CNCman's entry to the 8th annual BLF/O-L contest [ Handmade - FINISHED - ]
98 posts / 0 new
Zia
Last seen: 4 months 14 hours ago
Great work
Zee
Serlite
Last seen: 4 hours 42 min ago
This is shaping up really nicely!
Looking forward to seeing all the pieces come together.
kennybobby
kennybobby's picture
Last seen: 8 hours 22 min ago
That’s awesome work—i love to see it come together. How is the gap gonna be eliminated? Guess that big-ass hacksaw got carried away with the plastic…
Now i used to think that i was cool,
drivin' around on fossil fuel,
until i saw what i was doin',
was drivin' down the road to ruin. --JT
CNCman
CNCman's picture
Last seen: 23 min 36 sec ago
Screws and some glue. I may need access to fix something later so its getting some 2 × .4 mm screws.
The gap is a result of not being able to close it while molding it. It will be pulled together with screws. Wink
The fun stuff is yet to do. Getting the head made is going to make or break this project. Smile
Rdubya18
Rdubya18's picture
Last seen: 2 hours 13 min ago
Coming along nicely
Skylight
Skylight's picture
Last seen: 19 hours 57 min ago
Great work. Thumbs Up
Very interesting to see how the plastic can be formed. With a transparent flashlight, everyone can see how the internals of a flashlight work. You will need some batteries with a good looking cover.
Umpi2000
Last seen: 4 days 5 hours ago
This is looking epic
G0OSE
G0OSE's picture
Last seen: 12 hours 39 min ago
Coming along nicely! Thumbs Up
CNCman
CNCman's picture
Thanks everyone Big Smile It’s fun to be here with you guys. Beer
To O’l Lumens and many BLF members who started this forum, THANK YOU !!
Akokot65
awesome work! I love projects like these.
CNCman
CNCman's picture
Here we finish the tail cap complete and mate it to the battery tube.
The gap had to be closed to maintain correct fit. Using JB Weld and closing it in a vice for 24 hrs worked.
Gluing the switch to it’s mounting plate.
Cutting the spring shorter for the 3rd time.
Gluing the switch inside the body.
Hand drilling 4 × .041 diameter holes unequally spaced for 4 × .040 diameter x .25 long pins.
I was concerned the glue would fail under the spring pressure after batteries were installed.
Glued and pined in place.
Mating the tail cap to the battery tube.
Drilling 3 holes with .063 diameter drill for tapping with a 2mm x .4mm tap.
Finished Thumbs Up Learning as you go is a result doing projects like this.
You can only plan a path, doing it requires flexibility.
MtnDon
MtnDon's picture
Last seen: 7 hours 13 min ago
Superb! Thumbs Up
MRsDNF
MRsDNF's picture
Last seen: 1 month 1 week ago
Very creative CNCman. I see a name change in your future if you keep using hand tools. Smile
gchart
gchart's picture
Last seen: 7 hours 59 min ago
Great work!
Ain’t that the truth Big Smile
CNCman
CNCman's picture
Thanks guys Big Smile I started out a manual machinist many moons ago, so maybe the name is not accurate LOL.
Making the Head and the cooling is up next. I just found the right size Hot sauce bottle today for a mold, if it doesn’t break under the heat. Wink
CNCman
CNCman's picture
I do have a question about a “MTN 12mm Momentary Switch (for momentary / e.switch drivers)”
http://www.mtnelectronics.com/index.php?route=product/product&path=25_83...
The driver i’m using to hook it to is,
http://www.mtnelectronics.com/index.php?route=product/product&path=67&pr...
I have and understand the instructions where the 2 wires go for controlling the driver.
I have the non-led switches in hand and just ordered some with led.
. Question My question is, can a lighted switch be hooked up to this driver ? It will need power, I do not know where or the voltage to hook the leds too.
This is for the build, so any help is awesome Big Smile
Here are the options for the driver below.
FET Driver – 20mm model FET20-SS – Zener Mod?: Yes – ~6V LVP – Firmware: Electronic Switch CU.. – Turbo Timer: 120 Seconds
Electronic Switch CUSTOM Firmware Options.
1. Number of light levels: 4
2. Approximate PWM levels of each mode: (1) 10% – (2) 30% – (3) 60% – (4) – 100%
Zener Mod: Yes – ~6V LVP
pinkpanda3310
pinkpanda3310's picture
Last seen: 1 week 4 hours ago
Wow this is some fantastic work, the idea and the creation. Looking forward to the rest. Sorry I’m not much of an electronics guru so i can’t help with your lighted switch question. Maybe this bump will nudge someone else to help out Wink
Rdubya18
Rdubya18's picture
I wish I knew . Still in awe of the black magic myself . Your light is a really cool idea .
grin
Last seen: 1 week 2 hours ago
I have a bit of reading to do catching up on the build threads. This is a cool build Thumbs Up
gchart
gchart's picture
I think ground connection will be shared with the switch’s ground connection. The positive connection will likely get tied right to where the LED positive wire is (in the middle of the driver).
You’ll likely need a large resistor due to having 2 cells. MtnE says that a 36K resistor is included with the LED-outfitted switch. At 8.4 volts (full batteries) and a 2.8 volt drop across the switch LEDs, that’ll be around (8.4-2.8)/36000 = 0.15 mA draw. With depleted cells (5.6 volts) that’s around (5.6-2.8)/36000 = 0.06 mA. That’s a pretty decent range of indicator LED draw.
You could probably also hook up the Switch LED+ connection after the Zener diode (share the same pin a Pos to the MCU?) and you could use a smaller resistor and it’d give you a smaller range of current draw between full and depleted cells. I’d need to take another look if you want to do that.
CNCman
CNCman's picture
Thank You gchart and JasonWW for your help with the switch wiring. You both said the same thing about the resistors and hookup. Thumbs Up I will tackle this soon, with a pre-install test.
But first an update on building the Head and some trouble I’m trying to work thru.
Materials for the stand to hold a Hot sauce bottle I’m trying out for a mold.
After cleaning off the label, I noticed the top of the bottle had to be removed in order to remove the Head from the bottle after molding it.
Scored it behind the cap lip with a diamond glass cutter.
And things began to fall apart.
But it was ok to use taped up.
I was going to cut this one in half and make another one but it did not pass inspection.
I tried a single strip about one inch wide here. Learning what does not work first, LOL Facepalm
So this did not go well, but we learned a few things.
Tomorrow will bring more attempts, never give up, never surrender. Wink
tekwyzrd
tekwyzrd's picture
Last seen: 1 day 1 hour ago
Cut glass with string
Nothing travels faster than the speed of light with the possible exception of bad news, which obeys its own special laws. – Douglas Adams
MtnDon
MtnDon's picture
I have had some success, and some failure, cutting glass with a diamond blade and tile saw. Also with a rotary tool (Dremel) with diamond coated disc. Lots of water. Safety goggles. Cut resistant gloves. Go slow.
Rdubya18
Rdubya18's picture
I have never had success cutting glass . I can’t wait to see how this works out .
MRsDNF
MRsDNF's picture
Bugger. Just make sure its only the glass your cutting. Beer
CNCman
CNCman's picture
Finally getting time for the fun stuff Big Smile
After more failures, we got an understanding what can be done and do that.
The length on the 1.85 diameter needed trimming down to 1.65 diameter, the bottle was for roughing it in only.
The final finishing in this area was free handed.
After molding the 1.65 diameter to size, it was taped to hold it in place.
Here the pipe is taped up to hold it in place on center while the 1.0 diameter is heated and molded, then trimmed and repeat several times until the 1.0 diameter is finished.
Prepping for JB Weld epoxy in all seams.
The holes are for air flow, it is air cooled.
This is part one of 4 pieces of the Head.
Next up will be trimming to length and mounting the Driver and cooling fan inside, and continue working to forward end.
I drew this up on a free 2D cad program for reference only. I could not hold exact dimensions, hense the need for flexibility.
Here is the link for free 2D CAD. Easy to learn the Solid Edge 2D Drafting, I have used it for many years.
https://www.plm.automation.siemens.com/plmapp/education/solid-edge/en_us...
Rdubya18
Rdubya18's picture
That’s impressive.
Scallywag
Scallywag's picture
Last seen: 1 day 17 hours ago
So I hadn’t checked this build thread yet. With my own build nearly complete, I need to catch up on all the other build threads.
I am blown away by this build so far, CNCman. I would never have thought to make a light like this, and I certainly don’t have the knowledge or skill to do these things! I found, in particular, your bending of the copper Battery- current path to be both beautiful and technically skillful. This flashlight is truly art Silly
G0OSE
G0OSE's picture
Very impressed with this so far mate, really good work. Thumbs Up
kennybobby
An artist friend who works in glass told me that soda-lime glass (used for bottles and containers) requires careful heating to reuse.
i once used a hot-wire cutter to remove the necks of some beer bottles to make whisky glasses, but even with that the edges were too rough for drinking. She said they would need stress relief in an oven and even that would be no guarantee to add a lip with a torch without breaking.
The glass used in a lab is a different type and can be cut, drawn, bent and easily lipped with a bunsen burner.
Great work with bending and molding the plastic C-man.
