I’m not sure if this is the most appropriate place for this question. My apologies, if not.
I am looking to buy some Lee filters for take some green out of a few LEDs. It seems the Zircon filters are made for this color correction with LEDs, but take more lumens.
Which series of filters from Lee do you use/recommend? The 240 series or the 800 series?
I probably won’t be putting them on anything getting too hot, but I’m also wondering about peoples’ experience between these two series in their efficacy in fixing tints.
Go with Lee Zircon. The regular ones will melt and distort.
As for how much light is filtered, it depends on how much green you want to remove. There’s almost no way around it.
I have the 805, and I find it doesn’t make a big enough difference. Only works on LED’s that already look pretty good like 219C.
I typically use the 804, and sometimes even the 803.
I have used optical adhesive glue in the past, but I don’t recommend it as it becomes a permanent fix.
If there is an option to squeeze it between a lens and optic, that works well, but you want to avoid gaps of air in between.
The best solution I have found to date that works very well is to use double sided tape. On my zebralights, I install it right on the top of the glass.
In a light where you can unscrew the bezel, I install it underneath. Hardest part is to avoid fingerprints on the tape.
Nope, usually limited by width of tape. Just use a rectangular piece along the center. If you avoid placing finger prints, its barely noticeable and has no impact to the beam.
