A’s tail diameter of 28mm.
Agro
Agro's picture
I don’t see on your mods list. I’d like to add it to the table but I see that it is available with 2 different tails, could you please indicate which one did you use?
Thx. Smile
samyy
The new Imalent LD70 – built-in battery (18350?), XHP70.2 and 4000lm Shocked this
CRX
CRX's picture
It was a short lived direct drive version with lighted tail. I didn’t make a thread.
Agro
Agro's picture
BTW, I find it curious that you got 1900 lm with SST-40 yet Vinh gets 1600 with XHP50.2 3V
CRX
CRX's picture
Direct drive, cracking bin LED, cell used, ANSI standard, planets aligned, different equipment...
I see vinh recommends to use the Vapecell 3A 14500, prob used that for testing.
I used a WindyFire red 14500. Don't get too caught up in the numbers.
dave1010
dave1010's picture
I liked this thread so much, I started a similar thread on pocket throwers over here: http://budgetlightforum.com/node/73093
2A
Last seen: 12 hours 42 min ago
very interesting database, thanks for the insights.
Chatika vas Paus
Chatika vas Paus's picture
Last seen: 3 hours 53 min ago
Yup. He also did some amazing projects. Not only 14500 and when I read your post, the first thing I thought about was 458 HAM’R
the4ds9
the4ds9's picture
Last seen: 5 days 19 hours ago
Thrunite TN50 CW is pretty hot. Its 4 21700 batteries are wired directly. The company rep told me they use LG. Wow imagine if it was VTC6A or 40T
patmurris
patmurris's picture
Last seen: 16 hours 29 min ago
Thanks for this very interesting hotrod list.
I wonder how the FF ROT 66 Gen II w XPL HI would rank. It is supposed to spit out 14k lumen stock but it’s probably less. The light is quite compact though.
http://www.ff-light.com/index.php?route=product/product&product_id=50
Agro
Agro's picture
I don’t think they’ll come close to the top…but you’re welcome to add them to the sheet. Smile
I wanted to add it but there are no dimensions given. Anyway I actually don’t think it’s very hot compared to the small lights listed here.
Xandre
Xandre's picture
That one from Djozz is nice,too:
http://budgetlightforum.com/node/29825
Regards Xandre
Agro
Agro's picture
Nice…but not very hot really. I added it now.
dave1010
dave1010's picture
The spreadsheet seems to have gone. Anyone got a copy?
Agro
Agro's picture
It looks like ethercalc got their domain hijacked.
They moved to ethercalc.net. I updated the link in the first post.
dave1010
dave1010's picture
Thanks Agro
Artiet59
I was very interested in Vinh’s Thrunite t10 with sbt90, think it’s 2000 lumens at start. 14500 . Thanks for the list!
Edit- don’t know how it plays into the list given I highly doubt 2000l is sustainable for more then 30s.. it’d prob turn into a molten iron lol.
