Send you the temperature test clip of Brinyte T27 Artemis.
The light uses osram 3030 2mm leds, the brightness is over 1000 lumens, the distance is more than 1km.
Some special points on Brinyte T27 Artemis, you also saw in the previous clip, then I summarize a few key points:
The first to mention is the remote control switch. Do not have to control by infrared, so even if there are obstacles, we can still turn on and off the lights remotely.
The second is a convenient magnet charger with fast charging current up to 2A
The third point is a 21700 battery with protection and integrated Type C charging port. If you go far and forget the charger cable, you can charge it with a phone charger with fast charging current up to 2A. The 5000mAh battery is also enough for you to use all night.
