Any good 16340 Hosts?
31 posts / 0 new
ReManG
Last seen: 5 months 1 day ago
Wanting to make a couple of smaller lights and have a few 16340’s laying around. I would like a smaller host than the S2+ 18350/16340 size, but cannot find any under about $20 for a complete light. Anyone have any ideas or know of any sources for cheaper, decent 16340 hosts?
MascaratumB
MascaratumB's picture
Last seen: 14 min 38 sec ago
Have you checked the On The Road 311 flashlight?
Review: http://budgetlightforum.com/node/73735
On AliExpress you can get it for a price below that!
https://www.aliexpress.com/item/4000623233745.html
jon_slider
jon_slider's picture
Last seen: 11 hours 35 min ago
I cant help with the <$20 limitation
MascaratumB wrote:
On The Road 311
nice host if the operator is OK with the UI and modes
I would consider the Nitecore EX11.2, for a more versatile UI (ramping like anduril)
Geuzzz
Geuzzz's picture
Last seen: 1 hour 28 min ago
Ultrafire 602C?
jon_slider
Geuzzz wrote:
Ultrafire 602C?
wow!
the price is right.. just one mode
Geuzzz
Geuzzz's picture
jon_slider wrote:
Geuzzz wrote:
Ultrafire 602C?
wow!
the price is right.. how about the UI and modes?
Dont know actually, but as a cheap host its great. 17mm driver size, 16mm led size. Rugged anodisation.
Host 8 dollars. Blf A6 driver 5 dollars. And add your favourite led.
jon_slider
single mode
agree, great option for a cheap host
review
MascaratumB
MascaratumB wrote:
On The Road 311
The light is moddable, both the led and the driver. The + of that light is the USB-C charging Wink
But there are probably better hosts out there.
BTW, WildTrail has a stainless steel one being sold in AliExpress.
https://www.aliexpress.com/item/32921071234.html
This is similar to the Alonefire AK9, which is 10€ more expensive.
ReManG
I did see that, looks like a nice light for the money. I just wanted a couple of cheap hosts to burn up some parts bin stuff.
Geuzzz wrote:
Ultrafire 602C?
I missed this somehow, but this is great, thanks, I ordered a couple in one mode, will be perfect. Fastech used to have these as hosts for $5 gutted.
eicca
eicca's picture
Last seen: 19 hours 24 min ago
How might one alter the driver in the Ultrafire 602C single mode to bring it down to something like 5 lumens?
Streamlight ProTac HL - SureFire P2X Fury - Fenix PD35 v2.0 - Fenix PD25 - Sunwayman V11R XML2 6A3 mod - Olight Warrior X Pro - Skilhunt H04
buck91
buck91's picture
Last seen: 9 hours 27 min ago
I just received a 3P clone body from AE. The machining is excellent and even the anodizing looks great- even and polished. If you are interested in a P60 setup. Lumensfactory has 1 cell tubes for E-series lights. Convoy has 18350 bodies, I think Jaxman might also?
Agro
Agro's picture
Last seen: 1 month 2 days ago
What is a 3P?
Could you please link to the clone?
buck91
buck91's picture
Check your PM Thumbs Up
MascaratumB
I am not sure if you are still searching , but take a look “blast from the past” (yeah, Roxane is an “old” brand):
https://www.aliexpress.com/item/1005002372874591.html
https://www.aliexpress.com/item/1005002372613180.html
Lightbringer
Lightbringer's picture
Last seen: 2 hours 31 min ago
Assuming a ’123 will keep a more or less steady voltage, you just gut the driver and stick in the appropriate-value resistor.
The little Thorfire KL02 doodads (also made for ’123s ‘though 16340s will run hot) do exactly that, “bead” type LED and a resistor on one contact-board, that’s it.
https://budgetlightforum.com/node/40412
Some dewd was selling them on fleabay 10 for 20bux or something, obscenely cheap. I got 2 duds in a 10pak, but it was still worth it.
Unheard
Unheard's picture
Last seen: 22 min 13 sec ago
There’s space for a 10mm MCPCB. I’m using an eagtac 16340 in it (short and protected) to have a small lantern.
Smile, you cannot kill them all.
Lightbringer
Yeh, I didn’t want to cook them nor run down a Li cell to nothing, couldn’t find my real ’123s, so I got a set of those 3V Li-based converter cells.
JaredM
JaredM's picture
Last seen: 6 hours 54 min ago
https://www.aliexpress.com/item/4000389793969.html
Thought about snagging this little thing.. but I ain’t got no 16340 cells. Might pick one up if Vapcell T6’s turn up at a reasonable price.
Unheard
Unheard's picture
You chicken.
flightless22
flightless22's picture
Last seen: 8 hours 7 min ago
WOWTAC W1 $19.99
The bezel is glued, besides that it’s a decent light with just the led swapped.
Unheard
Unheard's picture
The new Sofirn SC21 will be slightly more expensive but a whole different beast.
https://sofirnlight.com/products/sofirn-sc21-mini-flashlight-rechargeabl...
Maybe even a S1R competitor.
flightless22
That looks very interesting and the price is reasonable. Thumb size and egg weight is a good decision.
I wish sofirn would go with Anduril 2 or at least make some tweaks for the ramping firmware to move slower for the lower output and faster for higher output.
Lightbringer
Dunno if these were the ones, but someone here was all gaga over these or similar ones. 3bux a pop, go crazy…
https://www.aliexpress.com/item/32857438398.html
Ain’t got any, so dunno from any firsthand experience with ‘em.
Lightbringer
I think I’d need to know first if egg weight is extra-large or jumbo or small or what. I’m not quite sold on it.
JaredM
JaredM's picture
Platypus, chicken, or hen?
TIFisher
Last seen: 14 hours 31 min ago
Very cool. I’m tempted, but for just 11mm extra length, 5mm extra width, and few meager grams of weight…
More output, better runtime (1200mAh 18350), Anduril…the only thing it’s missing is a sweet deep carry reversible clip like that SC21.
I’ll probably snag one anyway because “Sofirn”, and the price is crazy reasonable. TBH, I haven’t been disappointed in one Sofirn product I’ve purchased, and if I was compelled to go down another li-ion cell size rabbit hole, that might trigger it.
TIFisher
…sorry….and no freeloading…maybe this a possibility?
Thrunite BSS bundle
Scallywag
Scallywag's picture
Last seen: 2 days 18 hours ago
It’s cute but I think, between my D25C TI, S1 (original), and V10R Ti+, I’m probably done with 16340s. I’d need a real compelling reason to carry something else in the size class.
Unheard wrote:
You chicken.
Chicken! lmao
Lightbringer
Cheep-cheep-cheep-cheep-cheep!
Yeah, that’s not gonna land…
djmcconn
djmcconn's picture
Last seen: 8 hours 16 min ago
That thrunite deal ain’t bad. That little headlamp is a handy dandy
FBsLights
The Thrunite/Wowtac W1 lights are good budget lights.
I like the driver and UI, but they do need a LED swap.
The bezel is glued but I’ve been able to remove it with some heat and grippy gloves.
Now I need to decide which LED.
I also like the headlights in that bundle linked above. They also need a LED swap. I haven’t opened one of those yet, but I will.
FB
