JoshK's Machine Made Light for the 8th Annual BLF/OL Contest
69 posts / 0 new
Joshk
Joshk's picture
Last seen: 4 days 12 hours ago
I’m getting started with a very special LED. I’ve been saving it for just the right project.
Revered by older BLF members, and discontinued by Nichia, it’s the 219B R9080.
Last night I order it a MTN XP 16mm Copper MCPCB from Mtn Electronics
And to get the design started, I drew an 18650 to scale in SolidWorks.
Edited by: sb56637 on 01/09/2021 - 08:16
Joshk
Joshk's picture
Started.
Joshk
Joshk's picture
I drove to Walmart special for this project item. Unfortunately when I got home and opened the package, the geometry wasn’t the torpedo shape I expected. I guess I’m just not old enough to have actual experience with these things. So instead I will be using online images for my geometry reference.
G0OSE
G0OSE's picture
Last seen: 11 hours 10 min ago
!{width:60%}https://www.dropbox.com/s/acjlfgpv663z5w9/Sup.JPG?dl=1!
Well, at least you won’t have any worries with constipation any time soon! Big Smile
MascaratumB
MascaratumB's picture
Last seen: 4 hours 53 min ago
Subscribed Wink And good luck with the project Thumbs Up
Joshk
Joshk's picture
So this is a pool toy I created earlier in the summer. It is based on real life torpedo geometry I found online. I will be borrowing this elegant geometry again for the current project. I won’t be taking the back to a point though, I will make the front and back symmetric.
Scallywag
Scallywag's picture
Last seen: 4 days 11 hours ago
That’s the LED I’ve been leaning towards for my build as well. I’m thinking sw45k. To help with the decision I’m probably going to throw a 219B in my Thrunite T10TV2 (if I can get it open).
Joshk
Joshk's picture
Yea I nearly sold it but here we go, I found a use.
Joshk
Joshk's picture
I’ve drawn the basic shell so that I can start developing this. It’s no bigger than necessary to get the basic parts inside and have ‘corners’ thick enough to be printable and not break easily.
NeutralFan
NeutralFan's picture
Last seen: 1 day 2 hours ago
Maybe it’s just me, but I can’t see any of your pictures Joshk.
I’d rather use my flashlight around the house than turn on the lights.
Joshk
Joshk's picture
Weird. Ok, so moved them all off Dropbox to my server. Give it a try now.
raccoon city
raccoon city's picture
Last seen: 1 min 22 sec ago
I can see them, and I could see them before.
They're currently being hosted on:
blf.asupgrade.com
(I haven't heard of that site before.)
Joshk
Joshk's picture
I’ll probably get back to this project tomorrow. The A/C in our house went out 2 weeks and nobody has been sleeping good. We thought we had a repairman lined up, but he couldn’t seem to show up or call back. There’s a new company here today and they have been working hard all day long.
MtnDon
MtnDon's picture
Last seen: 4 hours 15 min ago
Ooooff! I’m not sure where you live but there are many areas in the US where I would not want to be without A/C in August. I hope tomorrow is nice and cool inside for you.
Meanwhile, I enjoyed our high of 82F today here in the mountains. Above 80F lasted all of about 2-1/2 hours. Sunny day too. 8800 feet altitude does that.
I plan to get back at my project in a day or two as well; we’ve just been hiking a lot, taking afternoon naps and reading books.
Joshk
Joshk's picture
I’m a lifelong South Dakotan that has been in Arkansas the past 2 years. I’m not used to heat, humidity, or stagnant air. Arkansas has had all 3, plus some heat advisories in the past few weeks. It’s been 80%-98% humidity day and night the whole time. (96% at the moment). And the heat has been in the 90’s every day and 80’s each night. And never any wind.
Joshk
Joshk's picture
Well the crew finished up a bit ago and left. The house is cooling off and drying. What a relief. I don’t even miss the $3800 they took with them when they left. Money well spent.
MtnDon
MtnDon's picture
Thumbs Up
I left a window open too much last night. This morning I ran the split mini in heat mode in the kitchen / dining area for a little. (Solar driven)
Joshk
Joshk's picture
What do you have for a solar setup? Is it lead or lithium?
I’ve been slowly collecting laptop batteries for a solar project of my own in the future.
MtnDon
MtnDon's picture
Two pole mount pv panel arrays with trackers plus a ground mount array facing southish. Outback controllers and inverters. GBS prismatic LiFePO4 cells in 48 volt configuration.
Joshk
Joshk's picture
Thumbs Up Sorry for the tangent. My mind wanddddddddddddddddddd
MtnDon
MtnDon's picture
Mine too Facepalm
Joshk
Joshk's picture
Alright, back at it today. So obviously if I put that MCPCB inside a plastic shell it would overheat and then melt my flashlight. So we need to go metal. Let’s look at those options. This is model is hollow as shown above.
Obviously copper would be best, but at $756 plus shipping that would be a poor choice. Steel for $116 might be acceptable if it were guaranteed my design contained no errors, but there are no such guarantees. Furthermore, all that gets you is a powdery piece of metal. This old SLS printing technology from 1988 has a very rough surface that makes large threads suck, and small threads don’t even print.
So from this pricing I can see the path forward is a hybrid design. With a plastic body, but a metal tip. I may even plan to solder the LED direct to the body on two contacts to avoid the issue of how to attach the MCPCB securely.
Joshk
Joshk's picture
What’s that thing AVE on youtube says about the tip?
The Steel price of $23 is pretty good, but I wouldn’t be able to solder to that. The Brass would probably solder fine, it costs $77. Even so, with shipping and one re-order this might cost nearly $200 in the end, and that’s not counting other parts and time. That’s not a good price either.
CNCman
CNCman's picture
Last seen: 6 hours 6 min ago
Welcome to the RED Zone, mid south is Hot too, maybe worse with little air flow.
Nice drawing and planning Thumbs Up
Joshk
Joshk's picture
The nice thing about doing most of the work at the computer is I can be in the house rather than out in the garage. When I saw my wife hydro-dipping out on the deck I decided to try my hand at it. Silly My hand got covered in paint. But check out my YT play button in red/white/blue Party It has issues, but it’s my first attempt ever.
Then we went in the pool.
CNCman
CNCman's picture
OMG Shocked
Looks like your fingers have been shredded in a blender. Sure that’s not blood ?
raccoon city
Whatever you do, don't turn on the garbage disposal...
Ahhh!!!
Joshk
Joshk's picture
Ha, it does look gruesome, but it’s just red/blue paint and water. I might do this again for Halloween on purpose Smile
lumenzilla
lumenzilla's picture
Last seen: 14 hours 30 min ago
Thanks God.
MRsDNF
MRsDNF's picture
Last seen: 1 month 1 week ago
Thats scary.
Scallywag
Scallywag's picture
My wife agrees, this looks good (from a makeup-gore perspective). I thought I was about to read a post about you dropping out due to some accident. I am glad that is not the gore it appeared to be.
