Hi everybody,
We are glad to tell you that we have listed new products at this month, DC48V High CRI 95+ 270W LED Panel Light Ultra Luminous Daylight White Warm White, good for Photography DIY Camera Video Light, or DIY other LED Panel Light at your home, house, office or other places.
Hope you like our this new products. If you are intested in them, please place your order at our store directly.
Below are the weblinks:
Aliexpress store: https://www.aliexpress.com/item/1005001375839369.html?spm=5261.ProductManageOnline.0.0.15dc4edf3RqVEJ
Amazon store: https://www.amazon.com/dp/B08H5BWJ86?ref=myi_title_dp&th=1
https://www.amazon.com/dp/B08H59PTBZ?ref=myi_title_dp
Ebay store: https://www.ebay.com/itm/283996450821
https://www.ebay.com/itm/184428964179
Season sale Starts on Aug 23, 12:00 AM PT, is coming soon at our store. https://diyledu-home520.aliexpress.com/store/3628166/pages/promotion-20210828.html?spm=a2g0o.store_pc_feedback.pcShopHead_105177(link is external)
We want to tell everyone that we have already listed our new product, SMD3030 LED Panel Light as below pictures at our aliexpress store just now, here is the link: https://www.aliexpress.com/item/1005001375839369.html?spm=5261.ProductManageOnline.0.0.15dc4edf3RqVEJ(link is external)
Amazon store: https://www.amazon.com/dp/B08H5BWJ86?ref=myi_title_dp&th=1(link is external)
https://www.amazon.com/dp/B08H59PTBZ?ref=myi_title_dp(link is external)
Ebay store: https://www.ebay.com/itm/283996450821(link is external)
https://www.ebay.com/itm/184428964179(link is external)
Here is the link of 300*195mm Grille Shape Aluminum Heatsink Heat Sink Radiator Cooling Fin for our SMD3030 LED Panel Light LED Plant Grow Light PCB Boards,
if you are interested in this led panel light, welcome to buy one at our stores.
Warm White 2800K-3200K Testing Report from Factory
Features of SMD3030 LED Panel Light:
1: High CRI Ra: 95+, testing report is RA 97-98.3
2: Color temperature: Daylight White 5500K-6000K(has 500k permissible error), Warm White 2800K-3200K
3: Lumen: 90-100lm/W,20000lm-25000lm
4: Max input voltage of this led panel light: DC48V
5: Max working current of this led panel light: 5A-6A, never over 6.2A, otherwise, the panel is very hot, and led chips will be burned.
6: Material: 2mm(0.2cm)Thick aluminium plate board, it's better for heat dissipation. But we still suggest customers weld aluminum strips as below picture and install powerful cooling fans at the back of aluminium plate for heat dissipation. Please note: it will become very hot when the consumption power reachs to 250W-270W. so in order to increase this LED Panel Light's working life, we suggest customers let it work under 200W if you can not handle with the heat dissipation problem.
7: Size: LengthxWidth: 30cm x 19.5cm. 16x18 in series line, total 288pcs LED Emitters.
8: Application: suitable for Photography DIY Camera Video Light
Parameters of Single SMD3030 LED Emitter:
1: Working Voltage: 3V-3.2V,
2: Working Current: 350mA(0.35A),
3: Power Consumption: 1W.
4: Efficiency: 98lm-99lm/W
5: Power Factor: 0.968
Package include: 1Pc LED Panel Light(Daylight White or Warm White color, it's up to your choice)
Daylight White 5500K-6000K Testing Report from Factory
Below Testing Reports from our customers
________________________________________________________________________________________________________________________
