"Petition" to persuade Emisar (Hank Wang) to make a larger version of D18
48 posts / 0 new
lightdecay
Last seen: 2 months 3 days ago
Go big or go home. Look no further, pure brass Haikelite MT03 is still available.
http://budgetlightforum.com/node/66532
It weighs 1450 grams. That is a massive upgrade from the Emisar D18! (pun intended)
21k lumens! It can probably hold turbo for more than a minute.
Bardo219
Last seen: 3 days 7 hours ago
I’d buy anything from Hank
Where would we end up with 3 × 21700? Just increased runtimes?
Dr.Phillip
Dr.Phillip's picture
Last seen: 5 days 7 min ago
So I decided to buy the D18 with custom XPL HI emitter settup:
3 × 2850K
6 × 4000K
6 × 5000K
3 × 6500K
This should give ne better tint than sst20 5000K and better/higher lumen output than sst20 4000K.
If Hank comes out with a D18v2 I’m gonna be so pissed Big Smile (just kidding).
But seriously, D18v2 could have a bit beafier head with more heat dissipation options and either 3×21700 or 4×18650. That alone should make higher output possible.
Also D18v2 should have more emitter options. Like XHP 70.2 high CRI
adam7027
Last seen: 11 hours 38 min ago
Dr.Phillip wrote:
…If Hank comes out with a D18v2 I’m gonna be so pissed Big Smile (just kidding).
XHP70.2 is meaningless even at the highest offered CRI due to huge tint-shift in beam. That emitter is anything but quality light source, unless someone skilled enough dedome each one installed.
Speaking of high CRI, if someone could make a flashlight with 12, 18 (or even more, e.g. 36) pieces of E21A, that could be really something.
Tally-ho
Tally-ho's picture
It doesn’t seem true for the whole XHP70.2 series. zieloczek100 made a review of the EAGTAC TX3G Pro using a Cree XHP-70.2 in a small SMO reflector and the beam doesn’t look as bad as expected. It looks pretty good.
A few of his pictures :
Field shots, camera settings ISO-200, f / 2, 1s, white balance – Fluorescent H
EAGTAC TX3G Pro – TURBO
Emisar D4 – TURBO
Emisar D4 – TURBO
Th558
Th558's picture
Last seen: 8 hours 9 min ago
My FW21 Pro actually looks decent. Greenish yellow corona but apart from that it’s not too bad. I think I don’t notice it much due to the floody beam. With the EC01 and SP33 it was more annoying.
stephenk
stephenk's picture
Last seen: 11 hours 49 min ago
Can I add to the Petition a 1/4”-20 UNC tripod thread on any future versions of the D18.
richbuff
Last seen: 2 hours 20 min ago
I love my D18 vn 18 x W2. I would love to have the next bigger thing in this department. I do not have anything against the lights that other people like that I am not excited about. It seems that some people are against the lights that I am excited about, for all of the same old reasons that have been repeated 47 trillion times.  I like maximum thrust to weight ratio. Added plus is ability to access normal modes in both pocket rockets and shoulder fired rockets.
Please count me in as petitioning Hank Wang to make a larger version of the beloved D18.
My current favs: Nitecore TM9K, Astrolux EC03, Imalent MS03, Lumintop FW21Pro, Nitewatch NSX53, Emisar D4V2 W2, Lumintop FW4a W2, Noctigon KR1 vn 90.2, Mateminco MT07 vn  W2, Acebeam X45, Imalent MS18, Acebeam X65, Imalent R90TS, Acebeam K75 and Astrolux MF05.
Because I like big lights, my flashlightical views lean heavily toward both the extreme bright and the extreme heft.
lightdecay
2 years ago Matt Smith modded a BLF GT with a COB LED.
https://www.youtube.com/watch?v=8_T-YIvWNmQ
I wonder if we will see more flashlights with a COB LED in the near future. If a decent driver was available, maybe it could be used to get more (floody) lumens and much better efficiency from a D18-sized host. Better efficiency would mean less heat and longer battery life, which could make a bigger difference than upgrading from a 14k lumen turbo to (for example) 25k lumen turbo.
I don’t actually know much about COB, maybe the technology isn’t there yet.
Taskulamppu
Taskulamppu's picture
Last seen: 4 days 21 hours ago
Email Hank, he will build you a 16 emitter beast like this (E21A): https://www.reddit.com/r/flashlight/comments/i0u34v/custom_brass_d4v2_mu...
BurningPlayd0h
BurningPlayd0h's picture
Last seen: 6 hours 48 min ago
It really doesn’t have an efficiency or price advantage over many small LEDs.
b3nault
Last seen: 5 days 2 hours ago
I’ll take a d18, but filled with 18 SBT90.2 emitters. Make it as large as it needs to be,
to support as many 21700 batteries that is needed. Heck, I want it full copper too.
Hank, take my money.
lightdecay
Why only 18 SBT-90.2 emitters? At $35 each these emitters would cost $630, but they wouldn’t even be able to put out 100k lumens.
A flashlight this expensive is not worth it, if it is not brighter than Imalent MS18 (100k lumens).
Artiet59
Last seen: 6 hours 15 min ago
But wouldn’t it throw almost twice as far? even though it may ONLY be 75,000 lumens, couldn’t it potentially throw 2200 meters? reflector dependent of course. I mean come one… you wouldn’t pay $2,000 for a 18 x sbt90.2 , 6 × 21700, full copper, 26lb thrower? I would, if Hank made it! And if my wife never found out though it’d be hard to hide.
ps- I got my ridiculous theoretical math from comparing the gt4 to the gt94, and the ms18 to this new Noctigon Coppertron (thats a trademark name i just made up).
Dalamar
Last seen: 18 hours 18 min ago
bmengineer wrote:
You’re listing way too many features that are typically not compatible.
Good flood, and good through.
4-8 cells and USB charging.
More overpowered and a good emergency light.
I think if you want to create an interest list, you should narrow down what you want to capture interest in, and I think Hank might not be the best bet since he typically doesn’t make items just because people asked for them.
You can have good flood and good throw by including 10 or 15 and 45 deg TIR, but the throw will never be super amazing. Likewise, you could have an aspheric lens option, granted the lens would extrude.
I would be interested in a crazy light if it uses SUNLIKE-tier emitters and buck/boost, or at worst, E21A emitters. I don’t like the green halo from E21A and a TIR won’t correct that, so 219b would technically be a step up
I miss the lights with handles lol, I used to use one in the offhand while shooting coons with my rifle, despite the weight the handle actually easier to hold than a light
I only like high CRI. Collection:
Fireflies NOV-MU 21 4500k E21A
Fireflies ROT66 219B SW45 D220
Fireflies E07 219B SW45k (all copper, in mail)
Awaiting release of E07x Pro, only if 219b still stocked.
Emisar D4 (v1) SST20 4000k frosted
Varmint removal (throw):
Convoy M21A C8 ver SST20 4000k (5a)
Convoy S2+ SST20 4000k (3200ma)
CRI test dump https://drive.google.com/drive/folders/1kcl_uOhgfpR4RSsa8F4b-UUVP9mkL6Cr...
Dalamar
in the 600+ price range you just as well ask Silent Thunder to custom for you, probably won’t have a metal body though
Photon Master
Last seen: 12 hours 35 min ago
Jeeze how did I not see this thread before… I have three 9.3’s, two K1’s, a D18, KR4, some D4SV2’s
I love the idea of a massively powerful Hank light. I blew $600 on my Imalent MS18 so I’d happily spend that much for something like this
