Need zanflare F2 switches
I have two that have failed now.
Can anyone link me to some good replacements?
I tried and ordered what I thought would work but they didn’t fit correctly.
Thanks
Your problem is with the switch or the PCB?
I was looking to the switch of my F1 (not sure if identical to the F2) and it is similar to a Omten switch, like those used in Convoys.
The PCB is samller in diamter though
Its the switch. I can use a paperclip to test, turn it on and cycle through the modes.
Thanks
Well, if they are similar to the one in the F1, I guess these will serve: https://www.aliexpress.com/item/32685050264.html?spm=2114.12010612.8148356.1.703f6df0DpnlEa
Here is my disassembling of the F1, where you can see the switch, down, in the red board:
thanks
