Dimensions on the tailcap magnet in a UF-H3?
Got my H3 from DD (finally), and outside of the weaker than expected magnet it is fantastic.
So of course, I want to fix that imperfection. Before I tear it apart though, I want to be sure I can find a stronger replacement of the correct size.
Anyone got dimensions?
18mm x 2.94 mm (thick) Its a strong magnet. I'm not sure you will find a stronger one. Depending on battery length you may be able to put two magnets in there.
Thanks EDC,
When I got the light to work and stuck it to the side of an electrical cabinet it stuck quite well. I was a bit concerned when it slid down my fridge. I think this is more of a reflection of the quality of the metal in the fridge than the magnet.
