Review: Intl-Outdoor 2200mAh 16650
5 posts / 0 new
Stephen Wallace
Last seen: 7 years 6 months ago
Ever since I became aware of the Sanyo UR16650ZT, I have been very interested in this cell. 17650/17670 cells are very popular with those that have 2xCR123A lights, and wish to use them with a single li-ion cell, but do not wish to risk boring out the light to take a 18650 cell. Likewise, they are popular with Maglite mod’ers, who use these in tri-bored, shortened D cell Maglites to make a compact light that still has enough voltage to power multiple LEDs or hot-wire bulbs. I myself was interested in using these in a tri-bored, triple XM-L MagD.
The problem with the 17mm cells is that they have not received the same level of development as 18650 cells have recently, and so capacity remains low. 1600mAh pretty much seems to be the de facto standard capacity for 17670 cells – for instance, the AW 17670, or the more recent Eagletac cell of the same size. Ultrafire have advertised 17670 cells of 1800, and even 2100mAh capacity, but considering some of their capacity claims for some of their other cells, I take that with a pinch of salt. As such, when I saw that the Sanyo cell was said to have a minimum capacity of 2100mAh, max 2200mAh, by the manufacturer, despite being an even smaller 16650, I really wanted to try these.
I spent a while looking for suppliers for protected versions of these cells, only to find that the few suppliers there were all stated that they had to be supplied by the hundred, or even thousand. Even fewer actually had these cells in stock. I eventually found that these were available from www.intl-outdoor.com, that they sold them individually, and had stock. I ordered three of these straight away.
A Quick Aside
A few people have issues with intl-outdoor, and I won’t say that I haven’t been effected. However, in my few dealings with Hank at intl-outdoor, he has never been rude, and has resolved my problems.
Along with these Sanyo cells, I also ordered three of the protected Panasonic 3100mAh cells. Like others, I received cells with protection circuits that cut out at too low of a current. These wouldn't allow anything close to a 2C discharge. Hanks new supply of cells with better protection circuits has not come in yet, so we don’t yet know how or if he will offer any deal on these for people who bought the previous cells.
What I can say is that one of the Panasonic cells that I did receive had quite a large dent in it, and I only received one of the three Sanyo cells I ordered. I reported this to Hank, and he instantly refunded me for the dented cell, and sent out two more Sanyos. I and others have since received further deliveries from Hank packed in boxes rather than padded envelopes, so damage in transit should be less likely.
Of the two Sanyo cells that I then received, one was red wrapped (this is the newer cell, and the same as the one that I received with my original order) and on was the older black wrapped cell as shown on the intl-outdoor webpage. One of the reasons for conducting this test now is to see if these cells perform the same, despite some differences in construction.
Testing equipment
A quick re-cap of the equipment used for testing: -
I will (normally) be charging cells with an iCharger 106B+, and discharging and testing internal resistance with an iCharger 208B. Two chargers are used for speed and convenience – one cell can be charging while a second is being discharged. I use the same charger for each step to ensure consistency in conditions between tests, so that results are comparable. I use iChargers specifically because they have an adjustable CV setting. This can be set as high as 4.30V – perfect for these cells.
However, for these tests, only the 208B was used. I had great difficulty getting consistent internal resistance readings with these cells. Once I achieved a consistent, low IR reading, I decided not to move the cell from charger to charger, but instead left the one cell attached to the same charger, and did all the charging and discharging steps one after another. I then attached the second cell, and did all the testing on that cell on the same charger.
Voltage is measured with a Precision Gold WG 020 multi-meter, dimensions with a Precision Gold digital calliper, and weight with a Neva digital scale stated to be accurate to 1/100th of a gram.
The base of the cell is attached to the charger via a 12” 16AWG cable with a large, strong magnet soldered to it. The positive button is attached via a magnet (if it adheres well) or via a crocodile clip. With these Sanyo cells, due to lack of magnet adhesion, and an inability for the crocodile clip to hold on to the button, I ended up threading a small split ring through the button’s vent holes, and then attaching the crocodile clip to the ring. An odd set up for sure, but it gave a lower and more consistent IR reading.
Results at a glance
Intl-Outdoor 16650 2200mAh protected
Sanyo UR16650ZT
2200mAh maximum
2100mAh minimum
4.30V charge CV
3.00V end voltage
http://industrial.panasonic.com/www-data/pdf2/ACA4000/ACA4000CE301.pdf
Purchased from: www.intl-outdoor.com
Cost: $11.55 each
Cell 1 (red)
Cell 2 (red)
Cell 3 (black)
Initial voltage
3.97V
3.97V
0.00V (1)
Measured length
69.14mm
69.22mm
69.82mm
Measured width (max)
16.91mm
17.04mm
17.11mm
Weight
39.79 grams
39.88 grams
39.72 grams
Internal resistance at initial voltage
195mOhm
195mOhm
N/A (1)
Capacity from storage down to 3.00V
1377mAh (2)
1384mAh (2)
N/A (1)
Internal resistance after storage charge
200mOhm
201mOhm
N/A (1)
Capacity from 4.3V down to 3V @ 0.4A
Terminated prior to CV phase (3)
N/A
N/A (1)
Capacity from 4.25V down to
3V @ 0.4A
1913mAh
1923mAh
N/A (1)
Capacity from 4.2V down to 3V @ 0.4A
1834mAh
1832mAh
N/A (1)
Capacity from 4.2V down to 3V @ 1.0A
1806mAh
1803mAh
N/A (1)
Capacity from 4.2V down to 3V @ 2.0A
1777mAh
1767mAh
N/A (1)
Capacity from 4.2V down to 3V @ 3.0A
1710mAh
1686mAh
N/A (1)
Capacity from 4.2V down to 3V @ 4.0A
1334mAh
1241mAh
N/A (1)
(1) Cell number 3, with the black wrap, was dead on arrival. Assuming that the protection circuit had tripped, I placed the cell in one charger after another trying to reset the circuit. Approximately half my chargers wouldn’t even recognise that there was a cell present, and just showed an open circuit. Roughly half indicated a bad cell or other error. A couple of chargers tried to charge the cell, but it didn’t jump up to 2.50V (or whatever the trip voltage of the protection circuit may be) – the voltage was increasing from 0V upwards. At this point, I put that cell aside.
(2) This is rather a higher value than I would have expected but is no doubt due to the higher than normal initial voltage on receipt of these cells.
(3) As HKJ found, the protection circuit does not appear to have been made with the UR16650ZT in mind – if you set your charger to charge to a voltage of 4.30V, the protection circuit will trip, and the charge terminate, before the charger enters the CV phase.
At a CV setting of 4.27V, the charger enters the CV stage, but doesn’t get down to 1/10th of the original charge rate before terminating. As the charge progresses, and the voltage fluctuates, prior to the current stepping down, the voltage may peak high enough to trip the protection circuit.
At a CV setting of 4.26V, the CV phase got down to approximately 0.2A – 1/5th of the original charge rate.
I was finally able to complete the full CV phase of charging at a voltage of 2.5V.
Construction
As per the above images, the two red wrapped cells have a common mid sized button, while the black wrapped cell has a very small button. Using the cells in series, or in lights with physical reverse polarity protection, should not be an issue. Magnets preferred to adhere to the shoulder of the cell rather than the button, leading me to conclude that the buttons are made from aluminium.
The base of the cell is a metal plate, so wear and tear should not be an issue. The black wrapped cell's base extends further than the two red wrapped cells.
The wrap of all three cells is the hardier vinyl type, rather than the brittle tape style.
Light compatibility
Light
Characteristics
Fits
Functions
Olight M20
Wide tube, spring at head, sprung plunger at tail cap
Yes
Yes
SWM T20CS
Short tube, dual springs
Yes
Yes
Jet IIIM
Wide tube, tail spring only
Yes
Yes
Fenix TK15
Two-piece tube – narrow at head
Short tube, short spring at head
Yes (4)
Yes
Fenix TK11
Narrow tube, tail spring only
Yes
Yes
Eagletac G25C2
Wide tube, sprung plunger at head and tail (minimal travel at the head end), physical reverse polarity protection
Yes (4)
Yes
Nitecore IFE2
Narrow tube, physical reverse
Polarity protection
Yes
Yes
Fenix T1
Light intended for use with two CR123A only
Yes
Yes (5)
(4) Obviously, the width of the cell was never going to be an issue here in terms of the cell being too wide. If anything, there could be issues with the narrow cell leaning over and being out of alignment with the lights contacts. This did not appear to be an issue with any of the light however. However, the cell was an issue in a couple of lights due to it’s length. Both the TK15 and G25C2 seemed to need more force to tighten the tail cap down than the other lights, and I believe that this was because they were tightening down against the battery.
(5) The light flickers rapidly on high mode, and is not as bright as with two CR123A cells. However, this is most likely just down to the reduced voltage of a single li-ion cell, as compared to the two CR123A batteries that the T1 should be run on.
Charger compatibility
Charger
Fits
Functions
4Sevens single bay
Yes
Yes
Trustfire TR-001
No (6)
Yes (6)
Ultrafire WF-139
No (7)
Maybe (7)
Ultrafire WF-188
Yes
Yes
HXY-042V2000A
Yes - snug
Yes
XTAR WP2 II
Yes - snug
Yes
Pila IBC
Yes - snug
Yes
Jetbeam/Sysmax Intellicharge i4
No (6)
Yes (6)
(6) The cell will not sit flat in the cradle – the cradle is a fraction too short – but the cell’s positive button still makes contact with the charger’s positive terminal, and charging will proceed.
(7) The cell will not sit flat in the cradle, and may not make contact with the chargers positive terminal. The cell I tested had a slightly off centre button. Where the button was closest to the side of the cell, it would make contact with the charger. Where the button was furthest from the side of the cell, contact could not be made. On the whole, probably best to assume that this cell is not compatible with the WF-139.
Internal resistance
Cell
Voltage
Internal resistance
Intl-outdoor 16650 #1
3.97V (as received)
195mOhm
Intl-outdoor 16650 #2
3.97V (as received)
195mOhm
Intl-outdoor 16650 #3
N/A
N/A
3.73V (storage charge)
200mOhm
201mOhm
N/A
N/A
AW 17670 #1
3.72V (storage charge)
105mOhm
AW 17670 #2
105mOhn
Best-in-one 17650 IMR #1
3.86V (as received)
80mOhm
Best-in-one 17650 IMR #2
3.86V (as received)
77mOhm
OK, the IMRs are only really a fair comparison in terms of size, not performance, but these are the only cells I have in this size range. I had hoped to get hold of a couple of Eagletac 17670s for comparison, but haven’t been able to get these shipped to the UK.
Edited by: sb56637 on 08/26/2014 - 17:46
Stephen Wallace
 Conclusion
It has been suggested by some that the Sanyo UR16650ZTs currently in circulation as loose cells are some old pre-production cells, and as such do not achieve the cells stated specification. I don't know if this is true or not, but it is fair to assume that all the 'A grade' cells will have been sold to laptop manufacturers, and that the loose cells are at best not A grade stock. This most likely accounts for the capacity of these cells falling somewhat short of the manufacturers minimum claimed capacity of 2100mAh. A rather high internal resistance doesn't help matters, and the protection circuit may be using some energy that a bare cell wouldn't be losing. The protection circuit preventing you from fully charging the cell saps some more energy. You still wouldn't be looking at full capacity, but with an almost 100mAh difference between 4.20V and 4.25V, maybe you could get another 100mAh if you could fully charge these. 2000+mAh is nothing to be sniffed at, even if you were still 100mAh short of what these cells are meant to achieve.
Having said that, these cells still achieve a considerably higher capacity than the 1600mAh we have come to expect from quality 17670 cells. This is despite the fact that I could only charge these cells to 4.25V rather than the full 4.30V. With only a 4.20V charge, these still provide over 200mAh more capacity than a 1600mAh cell. Capacity remains higher through to 3A discharge.
I had not intended to carry out a 4A discharge, as while this falls comfortably within the safe 2C rate we would expect from a quality li-ion cell, the manufacturer's own documentation shows that the cell suffers a lot of voltage sag at 4A. However, other than overall capacity, I had been very impressed with the capacity achieved under 1A, 2A and 3A loads - the 0.2C capacity may have been lower than claimed, but the capacity wasn't dropping off greatly as discharge rates increased. There was a big drop at 4A, as expected, but still a reasonable amount of capacity there.
Capacity between the two red cells remained pretty closely matched from 0.4A (0.2C) through to 3A, with a maximum difference of 24mAh at 3A. Between 0.4A and 2A there is only a 10mAh maximum difference. At 4A, there is a much larger difference of almost 100mAh. As such, I'd recommend sticking to applications that require little more than 3A, particularly if you will be using the cells in series - 4A seems to be too much.
I would love to see A grade examples of these cells, with more capacity, less internal resistance, and a protection circuit that allows them to be charged fully. Wishful thinking, but I'd really like to see a 17mm version with a little more capacity than these. As it is, these cells still give a higher capacity than the currently available 17670 cells, and despite a fair amount of voltage sag, maintain a higher capacity right up to a 3A discharge. As such, I would have to say that these are currently the best high capacity sub 18650 cell available.
Post script
I have contacted Hank at intl-outdoor, and informed him of the issue with the black wrapped cell. Despite Chinese New Year, he responded quickly to my email, and has agreed to send a replacement once the holiday is over. He also stated that despite the different physical aspects of the black cell, it should perform the same as the red wrapped cells – the red wrapped cells are newer stock than the black wrapped ones.
Ouchyfoot
Ouchyfoot's picture
As far as I know the red cells are unprotected and the black are protected.I just got a couple protected (with nipple top) from Hank and they seem pretty good. In fact I ordered two more. I couldn’t fit AW 17670’s into any of my lights…even the Eagletac that claimed cr123 and 17650. These batteries slip into pretty much anything that accepts a cr123. They slide into Quarks as Easy as pie. I really like them instead of stacking up RCR’s. I wish this diameter battery would become more common.
Stephen Wallace
As I stated in the write up, the black cells were an early batch, and the red wrapped cells are newer ones – both are protected in this instance. You can order the cells from intl-outdoor with or without protection, and these cells were all ordered with protection. If you look at the first picture, the red wrapped cells are marked as protected on the wrap; and if you look at the second full size picture, at the cell marked ‘2’, at around 11 o’clock, you can the see the PCB’s strap running along the side of the cell.
sveqs
Last seen: 9 months 2 weeks ago
have you tried Nkon.nl?
