[Review] Sofirn SP33 V3 - XHP50.2 3V eSwitch 26650
43 posts / 0 new
Unheard
Unheard's picture
Last seen: 16 min 31 sec ago
Tom E wrote:
I solder the bypasses inside the spring – if the solder joint breaks, you don’t want that wire touching something it shouldn’t on the driver side.
Though the outer bypass has advantages – the spring can completely collapse down if a battery fits tight.
Yes, this is my concern. I have a 20700 for the SP33. Maybe I need to go back to the 26650. Or leaving the spring on the driver side untouched.
Smile, you cannot kill them all.
Tom E
Tom E's picture
Last seen: 5 hours 21 min ago
oweban wrote:
On the driver side I’d do my best to do it on the inside (would spend more time on it than I did), but for the tailcap side, it’s all one slab of metal so I figured it was fine for the outside. It’s unfortunate that “3500” ended up being 2200, though.
2200 is much lower than mine before the bypasses. By out of the box, do you mean the battery out of the box as well, not fully charged?
oweban
oweban's picture
Last seen: 6 months 1 week ago
Sorry, no – fully charged, but the kit battery. Have tested in both a lumen tube and sphere, both calibrated with lights from Maukka.
Also some crazy thermals.
Tom E
Tom E's picture
Is X in minutes or seconds? My lumens measurements are in "Tom E" calibrated lumens which is 12% higher than Maukka cal'ed. Just subtract 12% from my #'s. I didn't get their kit w/battery though.
My "Tom E" units were originally based on manufacturer ratings, but leaning towards the manufacturers that are higher end and consistent. It's rare to see any manufacturer come close to Maukka rated lumens. I try to give the manufacturers benefit of the doubt by still using "Tom E" ratings rather than Maukka cal ratings, but comparisons on BLF here is better to use Maukka ratings. For me it's easy though - 12%, that's it. I did have the Maukka cal lights to calibrate my PVC lightbox by.
gchart
gchart's picture
Last seen: 1 hour 26 min ago
I’ve gotta say… I did a couple updates to my lumen tube and set a new conversion factor (using my TO50R as a trusted source, alongside Maukka’s confirmed measurements of the TO50R) and I’m now showing 2200 lumens with my SP33 V3 as well Sad
oweban
oweban's picture
Ah, sorry. X is minutes; just grabbed that from my google sheet.
This is a closeup of the first 20 minutes on High (my labelling is garbage):
Tom E
Tom E's picture
gchart wrote:
I've gotta say... I did a couple updates to my lumen tube and set a new conversion factor (using my TO50R as a trusted source) and I'm now showing 2200 lumens with my SP33 V3 as well :(
My Maukka cal #'s are 12% lower - simple conversion, calibrated w/Maukka lights.
Still on a red Dolilada 5500 mAh 26650, I got 3270 at 30 secs. Subtract 12% and you get: 2870. Could be the stock cell is really that bad, or some differences in the lights.
oweban
oweban's picture
It can be good (enough) though – I got 10A in a tailcap amp test with the Sofirn cell, and when I bypassed the spring in it, I jumped up to 2800lm. With a 40T I was only getting 11.25A…
/shrug
I’ll check it one last time tomorrow night because I’m kinda done with it :/
Tom E
Tom E's picture
Yikes, yeah, that 11.25 amps on a 40T is much lower that what I got (14.7 amps using a clamp meter, heavy gauge wire). That explains the lumens.
hungtran369
Last seen: 1 day 20 hours ago
Thankyou for more detail
Funtastic
Funtastic's picture
Last seen: 1 hour 55 min ago
Shows he got a faulty light I reckon. I get just over 3200 like you Tom. Real shame it just happened to be the light up for review on 1lumen
Texas Ace Lumen Tube calibrated with maukka lights
New Zealand store – https://www.piercingthedarkness.co.nz (NZ customers only)
YouTube channel – https://www.youtube.com/channel/UCIUWi2vYp4CWrRkOJM70t_w/videos (Demos for my customers, and reviews)
Zappaman
Zappaman's picture
FYI: Lan at Sofirn just informed me the 5k version of the SP33v3 is (finally) BACK IN STOCK!!! I have one ordered since last August.
ZappaMan
