2 - Maha C9000's
1 - Maha c808m
1 - Accucel 6 Hobby Charger
1 - Home made power supply
1 - Digital Multimeter
1 - Digital Temperature Gun ( for measuring battery temperatures )
1 - Digital Caliper
1 - Digital scale
I also have various charging leads, clamps, wires, battery holders, etc.
I've also got a box of obsolete (dumb chargers), but they were not picture worthy.
I keep my charged batteries stored inside an ammo can, I may add pictures of them later if I fell like getting them all out (theirs a lot of them!)
Heres a picture of my rework station, just for the heck of it ! It's an aoyue2702 (where have I heard that before?? )
I have a single TR-001 charger, cost roughly $7, and a FUKE multimeter that cost me around 5€ years ago. I'll have to swap the 9V battery, it started complaining that it's low. After about 9 years?
Btw, TR-001 has independent channels and stops charging, independently, at the 4.17-4.18V mark, according to FUKE.
Why do you guys have so many chargers? How fast do you discharge your batteries? And how many per day? :D
I always solder using my Panavise. It's like having a third hand. I also use an illuminated magnifier which makes it easier to see what I'm doing on the smaller stuff. When you get older like me, the eyes don't work as well as they used to..
What's the cheapest (and still somewhat reliable) tester/charger that shows mAh?
I know, I could probably put proper resistors on the batteries, measure the time they discharge and calculate as well. Anyone got a good article on self measure'n'calculate method?
don't get the lacrosse bc700 - unreliable and warranty says they can charge you if it doesn't need repair or it was your fault.
temp sensor (thermistor?) on one of 2 banks just failed on mine and it is a month old (admittedly it was cycling batteries that entire time, but come on...). also many reports of failures in amazon reviews.
Ok...did some research. The turnigy accucell only runs about 45 dollars. I'm sold. I will use that for all of my expensive batteries, AW, callie kustoms, red 3100 trustfires...
