KDLitker C21 XHP70
What do you guys make of this?
http://kaidomain.com/KDLITKER-C21-Cree-XHP70_2-3600-Lumens-5-Mode-LED-Flashlight
Had my eye on it for a little while, thinking of pulling the trigger soon, probably a 4000-5000K version. Any potential issues I should consider? Still a relative newb with LED lights.
Up. Any info?
I would like to see the mode spacing first. Also some info on thermo regulation or timed stepdown.
It’s a boost driver with a xhp70.2 so it will heat up fast. Current is limited to probably 4.8 amps to the led. Probably temp regulated?
In case someone is still curious. This dude, Weerapat Kiatdumrong, likes it. If you read through the comments below his video: Sofirn C8L xhp50.3 vs Kdlitker C21 sst70 vs Convoy M21A xhp50.2 vs Mantaray C12 sft40 - YouTube.
Thanks for the youtube link. He goes into more detail of C21 and compares with other C8 style flashlights here: Understanding C8 flashlight series: Convoy C8+, M21A, Mantaray M45, Kdlitker C21, Mantaray C8.2 - YouTube
Some interesting specs for C21
Smaller than M21A almost same size as C8.
Uses 21700 batteries
fits 22mm driver
C8 sized reflector.
:+1:
It’s not going to throw well, have a nice UI, or be generally useful and will need a fast step-down. It isn’t tactical, and, well, just doesn’t have much use for me. Even the HI .3 version will disappoint.
