BLF triple 21700?
63 posts / 0 new
Tom E
Tom E's picture
Last seen: 10 hours 5 min ago
Seems to have turned out triple 21700's are slightly larger in diameter than quad 18650's, 51.8 mm vs. 50 mm.
The 3x21A will be my third triple 21700 light - Haikelite HK90, WildTrail WT90, and the more affordable 3x21A.
I do like the form factor - still comfortable to hold, plenty of power, both for max amps and/or runtime.
Lightbringer
Lightbringer's picture
Last seen: 1 hour 44 min ago
Make the body an empty can at 52mm or so. Keep the same contact ring on the head/driver. All parallel, so who really cares how they’re situated?
A cheap “speedloader” that’s got a cross or trefoil cross-section in the middle to keep the 4 18650s or 3 21700s upright, and a bottom-with-springs that would have the springs make contact with the cells on one end and with the body on the other end.
One for 3×21700 (shorter springs) and one for 4×18650 (longer springs).
Nb: I don’t mean a full cell-holder or carriage that’d make the assembly any wider, but just a disc-with-springs at the bottom and central spacer/form to just keep the cells upright. Kinda like a big-ass thumbtack but with cross/trefoil pointy-part.
Then you can have the same light take both configs, 3 or 4 cells.
Eg, if I’m remembering right, the SD01 with its 1pc body, has the cloverleaf-shaped insert-with-springs just drop in and snap-fit to stay, vs the Q8 where the cap unscrews and the PCB-with-springs is hard-mounted inside. The former is so much simpler and cheaper, and works just as well if not better (loses both threads and O-rings, as well as another potential for water-ingress).
