This is how the star is made.
Because I built in some tolerance, the die is focused at infinity when the slider is still 12mm short of the backside.
So when the slider is fully retracted, the focal plane of the lens is 12mm in front of the led, and the die projection is out of focus, creating a fuzzy larger spot instead of the smaller sharp square of the focused die.
So I positioned a cutout of a star (made from the lid of a coffee tin) 12mm in front of the led, which is sharply imaged at infinity by the lens, and because the led is only little out of focus, the throw is still not completely ruined (although I think it went down from 4Mcd to just 1Mcd).
Of course for maximum performance of the lamp, the cutout must be rotated out of the way.
If I find the patience I may have a go at a batman cutout, but it must be tiny, and the metal is tough.
That is amazing, very well done djozz
Now that is thinking outside the box ! I never thought a Fresnel lens could do that !
You could do a Batman thingy in the clouds too.
No doubt this years competition is heating up BLF has other forums beat easily
Think outside the box too long , cannot find your way back in.
Necessity is the mother of invention and the father is creativity.
Never give up, Never surrender. Make someone Smile today.
I tried a bat stencil, sawn out of thin aluminium with a fret saw, but I made it too big, the edges of the wings do not receive enough light so they appear not sharp.
So it must be made tinier, not sure if that can be done nicely with a fret saw. And I’m not sure about batman either, maybe I will end up with something entirely different
Jeff51 just posted about a batman projection contraption that uses a 100,000 lumen Imalent flashlight as a light source, and a 25cm fresnel lens with fairly long focal length. Pretty cool too, but not as silent, and maybe a bit less throwy than this one. https://budgetlightforum.com/node/75196
Tnx.
Today I got the 14AWG wire in so I could finish the battery carrier. I chopped the front section off the flashlight head 4mm above the shelf and sawed two grooves in the remaining rim to lead the ledwires to the side. Had to ream the holes in the shelf to 4mm diameter for these quite massive wires. Smoothed everything with sand paper so there were no sharp edges to cut into the wires. The wires were fixed in position with a good bit of kapton tape, does not look extremely profi but you are not going to look inside the lamp daily.
In the picture I show the old 18AWG wires too, so that you can see that 14AWG is a whole lot thicker.
I was lucky because with a 40T at 4.12V I measured 19.85 amps now, precisely what I was hoping for
So now that the battery tube was shortened, I could check the maximum flood setting of the lamp, with the slider towards the lens with the battery tube touching it.
In the picture the flood looks a bit less wide than in reality because of the wide field of my phone camera. Trees are at 25 meters as always. (it looks like I borrowed Flahoholic’s van for the beamshot )
Nice beam djozz. Ever have trouble finding a car park?
Not sure what you mean, but I do not have a driving licence, never needed one over here. (I can park a 20 meter steel barge though)
I guess MRsDNF was referring to your “spotting light” to spot a place for a car! It guess it could apply to the barge too
Speaking of which, ships often have great spotlights, my cycle trip to work is along a small part of the Amsterdam port and I’m always jealous of those marine mirror lights. They cost a fortune though..
Yes, quite the modest LED and optics swap with a driver bypass
MRsDNF wrote:
Nice work bench. Looks like your almost finished.
I could not get away with working on my dinner table. I have an Ikea Bjursta wall-mounted drop-leaf table next to my PC desk. It gets a bit cramped sometimes (about 90×50cm work area), but I quite like it. And it allows me to conduct mid-project research on BLF by simply turning in my computer chair, when I inevitably bugger something up
Throwtest
For who is into throw distance as unit (distance at which the illumination is reduced to 0.25lux AKA moonlight level), that is 4.36 km.
My Extech LT45 over-reads a bit, the Tasi 8133 makes it 4.24 Mcd but that may be under-read again. Let’s agree on rather throwy
(I do not dare to use my Mobilux classA luxmeter too much lately because the cable-connection to the sensor is rather worn-out and fixing it will require a completely new calibration as well, which will cost me 300+ euros)
Throwtest
For the Americans, 4.36km is about 2.7 cheeseburgers per bald eagle miles
Would These parabolic reflectors be appropriate for making somthing like this ? It doesn’t look very expensive. If I understand correctly the short focal lenght means that all light would be collected (expect in center), also it would not produce chromatic aberation as opposed to the fresnel lens.
those are uncoated aluminium reflectors, good for focusing sunlight for heating up stuff, but how is the light loss, and are they optical quality? If yes, they should be fun to make a recoil thrower with
I’m very impressed by the optical performance of these budget plastic fresnel lenses btw, the throw per surface area is very similar to the GT reflector. What helps is that the light source is small and centered (as opposed to projecting an image i.e. a slide which is a large source), the fresnel rims are only maximally optimised for light coming right from the focal point which is the case with a led.
Throwtest
Excuse my ignorance on these calculations—i see how you calculated the luminous intensity in candela, but i struggle to understand how the Luxmeter sensor area or solid angle come into play, or if they do? Does the sensor area not matter?
If the sensor area were known, would it be possible to calculate the lumens of the beam?
Now i used to think that i was cool,
drivin' around on fossil fuel,
until i saw what i was doin',
was drivin' down the road to ruin. --JT
Throwtest
I measured the luxvalue in the hotspot at 12.33 meter, then calculated that back to 1 meter to get the candela-value.
I’m not sure what “solid angle” is, and the sensor area does not matter as long as it is more or less uniformly lit, as is the case because the hotspot is way larger than the aensor area.
Thanks.
BLF Member Map, add yourself
My 7th Annual contest entry My 6th Annual contest entry My 5th Annual contest entry My 4th Annual contest entry
My DBSAR inspired SRK lantern hand made mod
This is very cool…. something to think about
link to djozz tests
Cool!
link to djozz tests
The sky is the limit
Looks pretty good actually!
My Youtube channel: Alllightson Reviews
My 7th Old lumens contest build: Matainvoy ML18S, Built video
My reviews: Sofirn SP31 V2, Nightwatch NI40, Sofirn C8F 21700, Brinyte WT01, Sofirn SD05,Ti AAA keychain, Sofirn SP33 V3, Skilhunt M150
My Youtube video-reviews: Brinyte WT01, Sofirn SD05, Ti AAA keychain, Sofirn SP33 V3
- LEDs & Other Stuff - - UI CheatSheets - - CRX Flashlight Builds - - CRX Stuff for Sale -
Good effort djozz.
djozz quotes, "it came with chinese lettering that is chinese to me".
Tnx.
link to djozz tests
WoW
The beams are really awesome
Regards Xandre
“The outside received a base-paint first, and then after some slight sanding, bright red!”
I missed the last update from a few days ago but “Wow, nice work, sir!” (Mooi rood is niet lelijk, toch?)
mooi rood is niet lelijk herinner ik me uit de jaren 70 volgens mij, zegt iets over je leeftijd
link to djozz tests
link to djozz tests
MY REVIEWS THREAD /// My Flashlight Collection ///
Mods: 1 / 2 // TIR: 1 / 2 // Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 /// My Review's Blog (PT) /// OL Contest 2019 /// OL Contest 2020 /// GIVEAWAYs: 1 / 2
link to djozz tests
Old Lumens Contest 2020 - Hand-made light category
ZL SC62(w) | Jaxman E2L XP-G2 5A | Purple S2+ XPL-HI U6-3A | D4 w/ Luxeon V | RRT-01 | Purple FW3A, 4000K SST20 | Baton S1
Boruit D10 w/ Quadrupel Fet+1/Anduril | EagTac D25C Ti | DQG Slim AA Ti | Jaxman E3 | UF-T1 by CRX | Olight S15 Ti | Nitecore EX11.2
L6 XHP70.2 P2 4000K FET+7135 | Jaxman M8 | MF02 | Jaxman Z1 CULNM1.TG | Blue S2+ w/ ML Special | Thrunite T10Tv2
Supfire M6 3xXHP50.2, Sofirn C8F, Unfinished: Sofirn SP70, IYP07/Tool AAA hot-rods, Jetbeam E3S
Others: Nitecore EC23 | Nebo Twyst | Streamlight ProTac 1AA | TerraLux LightStar 100
Very cool
Holy spotlight … Batman
Throwtest
link to djozz tests
Outstanding!
Great work, once again!!
cheeseburgers per bald eaglemilesOld Lumens Contest 2020 - Hand-made light category
I could go for about 2.7 cheeseburger right about now!
Where did I put that bald eagle?
How to Post Images on BLF // Many knives for sale (USA only)
How to move a thread // WTS Brand New Timex Expedition Vibe Shock Camo Watch (USA only)
So much throw, nice work!
link to djozz tests
link to djozz tests
