4S BMS 30Amp Board Input Voltage
3 posts / 0 new
fluke
Last seen: 5 hours 4 min ago
Hi People.
Got a 4S BMS 30Amp Board.
What input voltage min max will I need?
No specs with it, do I just put 16.8 into it?
Ive searched google but dont see anything.
Barkuti
Barkuti's picture
Last seen: 1 hour 37 min ago
There's no minimum input voltage into the BMS, if too low it will just not work and if too high it will cut-off.
A BMS is a circuit which works as interface between a battery and whatever charges or loads it and so, by itself alone it needs no voltage. The BMS characteristics are chosen to fit the battery or set of cells chosen, with most common values for full charge and discharge of li-ion being 4.2 and 2.5 V per stage. BMSs are built around some control integrated circuit, looking for it on the board and noting down its chip markings will serve to find its datasheet. This should answer between a truckload and a boatload of questions.
The current handling of the BMS is specified with some typical and peak values, usually related with some sense voltage fed on the control chip via the onboard MOSFETs' VGS or some sense resistor. I say this because to me a 30A BMS is something which can work at that current rate, but sometimes I've seen BMS circuits advertised using peak current values.
Hope this can answer most of your doubts.
Sun, 08/09/2020 - 05:39
The human mind, and its programming, is at the forefront of a particular battle of The Light vs evil dark forces. Nearly every human being on this beautiful planet “Earth” has some sort of negative mind programming in its mind. And you better take care of your mind programming, or someone else will in this wicked world.
Please avoid fully quoting lenghty posts, namely with nested quotes. Trim quotes down to the essential. Helps with neatness and legibility. Thanks.
I recommend saying no to Covid vaccine. Listen to your spirit or soul. Innocent
Keanu Reeves may need your help. Join his Telegram channel here.
Sirstinky
Last seen: 10 hours 34 min ago
A 30A bms probably only handles 15A continuous. As was said, the 30A is a peak value. As far as input voltage, the IC runs at 5 volts and the bms has a preset voltage threshold for turning off the output (for 4S like 14.4v?). Input voltage just has to be high enough to keep that from tripping. You also need to supply adequate charging voltage to it.
