REVIEW - Sofirn SD05 - No Stepdown Version
For my first review of a flashlight, I'd like to write a bit about the SD05 diving light by Sofirn. I will be reviewing the 6000K version with 4000mah battery/charger combo. This light may be purchased through Amazon through the link below (shipped from the U.S.). Use the coupon code for a 29% discount on the listed price.
https://www.amazon.com/dp/B07SJ5J6YQ?ref=myi_title_dp
29% discount: ZSBG3RMQ
This light represents a couple of other firsts for me. It is my first 21700 light and it is my first rotary light. I will be reviewing it less from a technical standpoint and more from real-world observations and opinion.
Everything came well packaged and protected in a nice, small, plain box. The flashlight was wrapped in bubble wrap to keep it safe from bangs and scratches from the other items in the box. There was also a small piece of foam for padding. Included was a simple but effective charger, a USB cable, a spacer to use 18650 batteries, a small bag with two extra o-rings and a lanyard, and an instruction manual (in English, German, and Russian).
https://pictr.com/image/7msqt5
!{width:65%}https://pictr.com/images/2020/07/17/7msqt5.jpg!
The light itself is actually smaller than I thought it would be. The body has only a slightly larger diameter than an 18650 light. Its head grows to the size of a 26650 light to hold that big orange peel reflector and to help with cooling. Those cooling fins have a maximum depth of 3mm. Comparing it to Sofirn's own SP32A V2 and SP33 V2, it is the shortest of the three. Like the SP33, it's not meant to be clipped inside a jeans pocket, but then, it's not meant to be an EDC light. Carried in a jacket or cargo pants pocket is no problem. I was surprised by the lack of any knurling anywhere on the light. It can be a bit slippery, but fortunately the rotary ring has indents that allow decent grip with index finger and thumb. I still think a bit of roughness to the finish would help.
https://pictr.com/image/7msRAV
Inside the flashlight itself was a Sofirn 4000mah 21700 battery. It states "40A" on it. That's a rather high drain rate claim that I cannot test, but even if it is overstated by a factor of two, that's still more than this light can draw. In fact, if you wanted more capacity, I'm sure a 5000mah 10A battery would not affect output.
https://pictr.com/image/7msyc8
The lanyard in my set is ridiculously long. The tailcap has a large enough hold to attach the mini clip from the lanyard instead of the usual smaller cord. The little locking bead is needed if using this light in hand underwater, as an open lanyard tends to get pulled loose by the motion of the water. The length is good in case you need to throw your light at an attacking fish while still keeping the fish at a distance.
https://pictr.com/image/7msXhX
https://pictr.com/image/7ms2NQ
The tube has different sized threads on each side, both well lubed, and both with two o-rings. There are springs on both sides, which allow the use of 18650 and 21700 batteries. In fact, the included 21700 feels a bit long for the light, but does fit comfortably. Even an unprotected flat-top 18650 holds with no problem. As usual for Sofirn, the head seems all glued up.
Using the rotary ring is a delight. Despite, as mentioned earlier, the lack of knurling, the switch has just the right amount of resistance to prevent worry about unwanted mode changes without being difficult to manipulate. There are detents for each level that hold the ring in place. The light level changes about midway between each detent. Even underwater it was relatively easy to operate. It would be improved by some form of grippiness though. The only other improvement would be an infinite adjustable light level, though that would probably add a significant amount to the cost.
Being the 6000K version, I was initially worried about the tint of the light. To my delight, it is actually quite nice. It's not high CRI, and on low there is a bit of a green corona around the spot, but it avoids the sickly tint that makes everything look like a mysterious, foggy night. On medium and high, it simply looks white. The modes are well spaced, though again as this is not an EDC light, there are no "low" modes. Low is 300 lumens, mid is 900, and high is 2550, as claimed by Sofirn. I have no reason to doubt these numbers. This means it's not a great sneak-around-the-house-at-night light, but it can be used quite well to light a room if the power is out.
Using a Cree XHP50.2, I was concerned about the light having a donut hole. Yet again, I was pleased that this is not the case. The spot is nice and even with a slightly dimmer (though slightly green) corona, fading out to a slightly blue outer ring. It is much nicer than the beam produced in the SP33, as well as having a better tint.
The big thing here, if using this light in the water, is the fact that there is no longer a step-down on high mode. There are other reviews who have put this light through more rigorous depth testing and the light performed admirably. I was able to run it only to a depth of 4 meters in a pool whose water temperature was 29 degrees C. There was no problem with ingress of water. There was also no problem running the light on high. After ten minutes, the head of the light felt as cool as when I first turned it on. This means that is can be run on high indefinitely while diving. The claimed runtime is one hour thirty-eight minutes on high (probably including output at lower levels as the battery drains), so that would provide maximum brightness for a respectable dive-time.
Due to the size of the head and the cooling fins, mid level is sustainable even when not in water. So if this light was to be used for a night hike, and the 300 lumen level is not enough, 900 lumens can be had as long as the battery holds out. The beam is a good mix between flood and throw When used on high, it makes sense why Sofirn initially used a stepdown timer on the older version. It takes a few minutes, but the light does heat up. I don't know if the old version also had temperature control, but this version does, and to my surprise it works quite well. It takes between three to five minutes for the light to start ramping down, keeping the temperature below 55 degrees C and around the mid setting. Resetting the light back to high will return the brightness to at least close to its full power, but ramps down quickly again if the light is still hot. It would probably take several attempts at doing this to actually get the outer temperature to surpass 55 degrees.
Overall, I am quite pleased by this light. It certainly succeeds in its intended uses and even excels in some areas outside of its wheelhouse. Its ease of use means you can hand it to anybody and that person can figure out how to use it. If going diving or hiking (or taking out the garbage and not wanting to be bitten by raccoons), this would be a light well worth bringing along.
Congratulations on your first review!
When you go to the site that hosts your pictures and right-click, and choose “copy Image Location”
Like the one below:
If you then use the Insert Image tool on BLF, and inset the URL that ends in .jpg
The code in your POST will look like:
Without the quotes on each end.
The width:65% is how much of the width you want to fill with the image. Always best to use 95% or less depending on the shape of the image.
And you get your image in the POST. Like:
Keep up the good work,
All the Best,
Jeff
Thanks for the tip! Strangely, I cannot edit the original post to add the pictures. But it does look like I can put them in a new post. I guess I’ll show them here, in case somebody doesn’t feel like clicking on the links as they read.
…Is it my computer, or are the pictures not showing up for anybody?
I can see them fine. You should be able to edit the OP though - weird.
Oops! I can see a pic of a box in the OP now!
This is strange… If I view the page on Chrome, I see all the pictures (including the one I was able to add on the original post). Using Firefox though, no pictures show up, including the one jeff51 showed. I wonder what I have on Firefox that’s not showing the pictures. I see plenty of pictures on other peoples’ posts.
In your origional post I see just the box.
In the other one I see three Images. Box, 3 lights, and light with battery.
I sometimes have issues on Chrome with my Android tablet.
Not showing what I expect. Sometimes I have to close the app to get the page to reload correctly.
Something odd about the BLF software.
For me, if I past some text into a comment box,
The Save/Preview boxes are grayed out.
If I add anything to the text - Like a space at the end of a line.
The Save/Preview come to life and I can get one with things.
Firefox is what I normally use, and it works for me…
What OS / hardware are you using?
After you get comfortable with the image locations.
You can just paste them into a line:
A picture embed always starts and ends with !
Without the quotes.
Just paste in your URL after the width thingie.
I find that easier to do when writing a big POST in a word processor, before copying it to the BLF editing window.
Again, Thanks for the review.
All the Best,
Jeff
I am a bit confused by this review, because I have this light, and your statement about how the light would benefit if it had temperature control. This confuses me, because it does have automatic decrease in temperature set at 55 degrees Celsius. Other than that, it seems to be a good review. Sofirn did away with the 3 minute timed cutback based solely on complaints of having both temperature and the timed cutbacks when being in the water keeps it cool enough to prevent the 55 degrees from being reached, but caused a diver to have to move the ring back to medium then high again every 3 minutes. Sofirn listened, and removed the annoying timer, but it will still cut back to prevent it from overheating. One thing that should be stated…do not forget that almost any magnet near the light can cause the light to come on. If putting it in a bag, it is best to back the cap up to disengage the battery. If putting it in your pocket be sure nothing containing a magnet is in that pocket. The magnet does not even have to touch it, just be near enough.
I’m running Windows 10. It must be a plug-in I have running on Firefox that’s blocking the links.
When I went back to edit the original post, I added the url to the add image box, hit the ok button, but nothing showed up in the post. I actually typed out the line and in Firefox, all I saw was that line of code as a link. Right now, I do NOT see the photo in the first post, nor do I see the link (besides the one that I originally used).
In the latter post, the add image option actually created the links for me, but as I said, I don’t see the pictures in Firefox. Guess it’s time to start shutting off the plug-ins to find out which one is blocking the pics.
Found it! It was a privacy blocker add-on that was blocking the pictures from loading.
Thanks for the advice; now let me go and properly load the other pictures into the original post!
I just checked to be sure and the temperature regulation does work properly on the light…it reached about 55 degrees and the intensity of the light gradually cut back to medium high. It also has undervoltage protection, so you can safely turn it on and let it run until it cuts off…it will not go nuclear.
…I think I give up. I simply cannot get the insert image button to add an image to an old post. If I type out or even copy the link, it simply writes it as a link! What am I doing wrong???
I copied the exact line that made the picture show up in this post into the first post and in the first post it actually types out the line as is and creates the link.
Thanks for the info, sarge. Either I never left it on long enough for the regulation to kick in or it started to ramp down but I could not discern the drop by eye. After four or five minutes it certainly felt hot enough to the touch that I didn’t want to leave it on high any longer!
Just for grins,
past the line that’s supposed to embed the image and put quote marks (“) at each end so we can look at it.
I just grabbed a temperature gun and sure enough, it does step down! After around six minutes, the temperature was stable at about 49 degrees C. The brightness was still slightly above the mid setting. Resetting high mode put it back to full power, but ramped down quickly again, reaching 53 degrees C. I’m actually impressed how well the temperature regulation works on this light! I stand corrected on what I said in my original post; this light will not go nuclear.
O.k., I am going to post one of the pictures, and place the line in quotes to see exactly what is typed. I will then go an try to edit this post, both by using the insert image button and by typing out the link again…
That was the original post, and now comes the edit.
Edit number 2:
Son of a… why does the insert image button work now on this post but not on the orignal???
Let’s try typing it out…
Edit number 3
What in the world??? NOW that works too!!!
It does drop gradually to a point you might only notice if you move it to medium and see it does not decrease the amount of light. 55 degrees does feel quite warm, but not dangerously so. I just did not want anyone to have the mistaken idea that the battery might vent if just left on high in a power failure. It, like most Sofirn lights has advanced temperature control and battery low voltage safeties, so you do not really need to use protected batteries in this light. If it does need a protected battery, it will say protected battery recommended in the manual. 55 Celsius is 131 Fahrenheit, so that is pretty warm to the touch.
https://pictr.com/images/2020/07/17/7ms2NQ.md.jpg
!{width:65%}https://pictr.com/images/2020/07/17/7ms2NQ.md.jpg!
Just tried it, won't work for me.
Insert button not working also.
I wonder if something is wacky at your hosting site?
Weird!
Test with one of my images.
Nope, can't insert the image.
Think something may be broke at BLF.
!{width:65%}https://live.staticflickr.com/65535/50023566117_7f51496cf8_b.jpg!
Well, at least I could update the original post regarding the temperature control. I wouldn’t want to misrepresent the flashlight in my first review! Thanks again, sarge!
I definitely think I found a picture posting bug in BLF. I can’t imagine though that this is the first time this has happened… unless I broke it! Good to see the problem verified by somebody else too. Thanks, jeff!
