groupbuy: Astrolux MF02S SBT90.2 (600kcd) ONLINE
141 posts / 0 new
M4D M4X
M4D M4X's picture
Last seen: 1 hour 13 min ago
for "my" price you need to contact me
the anyguy "BG" code will be more expensive in a few days...
PLEASE NOTE
i do not work in "reviews, deals and codes" for the time being
maybe M4D M4X will return one day, but until then:
THANK YOU FOR YEARS OF YOUR SUPPORT AND FRIENDLY CONTACTS!
spaghettikku
Very hot.. i recommend for buy handle
my9221
Last seen: 4 hours 42 min ago
Where you ordered from as BG is on preordered?
chrlee
Last seen: 2 days 14 hours ago
Unfortunately, the MF02S v2 coupon has expired. Could you give me a new one?
Funtastic
Funtastic's picture
Last seen: 4 min 16 sec ago
Almost 6 months later, can I have a coupon lol
Texas Ace Lumen Tube calibrated with maukka lights
New Zealand store – https://www.piercingthedarkness.co.nz (NZ customers only)
YouTube channel – https://www.youtube.com/channel/UCIUWi2vYp4CWrRkOJM70t_w/videos (Demos for my customers, and reviews)
chrlee
The groupbuy has ended, but the flashlight is still available. Where is the problem? Smile
Funtastic
Funtastic's picture
No problem, just found it amusing after so long.
Artiet59
Last seen: 5 min 11 sec ago
Just got kind in last week, love it but notice 30q’s I have won’t hold turbo once they get to about 3.5v each, or so. I may have a bad 30q unnoticed when charging, but that’s a different problem.
Question to anyone who knows-
Can you use flat tops in this MF02s V2? It looks like you can with the brass tabs in the battery tube, it I just wanted to see if anyone has been successfully doing this before I order some Molicel P26a flat tops.
Thanks!
Funtastic
Funtastic's picture
Flat tops work fine Smile sold a couple with flat tops.
Turbo requires 35A (from memory) and at 3.5v the voltage drop/sag would be unable to allow Turbo.
Artiet59
oh man, thank you Funtastic! that is great information and i really appreciate the quick response to this, very helpful! Looks like P26’s or VTC5a’s are what i need then.
Also, i really enjoy the YT channel, i think it is you that has been posting great thrower reviews lately, convoys, etc? If not sorry, but if it is you, keep them coming they’ve been helping me a lot!
d_t_a
Last seen: 5 hours 39 min ago
I believe the earlier MF0x models use this kind of battery carrier (with a plastic washer which prevented most flat-tops from making contact — an added protection in case battery is inserted incorrectly)
Newer MF0x series likely use this kind of battery carrier, so flat-tops work now (but be careful not to insert battery upside down, which will create a short and will just burn out the springs, assuming not-so-worse case scenario)
zoulas
zoulas's picture
Last seen: 6 min 49 sec ago
Why anyone would inset the battery upside down is beyond me. The spring side has always been the negative side for decades.
Funtastic
Funtastic's picture
That is a good comment DTA made and reminded me that there’s a long version that uses 8× 18650’s. Do you have the short or long version? The short version can use flat tops no problem, but no idea on the long version.
I haven’t for a little while, but have got a few on there of the Convoy’s. I have another on the way of the Convoy Z1 with Osram CSLPM1 vs SST40 since I can’t find a video of it.
DTA – the short version doesn’t have a battery carrier, only the long version
d_t_a
Sorry, I made a mistake.
I don’t have an MF02S v2 at this time… the pictures were from an MF02 battery carrier and MF04 battery carrier — I thought the MF02S v2 used the same battery carrier as the MF02 and MF04, but it looks like they don’t.
Artiet59
Yes, thank you dta, that is good info.
I have the short version and it does not have a battery carrier, it is “built in” with the tailcap having buttons and springs and a mcpcb screwed in at the head side of the battery tube.
But to agree with Zoulas, I have always wondered how people insert the batteries in the wrong way (i just read a comment a week or two ago about someone ruining a $300 light that didn’t have RPP because the battery went in the wrong way). I guess if you just aren’t paying attention because putting batteries in seems like such a menial task that would make sense. i hope it never happens to me!
Artiet59
yea different carrier because of the 6v / 12v xhp series ( i believe) vs the 3v sbt90.2 although the sbt90.2 is 2s2p, so in actuality they may be the same. Maybe someone else can confirm, i used to own the mf02s xhp70 but i dont remember exactly how the carrier was.
Funtastic
Funtastic's picture
Sold a Convoy 4×18A and the customer reversed one or all of the batteries, killed the light and drained all 4 batteries. Lied about it, and so now I include clear instructions and a warning that warranty will be void if they get the polarity wrong.
Artiet59
Damn! that sucks.. I wonder how often manufacturers have to deal with that? Im sure way to often… just amazing..
Funtastic
Funtastic's picture
Had one guy that already owned a Convoy L6 reverse the batteries on the new unit I sent him. Well, while talking to his partner he chucked the batteries in wrong, killed it. I refunded him and sent him down a new one as he wasn’t “sure” that’s actually what he did lol I tested it before sending so that’s exactly what happened.
Everything that I sell gets tested twice, once on arrival and again before shipping out. Only 5 customer warranty replacements in 7 years Smile a lot of work though. I clean the contact points, lube threads, and make sure retaining rings and screws are tight, also install dual springs instead of the factory spring bypasses
Sold another L6 to a nurse at a medical center I often visited. She didn’t even read the instructions and inserted the batteries wrongly, thankfully I swapped the Convoy driver for a Sofirn SP70 that had reverse polarity protection.
chriscio
Last seen: 3 days 18 hours ago
Very interested
