Just got into flashlights with a couple of cheap q5 zoomies. One of the leds is trashed and wondered what would be a good recommendation for a replacement.
Closest I've been to modding is butchering the pil to see the star !! So any advice gratefully received !!
You will need some thermal glue, solderign iron, solder, flat screwdriver, maybe tweezers and a new probably 16mm star with a Q5 probably XR-E emitter as bare minimum.
Either repair it for the fun factor or spend way less to buy a replacement one.
given the cost of the light (sk68 clone?) I would say it isn't economical to repair - ie an emitter costs about 50% of the cost of the light - plus the time you'll spend on it.
that said - I would repair it (for fun and because it would bother me if I didn't) and I'd use XRE-R2
Deathrockets right it doesn't make financial sense to fix a cheap light but the practice working on them is worth it. One of my first LEDs an X2000 burned the emitter and I took it apart and replaced the emitter with the 5 dollar one I linked above from DX. I could have bought a whole new light for 5 bucks but I learned a lot and now to this day I still use it in the garage a year later and it has held up to ridicules amounts of abuse.
I would stick with the Q5 for a zoomie,here is a Q5 on a 20mm star. You could just press fit it again like the old one but if you glue it it will last a lot longer.
