Firmware files: ~toykeeper/flashlight-firmware/fsm : changes
There are two main files that are specific to the MF01 Mini (aka Mateminco MT07):
Hardware Definition
Configuration File
WARNING: this is untested… but this should pretty much be the changes that have to happen
Existing PWM hardware def
#ifndef PWM1_PIN
#define PWM1_PIN PB0 // pin 5, 1x7135 PWM
#define PWM1_LVL OCR0A // OCR0A is the output compare register for PB0
#endif
#ifndef PWM2_PIN
#define PWM2_PIN PB1 // pin 6, 7x7135 PWM
#define PWM2_LVL OCR0B // OCR0B is the output compare register for PB1
#endif
#ifndef PWM3_PIN
#define PWM3_PIN PB4 // pin 3, FET PWM
#define PWM3_LVL OCR1B // OCR1B is the output compare register for PB4
#endif
New PWM hardware def
#ifndef PWM1_PIN
#endif
#ifndef PWM2_PIN
#define PWM2_PIN PB4 // pin 3, FET PWM
#define PWM2_LVL OCR1B // OCR1B is the output compare register for PB4
#endif
Old PWM config
#define RAMP_LENGTH 150
#define PWM1_LEVELS 1,1,2,2,3,3,4,5,5,6,7,8,9,9,10,14,15,16,17,18,19,20,21,22,24,26,28,30,32,34,37,39,42,45,48,51,54,58,62,65,69,74,78,83,88,93,98,104,110,116,123,130,137,145,153,161,170,179,188,198,208,219,231,243,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,0
#define PWM2_LEVELS 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,11,13,16,18,20,23,25,28,31,34,37,40,43,47,50,54,58,62,66,70,75,80,85,90,95,100,106,112,118,125,131,138,145,153,161,169,177,185,194,204,213,223,233,244,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,0
#define PWM3_LEVELS 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,3,6,10,13,17,21,24,28,33,37,41,46,50,55,60,66,71,76,82,88,94,101,107,114,121,128,135,143,151,159,167,176,185,194,203,213,223,233,244,255
#define MAX_1x7135 65 // ~113 lm
#define MAX_Nx7135 110
New PWM config
#define PWM1_LEVELS 1,1,2,2,3,3,4,5,5,6,7,8,9,9,10,12,13,14,15,16,18,19,21,22,24,26,28,30,32,34,37,39,42,45,48,51,54,58,62,65,69,74,78,83,88,93,98,104,110,116,123,130,137,145,153,161,170,179,188,198,208,219,231,243,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,0
#define PWM2_LEVELS 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,1,1,2,2,3,3,4,4,5,6,6,7,8,8,9,10,11,12,13,14,15,16,17,18,19,20,21,23,24,25,27,28,30,31,33,35,37,38,40,42,45,47,49,51,54,56,59,61,64,67,70,73,76,79,83,86,90,93,97,101,105,110,114,118,123,128,133,138,143,149,155,160,166,173,179,186,192,199,207,214,222,230,238,246,255
//#define MAX_Nx7135 110
