✌ FREEME - ASTROLUX FT03 Mini XHP50.2 (4200lm) / SST40 Anduril AUX LEDs USB-C 18650 Flashlight - ALIVE
299 posts / 0 new
d_t_a
Last seen: 20 min 13 sec ago
oweban wrote:
Update on the driver – it uses the T1634, as in the D4v2.
Now here’s the fun part – is Astrolux going to make the source code available, and the build used, as required by the GPLv3 license? Is there going to be a pogo-adapter made available, as it uses a non-standard pad layout, and can’t be flashed via a SOIC clip?
Tested pulling ~6.3A on a VCT6, too.
edit:: this was not a fun driver to get out. Short wires everywhere.
Using the 15H version check, the firmware version reads 2019-09-28 (this is also the same Anduril version date on the Meote FM1 Copper with Anduril)..
Any update on the FT03-Mini with Osram NM1 LED? Will it also use Anduril? And also, any idea what’s the max current consumption for the FT03-Mini Osram version (I suppose it has to use different power than the SST40/XHP50.2 which use higher power)
oweban
oweban's picture
Last seen: 3 weeks 6 days ago
Yep, got the date – I should have checked before; so it’s version 446. Problem is though, what build target have they applied here? As of that build, the only T1634 hardware was the D4V2; is it a fork of that, or a direct “flash and go”?
What’s required is a copyright notice, a link to the code, and information about which config to use.
freeme
freeme's picture
Last seen: 9 min 13 sec ago
How many people are interested in FT03 mini NM.1? I need to provide an estimate for Banggood soon. cool
id30209
id30209's picture
Last seen: 4 hours 47 min ago
I was thinking to mod my Blue Mini but if BG vome up with Titanium/Copper or clear alu/copper model i’d be totally in
WTB Titanium 4sevens 2xAA tube
djozz
djozz's picture
Last seen: 59 min ago
Will they together with the NM1 use a regulated driver at 4.5A ? A direct driver will be no good for this led.
Tom E
Tom E's picture
Last seen: 13 hours 37 min ago
I'm interested in knowing what a NM.1 is, then maybe. I'll do some search'n... Never heard of it
No luck search'n on BLF frown
id30209
id30209's picture
What djozz said...
RapidLux
RapidLux's picture
Last seen: 50 min 54 sec ago
I can see Astrolux FT03S has got some bad reviews. Has Astrolux improved their build quality with the FT03 mini?
Bad review FT03S https://www.youtube.com/watch?v=1nDyHIkmTCY
Tom E
Tom E's picture
RapidLux wrote:
I can see Astrolux FT03S has got some bad reviews. Has Astrolux improved their build quality with the FT03 mini? Bad review FT03S https://www.youtube.com/watch?v=1nDyHIkmTCY[/quote]
Sorry, I ain't got time for a 32 min vid to get a simple answer... Yikes!
oweban
oweban's picture
Tom E wrote:
I’m interested in knowing what a NM.1 is, then maybe. I’ll do some search’n… Never heard of it
No luck search’n on BLF frown
I think he means cslnm1.tg – white flat 1.
RapidLux
RapidLux's picture
Interested, SST-40 (5000K) or NM.1(?), depending on which one has the best throw and tint (5700K to 4000K).
freeme
freeme's picture
Any more?
RapidLux
RapidLux's picture
NM.1 vs SST-40 https://www.youtube.com/watch?v=JpR2bUXeaXI
Edit: If the Osram orange colour is as bright, it would be exciting to test how it works in fog and rain.
www.youtube.com/watch?v=giCPm8vTawk
Barristered
Last seen: 7 months 1 week ago
A code for the FT03 Mini XHP50.2 would be greatly appreciated as no codes appear to work from page 1 ?
Thanks
chrisc
I too would love a code for the FT03 Mini XHP50.2
TheAuditor
Last seen: 34 min 57 sec ago
The NM.1 has popped up on BG. Not available yet.
Bonum commune communitatis.
Yarp.
JordanZHP
Last seen: 6 hours 30 min ago
Full copper still happening? Interested!
Tom E
Tom E's picture
Ok, NM1 = W1. Put me down for 1 as interested!
oweban
oweban's picture
Note the more simple driver. Not a problem, just mentioning.
id30209
id30209's picture
That was my thought exactly!
jmd4tide
Interested
Mark Duran
RapidLux
RapidLux's picture
lightdecay
Interested. Could I get the coupon?
madcrisis
Interested. Are there any other lights with the nm1 I could look at to get an idea of what its about?
d_t_a
There is the Wainlight C8+ with Osram NM1 LED, this is very similar to other C8 flashlights, but produces a more focused (more throwy) beam, but less total light output.
left:Convoy C8+ with XPL-Hi LED
right: Wainlight C8+ with Osram NM1 LED
Osram NM1 LED has a very tiny light emitting portion (the yellow square)
left: Convoy C8+ with XPL-Hi
Osram NM1 lights up a smaller area but more intense (throws farther).
I suspect the FT03-Mini with Osram NM1 will have similar throw (or a bit better) as the Wainlight C8+ with Osram NM1, but with better user interface.
Also the Osram NM1 LED on the Wainlight C8+ only uses up to 2.8 Amps max power, not yet maximizing the Osram's potential. Hopefully the FT03-Mini will better optimize the power (maybe like 4.5 Amps of power applied to the Osram LED), and also have a well-focused reflector.
Gr8Swammee
Last seen: 14 hours 50 min ago
def interested in a nm.1
rockfanatic
rockfanatic's picture
Last seen: 3 weeks 5 days ago
interested blue one
id30209
id30209's picture
Colored mini just became available on BG
freeme
freeme's picture
Group buy is ALIVE now. cool
id30209
id30209's picture
@freeme
Can you confirm what djozz asked before?
