New Fireflylite T9R STB90.2 / Osram 1x21700 Thrower Preview
141 posts / 0 new
twisted raven
Last seen: 14 hours 36 min ago
Never knew Fireflies (Firefly?) had a second website.
blueb8llz
Last seen: 6 hours 10 min ago
Some quick measurements using 30t on all three lights. All three lights have the sbt90. From left to right. T9r, ft03s, k1vn90.
Brightness doing simple ceiling bounce at turn on:
T9r- 730 lux
Ft03s- 730 lux
K1vn90- 850 lux
Throw measurements 25 feet away:
T9r- 478
Ft03s- 546
K1vn90- 655
This is not a review. Just my quick take on the light. I haven’t played with the light yet. But so far so good. I like that it doesn’t look like your typical flashlight. The head looks strange how it tapers off smoothly until it reaches the body. The tail cap thread was really dry but fireflies did include a small tube of lube. Finish seems well, no sharp edges. Fits well in hand. And weight distribution is fairly even. I’m still unsure about the switch. It’s kinda hard to explain. There’s not much travel on the switch being you don’t need to press down to far to activate it. And there is barely a audible sound when pressing the switch. But because of the short travel, the switch takes a bit of pressure to press down. Not hard at all, but just different. You guys will see what I mean once your light arrives. Or maybe someone can better explain this.
Pavlo
Last seen: 9 hours 31 min ago
Nice to see the T9R side by side with the K1.
How do they compare?
Kona G
^ +1
will34
will34's picture
Last seen: 4 hours 19 min ago
Thanks for your impressions, how do they compare heat wise? From the shape of the lights I’d assume that the T9R would have the most efficient heat management, and that the driver would create less heat compared to the fet ones.
Jimo
Last seen: 3 weeks 4 days ago
Is this about the store Brayn Gear. If it is BEWARE. Brayn gear is not on the level. Check out the ROT66 they have in custom lights  They have arot66 what they are calling a S50. The light is listed for 219 dollars on sale for 77. Ask them why its a  219 dollar light. Then look at  Specifications . Its the old bait and switch.
Jimo
adam7027
Last seen: 1 week 5 days ago
Pavlo wrote:
I’m thinking the same thing, Quad Thrower. Hopefully will be compact.
It shouldn’t. Because it is a thrower.
FireFlies, please, this has to be a quad SST-20 95CRI / quad Osram thrower Party
Please target above 300 kCd intensity with the SST-20 95CRI option.
twisted raven
I’d like something around the size of the TN40 or perhaps a little bit smaller. 4,000 lumens and 6-700kcd with good heatsinking for at least 3-4 minutes of sustained turbo.
Chicken Drumstick
Last seen: 6 months 1 week ago
lol, nothing too unreasonable then Big Smile
gchart
gchart's picture
Last seen: 6 hours 59 min ago
My review of this bad boy is done! Check it out over at 1Lumen.com
PSA for those that don’t read my review: do NOT use long protected cells
Glowbug
Last seen: 1 month 1 week ago
Great review! I have the exact light except in black. I put a protected battery in the tube to compare length. I saw it was to long for my liking to screw the rail so on. Very glad I backed out especially after reading the review with the resistor damage by crushing. It specifically says unprotected cells for a reason.
I own several Fireflies, and this one is incredible when you fire up the turbo. For a one called light, it amazes me with its output!
gchart
gchart's picture
Ok, an update on the “long cells” situation. I noticed a sticker on the accessories baggie that says “To fit 77mm 21700 remove tail spring put it into tailcap.” So I take that to mean if you’re going to use long protected cells that you remove the tail spring (pry it out with small needle nose pliers) and leave the already-installed spacer in the tailcap. Note that that means there’s nothing holding the spacer in besides pressure from the battery and the small driver spring. This did allow a long protected USB-C charging cell to be used. But then there’s not enough spring travel to use a non-protected cell. You should pick whether or not you’re going to use long cells and stick with that decision because removing and installing that spring isn’t very fun.
twhb
Last seen: 5 months 1 day ago
Is it just me or do SBT90.2 lights tend to have a second, inner hotspot? I’m noticing it in beamshots of the Fireflies T9R and the Noctigon K1, there’s the medium-small hotspot, then another, tiny circle in the center of that that’s quite a bit brighter than the rest of the hotspot. Can somebody with one of these lights confirm or deny?
The_Flashaholic
The_Flashaholic's picture
Last seen: 2 days 18 hours ago
Is it just me or does the OSRAM LED just eat battery charge like crazy?
My 4K Lumen Whore Reviews (MS18, X70, MS12, DX80, X80-GT, X45vn etc) - http://www.youtube.com/c/FLASHAHOLIC_TV
ggf31416
Last seen: 4 hours 27 min ago
I don’t know about this flashlight in particular but the OSRAM 1mm^2 are very inefficient at high current compared with the 2mm^2 or bigger LEDs. They are basically a better XP-E2 that won’t die as easily, but you wouldn’t expect a XP-E2 to remain efficient on turbo.
The_Flashaholic
Output and voltage drops significantly over 10 mins, even the tint changes
SKV89
Last seen: 4 hours 34 min ago
dotBLF
Last seen: 5 months 12 hours ago
*I sent my copper E07 back to Jacky in the US address for fixing because 3 things were broken and wrong and I am still being ghosted by him. I repeatedly messaged and emailed FF and Jacky, and always got ghosted. 2 years at this point and over $100 down the toilet. DON'T BUY FIREFLIES OR ANY OF THEIR NEW BRAND THEY ARE A BAD COMPANY. Do not do business with them. Buy from better people and companies.
BurningPlayd0h
BurningPlayd0h's picture
Last seen: 19 hours 28 min ago
A lot of lights with the 4040 pad White Flats are driving them at 6A+, that’s going to drain any cell very quickly.
sarge12
Last seen: 1 week 4 days ago
I found out the instructions for getting to advanced UI were different for me…click 10 times and hold the instructions say. For me it was click 10 times and hold…10,000 times. It takes that many to succeed for me with my spinal cord damage. It was ridiculous how many attempts it took. I will likely need a new switch soon.
