Astrolux MF01 Mini Copper is an improved version of the previous version that promises better heat dissipation. Hopefully, through this clip, you will choose a suitable flashlight for your use.
You turn on the flashlight in the turbo.
And it heats up to a temperature of 50c in 3 minutes. It’s very long.
And this means that the problem of this model has not been solved.
If the flashlight really gave out 5000 lumens, then it would warm up in 30 seconds. But that doesn’t happen in the video.
From this I conclude that the power is severely limited before it is required. The same problem was present before.
Yes. It got better
without measuring a luxmeter, I do not believe that it got better
