✌ FREEME - ASTROLUX FT03 Mini OSRAM NM.1 510lm WRGB LED options USB-C 18650/ 18350 Flashlight - ALIVE
94 posts / 0 new
Tom E
Tom E's picture
Last seen: 1 month 2 days ago
Hhmm, not in my notes. Not even sure if the screw holes are compatible to standard MCPCB's. It's probably 20 mm from the looks, but I'd have to check, hopefully this evening.
niajef
so am i correct in saying that OSRAM emitters are just pure throwers, no spill at all? cuz i was comparing this to a regular ft03 with sst40, and its almost the same amount of kcd. and the sst40 is already more throw less spill than my xhp. so the mini with osram might not be the same light to walk the dog with?
Tom E
Tom E's picture
NM1's are all about throw, period. Forget-a-bout lumens, tint, CRI, above or below some line... -- throw. In a reflector light, of course there's spill but not much brightness, and the hot spot is intense, small and can go some distance.
niajef
Tom E wrote:
NM1’s are all about throw, period. Forget-a-bout lumens, tint, CRI, above or below some line… — throw. In a reflector light, of course there’s spill but not much brightness, and the hot spot is intense, small and can go some distance.
hm…ok, sounds like a thicker laser basically…nice
Tom E
Tom E's picture
Yea, we call it a pencil beam. But it's actually a pretty good match for this FT03 Mini with it's deep reflector. The spill area is narrower than most lights. For dog walking, depends. If you are out in some open country you may want to see what's goin on a 50-100 meters out, but if you want to light up an area in close, not a good match.
Dedicated thrower LED's like these have no domes, domes are for losers, uh I mean flooders. The XPL-HI, XHP35-HI, SBT90.2 are all thrower LED's. If we want to turn a SST-40 into a thrower, what do we do? We cut off that dang dome! smile
niajef
well i have a ft03 xhp50.2 for now, it does both, some flood, some throw, so i think this is more suitable for dog walking, but i do still want a thrower light. so between those and the osram nm1, which one is the best? what are the differences?
Tom E
Tom E's picture
Well, it gets complicated. The OSRAM's have a wide variety now, even in white. There's W1, W2, W1.2, W2.2  (these tags are getting confusing...).
The SBT90.2 is relatively new and has high lumens (~5500 max) as well as excellent throw, decent tint even at ~5700K. It's expensive, around $45, can pull 25 amps, has a hugh hotspot, and can be driven by a simple driver (3V FET based) - no pencil beam. The XHP35-HI is a 12V LED, about 2000 lumens max, and available in an assortment of NW tints.
The XPL-HI has been around a while, lower output of ~1500 lumens max, but really like it's beam pattern in NW tints - they are milky white with no tint shift in the beam.
As far as max distance, the NM1 (W1) or newer W1.2/W2.2 (??) are the best, where the ".2" signifies 2nd generation.
niajef
ok, and iirc, w1 is pure throw, and w2 has a bit of spill, right?
Tom E
Tom E's picture
I'm trying to compile all relevant info on the current OSRAM throwers. I want to fill in a lot more, like manu ratings and BLF tested results. This is what I have so far:
Color - Part # - footprint (LED surface) nickname          Max/Pulsed   Peak Output (A)
White – KW CSLNM1.TG – 3030 (1mm²) W1                3/3.3A             4.5-5.0 A
White – KW CSLPM1.TG – 3030 (2mm²) W2                                         7.0-8.0 A
White – KW CULNM1.TG – 4040 (1mm²) W1.2
White – KW CULPM1.TG – 4040 (2mm²) W2.2             6.6/8A             ~8+ A
Red – KR CSLNM1.23 – 3030 (1mm²) W1
Blue – KB CSLNM1.14 – 3030 (1mm²) W1
Green – KP CSLNM1.F1 – 3030 (1mm²) W1                 3/4A                6.5 – 7.0 A
Green – KP CSLPM1.F1 – 3030 (2mm²) W1
Yellow   – KY CSLNM1.FY - 3030 (1mm²) W1
OSRAM Website links
3030 variants
4040 (boost) variants
The W2 has more lumens, less max throw from the W1. The W2.2 has more lumens and maybe about the same throw as the W1 -- not sure of this, but seems like the W2.2 is maybe the best one available.
niajef
Tom E wrote:
I’m trying to compile all relevant info on the current OSRAM throwers. I want to fill in a lot more, like manu ratings and BLF tested results. This is what I have so far:
Color – Part # – footprint (LED surface) nickname          Max/Pulsed   Peak Output (A)
Yellow   – KY CSLNM1.FY – 3030 (1mm²) W1
OSRAM Website links
3030 variants
The W2 has more lumens, less max throw from the W1. The W2.2 has more lumens and maybe about the same throw as the W1 — not sure of this, but seems like the W2.2 is maybe the best one available.
wait it looks like PM1 is the farther throw one?? wth, i couldve sworn it was NM1
Tom E
Tom E's picture
2nd generation PM1, not 1st generation. And again, not sure of this. Actually Hank has comparative throw #'s published for these in a K1, but not sure if the amps are fir the peak throw.
Tom E
Tom E's picture
Artiet59 wrote:
Tom E- I hate to ask so many questions, but did you happen to measure the diameter of the mcpcb? Looks like the ax seller isn’t helping me, and I’m switching my orange cslnm1 out to red, gonna get the led on a mcbpcb from Simon, hopefully. Just not sure which size, I will tear apart eventually so no big deal if you didn’t, but figured I’d ask so I can order it. Thanks again!
OK, just checked - definitely a 20 mm MCPCB. You'll have to work out the screw hole issue (smaller than normal cutouts). If it's a problem, you could always leave them out.
ArtieT59
ArtieT59's picture
Last seen: 9 hours 42 min ago
Tom E wrote:
OK, just checked – definitely a 20 mm MCPCB. You’ll have to work out the screw hole issue (smaller than normal cutouts). If it’s a problem, you could always leave them out.
This is very helpful, thanks Tom! I have a drill press and variety of tools, I will assess the situation once I get down to brass tacks. Gonna find a cheap hot plate, and once I get the CULPM1 from Hank I’ll be doing my first reflow. I’m in the process of seeing if Simon has a 4040 mcpcb only for CULPM1 (that’s why I appreciate you measuring it!) Incase the polarity (?) doesn’t line up when I take off the NM1 from the ft03 mini mcpcb. Any thoughts on this? I will probably need a new mcpcb bc I’ll be going from nm1 to pm1 (3030 to 4040, if I’m thinking right) right?
[FLF] Five Light Friday https://budgetlightforum.com/node/78749
Check out some of my new lights (picture heavy) and quick first impressions of them here: https://budgetlightforum.com/node/77180
My Sft40 beamshots / comparison thread: https://budgetlightforum.com/node/78100
The BLF GT with SFT40 (2300lm, 2700m+ @ 30 seconds!)
https://budgetlightforum.com/node/79561
Tom E
Tom E's picture
Yep, you should use a 4040 MCPCB. Funny, I was emailing Hank tonight about a custom order of a CULPM1 on a 32 mm MCPCB (same as a K1). It's actually gonna be delivered tomorrow.
The FT03 Mini NM should definitely be a 3030. Hopefully they didn't use a 3535 - a 3030 on a 3535 is doable but not the best setup for the LED.
I might have 1 or 2 20 mm 4040's, not sure - can't check now.
niajef
Tom E wrote:
2nd generation PM1, not 1st generation. And again, not sure of this. Actually Hank has comparative throw #‘s published for these in a K1, but not sure if the amps are fir the peak throw.
ya thats where i got my impression from, cuz in the dropdown list of emitter we could choose from, i couldve sworn the 2.1 NM1 was 650kcd while 2.2 PM1 was 600kcd
ArtieT59
ArtieT59's picture
Tom E wrote:
Yep, you should use a 4040 MCPCB. Funny, I was emailing Hank tonight about a custom order of a CULPM1 on a 32 mm MCPCB (same as a K1). It’s actually gonna be delivered tomorrow.
The FT03 Mini NM should definitely be a 3030. Hopefully they didn’t use a 3535 – a 3030 on a 3535 is doable but not the best setup for the LED.
I might have 1 or 2 20 mm 4040’s, not sure – can’t check now.
That is a coincidence about you ordering that from Hank! And it makes me think I should’ve thought forward more and when I ordered my CULPM1 form Hank i should have asked him for one on a mcpcb… (It still surprises me just how much “custom” parts orders Hank does for us in the community, I am starting to learn to just ask him the question because usually he will do it for a modest fee). But, then again i didn’t know the size i needed at the time, and he already shipped my order.. Maybe these are the mistakes people make when they’re learning all of this stuff? perhaps? maybe? LOL. Although I didn’t think about needing an appropriate sized footprint mcpcb until someone on blf mentioned it.. Love this forum for all the help! Oh, and speaking of help, if you DO have an extra 20mm 4040 kicking around, i would be much obliged! I do paypal, of course LOL Cool
Pip
Last seen: 1 day 9 hours ago
How do I get a group buy code? I’ve asked in this thread a few days ago and never heard back. I asked for an EC01 code in that group buy thread several months ago and never heard back on that one either. Am I doing something wrong?
Tom E
Tom E's picture
Pip wrote:
How do I get a group buy code? I've asked in this thread a few days ago and never heard back. I asked for an EC01 code in that group buy thread several months ago and never heard back on that one either. Am I doing something wrong?
Post again if no response. Me (and others) are probably clogging up the thread so freeme may be missing interested posts.
Just post: "Interested, thanks!". Keep it simple, repeat once a day if no response.
Pip
Interested, thanks!
KisaKot
Last seen: 11 months 2 weeks ago
Interested !
jp9mm
Last seen: 1 year 1 month ago
too bad about the aux leds
Pip
Group buy coupon is expired.
freeme
freeme's picture
Last seen: 6 hours 25 min ago
Which model?
1thedeals.comyoutubeAstroluxNealsgadgetsolight
Pip
Osram red beam black body.
freeme
freeme's picture
I need to request from BG again.
Pip
No longer interested. Saw that the convoy c8+ was available with red osram so I ordered that instead. Thanks anyway.
d_t_a
Last seen: 8 hours 27 min ago
Anyone tested the idle/parasitic drain of the FT03-Mini Osram?
I left battery inside the flashlight (I got a white/green/red) for a few weeks, and it got drained to below 3v.
In one of the FT03-Mini Osram flashlight, it killed the battery (drained to 0.0v and tried to ‘reactivate’ the battery but this time, it doesn’t get revived — this battery was a not-that-good quality battery though). On the other FT03-Mini Osram flashlight, the battery drained to 2.9v (this is a better quality battery) and in the last unit, the battery drained to 1.x volts (was able to revive this battery, it’s also a not-branded battery).
some comments: – it looks like “poorer-quality’ batteries get drained to below 2.0v, while the better quality battery (this was an older/used-much VTC4) tested to just below 3.0v when I removed the battery from the FT03-Mini Osram flashlight.
- I measured the parasitic drain on each FT03-Mini Osram, and it tested 4mA!
(for comparison, I measured the parasitic drain of FT03-Mini SST40/XHP50.2 which uses Anduril and has lit-up aux-LEDs (set to ‘Low’), and these use around 0.1mA idle)
Tom E
Tom E's picture
Yikes! 4 mA. Not surprising though. This looked like something someone created new on their own. Just by the choice of MCU made no sense because the majority of drivers we see from China use PIC's and this one is completely different.
Edit: Yep, confirmed. I measured 3975 uA on the OSRAM version, and 122 uA on the FT03 Mini SST-40 version running Anduril. Both have a switch LED on at about the same brightness, but the SST-40 is also running the LED's on around the SST-40. And of course Anduril periodically wakes up to do the LVP checks. It looks like the OSRAM version keeps that 8051 based MCU always on regular power, never sleeps.
This driver has to go.
freeme -- can you mention this to them? This driver has a major parasitic drain problem. It appears they don't put the MCU into sleep when power is OFF. We can't leave a cell in the light for any extended period of time.
A 3000 mAh cell would drain from full in 750 hours, or 31 days. If it was 1/2 drained already, then only 16 days. The FT03 Mini NM1 light drains a cell on standby about 32 times faster than the Anduril based FT03 Mini's.
Facepalm
Zia
Intrested in few
Thanks
Zee
Zia
Intrested in 3.i lost my email from before.thank you
Zee
