[4K Review] JETBEAM JET-RRT03 RAPTOR, best 18350 light yet?
Apart from a wonky tailstand this EDC takes some beating.
I have the same light as yours, i.e. 219C emitters but I did not opt for the extension tubes.
It’s a great light, just that the beam profile for the RGB have some shadowy lines for short distance lighting, unlike the clean floody beam from the main emitters
what am i missing?
Mode Stepping: Low → Strobe →SOS → High
—low to strobe? how is that not super annoying??
Switch: Tail, Rotary Twist
==a twist switch.>? how is that not slow and annoying?
wle
_
I’m following this thread to find out how this light could possibly be the best 18350 light yet. The suspense is killing me.
yeah that was kind of my point too
:slight_smile:
though it does have colored aux lights
who is the person claiming that?
wle
I own this light and it doesn’t work that way. Ring has 5 detentes in the following order: Low —> Medium —> High —> Colored aux LEDs —> strobes
Some people like this interface. You can set the ring to your favorite position and forget about it. Thereafter, turning it on is a simple matter of pressing the tailswitch button which is very fast.
What I like about this light:
  • best tint of any triple I own. Truly excellent choice of main emitters.
  • attractive looking flashlight.
What I don’t like:
  • No real low mode. “low” is something like 80 lumens. It’s far too high for many situations. Jetbeam really dropped the ball on that. A better option would have been to remove the medium detente and make the space on the ring between low and medium infinitely variable.
  • Colored blinky modes beam pattern is useless for anything other than partying or maybe using as a warning light while walking around.
  • Forward clicky might turn on if slightly depressed in the pocket. This could end up accidentally draining the battery. Especially since there isn’t a real low mode.
another thing i would hate
the light levels are not useful
i have another jetbeam with the same thing
low is about 20, too high
the next is 150 or so, too big a jump
and then 800, which lasts about 30 sec
would rather have 5 or 6 evenly spaced levels, starting at about 1 lumen - like say anduril does
1 3 10 30 100 300 1000
something like that
wle
definite NO
3 modes, the lowest being 80 lumens…
not my cup of tea
I guess that this is just a matter of opinion.
In my opinion, this is not the grail 18350 light even though the same company made the grail light.
They also made one with a similar UI to this one, a TCR-10.
For a tail switch grail light similar to this but with infinite variable brightness, another company made it (SWM) with a 16340 but could be bored to except 18350.
This is all just a matter of opinion but I think a lot of members would agree.
The TCR-1 and Sunwayman V10 Ti are still highly sought after lights and treasured by those who are lucky enough to own them. :slight_smile:
Agreed. In my opinion, this is not the “grail: 18350 light.
I rate this is a “near miss” in terms of making a great light. Simply changing the UI to make the main LED infinitely variable while keeping all other features as-is would have made it a great a light.
Would that have made it the best 18350 light? … I don’t think so. It’s still a bit big for an 18350 light. But those changes would have been enough to turn what is now a decent light into a very good light.
What I’d like to see:
A button-less TCR-1 with the triple emitters from the RRT-03, and aux colored LED emitters accessible via hidden series of movements (like how to access strobe in the RRT-01).
agree, a missed opportunity
I feel you understand deeply :slight_smile:
stepless ramping to sublumen levels,
would have made the light viable for indoor use,
even nightstand use,
making it a true 24/7 EDC,
instead of just a driveway flooder.
brilliant synthesis
Anduril in a TCR-1 triple
The Force is Strong with This One
[quote=Firelight2]
I definitely agree with you on the things that you don’t like above.
They should include a moonlight mode to make it a more useful bedside light as the 80 lumens is just too bright for bedtime purposes.
The RGB beam patterns with shadowy lines are just plain irritating for close-up applications
I would also prefer for the length to be shorter as this light is just slightly shorter than FW3A which uses 18650 battery
