After baking my trusty P7 last night, I was trying to improve the pictures from my iPhone and I happened to shine one of my flashlights on the P7 in low in an attempt to keep the flash from going off. This is what came up:
I had heard of using hand in front of the lamp, shining it on a fan or showerhead, but never heard of this. I tried it on several other lights and got the same thing, but only on some and usually only in low mode. Image appears on the iPhone preview as well as in the final picture:
I'm not even slightly bothered by PWM but it is very noticeable on the camera screen - on any camera I've tried. I've not seen it in the actual pictures though.
the easiest way to detect PWM is not with hands or white walls but with the light itself. in a completely dark room shine in any direction. look at the beam path from the side. then begin to move the arm (with torch in the hand) up and down in vigorous waves. continue to look at the beam (Not into the beam! ouch) from the side. The faster you wave/move/shake your arm, the better.
i am not sure if iTP A3's PWM is considered high-frecuency. but i can readily see that it's there.
When I saw the first picture, I thought you had the light resting on some display paneling like used in stores that allow the hangers to be moved into different positions. I was trying to figure out what was wrong with the picture!
Nope... I like the undetectable PWM levels of the Brinyte ... but can hear the PWM if I hold it close to my ear... maybe one could use an electronic guitar tuner to get the Hz numbers?
I'm with you, I've never noticed PWM visually unless I was looking for it...ie shine it at a fan, or at night when I turn the faucet on. I've never understood why some people are so upset about it, maybe I'm just not getting it...do people actually see the ocillation with their eyes, while not testing for it? I understand the buzzing can be annoying however.
