Fireflies NOV-MU 21*Nichia E21A mule 1x21700 Flashlight --in stock
Update: (2021/01/06)
Fireflies NOV-MU is available in stock.
Product link:
Firefllies NOV-MU
OP from 2020/11/01
“-+Features:
• 21* Nichia E21A mule; with RGB Aux Leds
• Max output 5500-lumen
• Battery type 1x21700 / 18650 (65mm to 76mm)
• Built-in USB Type-C 2A fast charging
• High efficiency digital current regulated Buck driver , 6A CC
  • FET; Efficiency > 93%
    • Made of 6063-T6 aluminum Alloy, Type III hard anodizing
    • Heavy duty built-in Magnet in tail
    • Ultra Clear AR Coating Glass lens
    • Size: 4.48’’ x1.26’’ x 1.06’’ /
    114*32*27mm
    • NetWeight: 108 gram
    • UI - open-source Anduril firmware
Application: High CRI Photographic supplementary light ; Indoor light ; Portable reading light
Light diffuser
Short body will be produced later
Note : The photos from Prototypes do not represent the final mass-production products!-“+
Reserved
Now this looks interesting…
What color temperatures will be offered?
Man I never knew E21As were that tiny.
I’d offer a frosted lens as an option (or default), E21As have terrible tint shift, even if it’s a smooth transition with a mule it’s still quite noticeable, and potentially problematic for photography.
I would definitely be very interested in this! In addition to the question above, would you also offer tint mixing?
Also with this being a mule, do you have plans to release an E21A thrower of some sort? There aren’t a lot of E21A throwers on the market yet.
Good design Fireflies, from info so far, I’d buy.
ETA?
Finally something really interesting. In.
Nice. Definitely interested.
Interested !
4500K — Mass production.
We have some samples in small quantity available, 2700K / 3000K / 4500k / 5700k
should be available next week
Yes, E21A thrower has been in progress already, final sample should come out next month
Nice to see more manufacturers using E21A. I will pass on this one because I don’t have use for mule, brightness decreases too quickly within a few meters without a reflector.
Jack stepping it up! Great to see this!
Interested
Lovely to see this,I am enthused.
Is Fireflies custom programming Anduril for each of these lights?
Sign me up for 2000k!
