Here’s how I put it together. Did I put it together wrong? The top strap kinda slides back and forth. My Skilhunt’s top strap is held in place on both ends of the strap and it’s fits much better. I also like the rubber friction glue on the inside of the Skilhunt strap, really helps it stay put on my head. The ArmyTek headlamp doesn’t fit the the Skilhunt headband though - it’s 1mm narrower and spins around in the plastic holder.
Any recommendations for a replacement headband if the Armytek band just isn’t working for my head? I don’t run around or jump up and down while wearing the headlamp, so I might be better off with standard rubber band material holder than the hard plastic that always bop my forehead when I’m putting it on.
