Crowdfunding of mass model of SunLike bulb (TRI-R)
63 posts / 0 new
SunLike
SunLike's picture
Last seen: 4 weeks 1 day ago
evanh wrote:
Wow, they certainly don’t disappoint. Looking forward to the other CCTs!
I have all of these!
SOL2835 0.5w Without diffuser:
BelMORDOR’s Ламповщик|Lampman
https://t.me/sunlikenews
evanh
Last seen: 1 week 3 days ago
Absolutely awesome.
  • So is that 0.5w per LED?
  • Is that wattage what you recommend for the balance of efficiency, longevity, and output?
  • Still at about 70 lumen/watt?
  • Are these 6V like the 3030? EDIT: I see on your site they’re 3.2V
  • Possible to get them in 2200K?
  • Possible to sell this in 5m flexible strips?
Looking forward to picking some of these up!
lightdecay
Last seen: 2 months 4 days ago
Looks amazing!
Some people prefer Duv to be right around zero (neutral tint), and others prefer it to be slightly negative (rosy tint), especially for warmer light.
Have you heard of this study?
https://cms.cnc-cie.ca/images/documents/CIECNCjoint2015/05_Ohno_CNC_CIE_...
Is it possible to tune these bulbs to also offer variants with negative Duv, say -0.005 and -0.010? This would lower color accuracy somewhat, but people might like the light more.
Tint mixing neutral light of different color temperatures is one way to do this.
https://budgetlightforum.com/comment/1490747#comment-1490747
SunLike
SunLike's picture
evanh wrote:
Absolutely awesome.
60 leds 15w
It is mass, so, it will be in stock ready to shipping
About 75lm/watt in this bulb (with diffuser)
2200k only cob 6w what was produced specially for me by SEL (Smart Eco Lighting co. ltd.)
Only 12×99mm pcb with 3-12 leds http://sunlikelamp.com/index.php?route=product/product&path=80_106&produ...
SunLike
SunLike's picture
lightdecay wrote:
Looks amazing!
I have no spectrometer, but you can find any duv what you want. There’s many reviews of my lamp and leds.
It can be cob sol, cob saw (seoul semiconductor), smd 3030 6v, smd 2835, sunLikePlus, SOL cob without violet, S model with switching
evanh
Since the bulbs are being mass produced, can we still request specific combinations of CCT in a single bulb?
SunLike
SunLike's picture
What CCT?
I know if it will be 2×4k+1×5k = 4200k and it is good spectrum
All another only with big order
evanh
That 4200K option may work. Ideally I’d get as close to 5600k as possible but with lower duv, so I’m curious what something like 2× 5600, 1× 4000 would produce.
Joshk
Joshk's picture
Last seen: 4 days 6 hours ago
It might be a good business move to mix 3000k and 4000k LEDs to create the elusive “true neutral” 3500k bulb. There are a lot of sellers selling 2700/3000/4000/5000k bulbs, but I don’t know of any selling a good 3500k.
I know you are thinking I must be basing this on personal opinion, but the ANSI standard “C78.376-2014” accepts 3500K as the true neutral.
Exerpt:
https://www.nema.org/Standards/ComplimentaryDocuments/C78-376-2014-Conte...
SunLike
SunLike's picture
Exerpt:
I still have no spectrometer =(
Joshk
Joshk's picture
I’ll trade you a 3500k bulb for a spectrometer report of it from my C-800 Wink
Spectrometers may look expensive, but if you get one used, then re-sell it, it’s like a free rental Smile
SunLike
SunLike's picture
I can take mixing spectrums from my helper for free =)
But I really do not need it
evanh
Did this for myself, but thought I’d share it in case the comparison is useful to others:
SunLike
SunLike's picture
There’s RIRERA11 https://t.me/sunlikenews/555?single
(SunLike MASS 11 33$ Ø58×130mm 130grams Δ38° E27/26 e14 GU10 gu5.3/mr16 B22)
and RIRERA9 https://t.me/sunlikenews/628?single
(SunLike10X v.2 (9.5w) + round diffuser 18×3030 6.2v SunLike
27$ Ø68×130.5mm 118grams Δ31° E27/26 e14 B22)
evanh
Added.
evanh
Oooo, you should make a ~13W BR30 replacement. Would love to see that 3500k combo in our kitchen!
Edit: Added BR30:
Edit: In fact, the BR30 is even more suited to this configuration for LEDs. The A19 and A21 bulbs are designed to be closer to omni-directional, while the BR30 is designed for a 90 degree direction beam.
Edit2: If I could buy BR30 in 3500K SunLike 2835 that put out 1000 lumen for under $35 ea, I would buy 6 right now.
SunLike
SunLike's picture
Evanh Smile Thumbs Up
p.s. 5% discount for this man!
SunLike10x v.2 (9.5w) (RIRERA9) also can be 11w if 36 leds
RIRERA11 (can be 9.5w if 18 leds)
SunLike
SunLike's picture
I can not find aluminium body BR30 =(
But I can add reflector if COB led(s)
p.s. use optiPNG to lossless optimise size of png files (after that pngOUTwin for additional ~5%)
Joshk
Joshk's picture
Those are some great sketches evanh, good work!
Did you use Inkscape?
evanh
Joshk wrote:
Those are some great sketches evanh, good work! Did you use Inkscape?
Thanks Joshk, I use Figma for just about everything that doesn’t need more than 0.1mm precision.
Sun]
[quote=SunLike
Here’s an (optimized) png of my SORAA VIVID bulb. It’s a bit thicker than normal BR30’s, so I took measurements with calipers in case it helps to find another body that might fit.
0oklight
0oklight's picture
SunLike, in a year or two years, with the work you are doing in this area, a company is going to try to buy you out in a way that may well sell you short, or worse maybe just take your work and market with a much larger backing fund.
I do hope you are preparing yourself for this.
By the way, subscribed. Future customer.
SunLike
SunLike's picture
Evanh May be something like that?
p.s. I just measured the small one
Ф93×99mm
evanh
It’s close. If there was a way to extend it at the base by 14mm, it’d be about perfect. As is, it looks like it gets thicker too close to the socket.
EDIT: Looks like the max diameter of the recessed fixture is 113mm, so too small for the next size up.
SunLike
SunLike's picture
Just use e27-e27 extender
Joshk
Joshk's picture
I have these E27-E27 extenders from Amazon. They extend the bulb exactly 32.4mm.
SunLike
SunLike's picture
I can add any long here (by nut or washers)
Or by this thing
evanh
Here are both options. I like the idea of risers best, since that gives us the ability to have the LEDs at the same depth within the fixture as a standard BR30. The overlays do show that it might still have a clearance issue though. I’d have to get a more detailed diagram of the standard BR30 fixture to check that clearance without just trying to screw something in.
The extender solves clearance, but also has the plane of LEDs 15mm further from the socket.
SunLike
SunLike's picture
Agro
Agro's picture
Last seen: 2 min 7 sec ago
I’m surprised to learn that MASS15D costs more per watt than SunLike10 with SOL unless one buys 20 bulbs or more.
I guess that SunLike10 is not dimmable but I still find it surprising.
SunLike
SunLike's picture
you mean 10X model?
eXperimental =)
It was born like cheap model with 6w COB led
With SOL led it costs 19$ (was 18$ first time) — http://sunlikelamp.com/index.php?route=product/product&path=59_98&produc...
Real it is 9.5w and when it is hot it is 9w
review here — https://budgetlightforum.com/node/71636
MASS15D have 60pcs 0.5W SOL2835 leds — http://sunlikelamp.com/index.php?route=product/product&path=80_82&produc...
Yes, really it is about 0.3w (with size of crystals)
