Fireflies NOV-MU 21*Nichia E21A mule 1x21700 Flashlight --in stock
304 posts / 0 new
Rayoui
Rayoui's picture
Last seen: 22 hours 56 min ago
The_Flashaholic wrote:
Very well but even the Adanced UI for us is being butchered. Extra taps for calibration and difficulty in releasing at chosen calibration, i.e 3 blinks to Calibrate number of steps, my NOV-MU only blinks twice! And only being able to access Turbo after ramping to max, get out of here!!!! Ok there is a momentary turbo but who the hell is in the middle of a dark forest with a flashlight turned off. Even in a tent hearing a strange noise outside you’ll want to start on a lower level first so you don’t blind yourself or others.
Simple UI is still too powerful for muggles so you have to learn how to program a lower level which kinda doesn’t make it a simple level.
Tbh an Andúril flashlight was about ramping and power, now it starts in stepped mode by default and Turbo is all but defunct.
If TK makes it impossible to turn the light off from Turbo, which some of TK’s creepy brown noses back up, this once legendary UI will be finished.
I don’t have any of the issues with Anduril 2 that you’re always going on about. I had zero difficulty programming any of my Anduril lights, which have all been upgraded to Anduril 2. The changes to turbo are a preference. You may not like it but many others do, including the person who wrote the software. It has nothing to do with brown nosing. You are just taking your frustration about tiny issues out on others for seemingly no reason.
It’s open source software. If you don’t like it, change it. Complaining about it day in and day out doesn’t do anybody any good.
Lux-Perpetua
Lux-Perpetua's picture
Last seen: 10 min 56 sec ago
Is there any source for the config files of the new FF models (NOV-MU, E12R, T9R, T1R)? Maybe I overlooked something but I failed to find them here:
https://bazaar.launchpad.net/~toykeeper/flashlight-firmware/anduril2/fil...
clientequator
clientequator's picture
Last seen: 1 day 15 hours ago
I saw that the firmware is on the github, maybe it will be merge later? https://github.com/loneoceans/lume1-fireflies
Pavlo
Last seen: 9 hours 11 min ago
UI question for Anduril 2 pro’s,
From lockout mode, manual says that 1H gives you Moon, and 2H gives you Low.
Both 1H and 2H give me the exact same output. Is 2H programmable? How?
Thanks
Rayoui
Rayoui's picture
2H in lockout will be the higher floor of the two ramp modes. So if you use smooth ramp mode and want a higher 2H momentary in lockout, set the stepped ramp floor level higher. Alternatively, 2H from lockout will use the manual memory level if it is set.
gchart
gchart's picture
Last seen: 7 hours 34 min ago
Rayoui beat me to it! I was going to say that the text-based manual describes that as such:
Lockout mode also doubles as a momentary moon mode, so the user can do
quick tasks without having to unlock the light. The brightness in
lockout mode has two levels: – 1H: Light up at the lowest floor level. – 2H: Light up at the highest floor level. (or the manual mem level, if there is one)
Lux-Perpetua
Gosh...I was way too late. Big Smile
You can set different floor levels both for stepped and smooth ramping, i.e. you can program a higher floor level for either one of these mode groups. 2H from Lockout mode will use the higher floor level whereas 1H always uses the lowest possible floor level.
Pavlo
Thanks guys. I will give this a try. I have it currently set on hybrid memory and still getting the same output. Will try manual memory and see if it works.
The_Flashaholic
The_Flashaholic's picture
Last seen: 14 hours 7 min ago
I measured way over 5200 lumens for the 4500K but 40T got me more power than a 30T, are the LED’s gonna turn blue soon!
My 4K Lumen Whore Reviews (MS18, X70, MS12, DX80, X80-GT, X45vn etc) - http://www.youtube.com/c/FLASHAHOLIC_TV
gchart
gchart's picture
I’m testing the 4500K NOV-MU and believe it or not the throw is exceptional. It punches out there by brute force. It measures no where near the claimed 5200 lumens.
Ohh… so when you originally said “no where near the claimed 5200 lumens” did you mean that you measured higher? Usually saying that implies that you measured lower.
SKV89
Last seen: 6 hours 55 min ago
That’s what I thought he meant too.
I measured 5155 lumens in a lumen tube. Lumen tubes measure lower for ultra wide flood lights because it doesn’t capture the stray spill. Since he measures with an integrated box, it should capture even the farthest spills. I estimate actual lumens should be 15-20% higher than what I measured. Would be interesting to see what Flashaholic measures.
SKV89
FF’s 22430 battery is MIGHTY IMPRESSIVE!!! It measures 2,112 mah whereas the much larger Acebeam 26350 mah measures 2,111 mah, which is as high as the 26350 format gets.
The_Flashaholic
Ironically the Max Ramp measurement was under spec
The_Flashaholic
Actually the ANSI measurement is bang on in a 22C room. I tend to highlight turn on lumens.
There’s very noticeable flicker under 10 lumens or so
Rayoui
Rayoui's picture
I had a strange issue with one of my NOV-MUs. It was acting very bizarre after a cell swap. Aux LEDs wouldn’t work, modes were all wrong and it kept wanting to going into full turbo with a loud buzzing sound coming from the driver. I just did a factory reset and now it seems to be fine.
Something must have gotten corrupted somehow during the cell swap. Anyone else experience anything similar?
Tom E
Tom E's picture
Last seen: 14 hours 47 sec ago
Rayoui wrote:
I had a strange issue with one of my NOV-MUs. It was acting very bizarre after a cell swap. Aux LEDs wouldn’t work, modes were all wrong and it kept wanting to going into full turbo with a loud buzzing sound coming from the driver. I just did a factory reset and now it seems to be fine. Something must have gotten corrupted somehow during the cell swap. Anyone else experience anything similar?
Hhhmmm, sounds familiar, like maybe the fuses aren't set correctly. Oh boy, someone should check what the fuses were programmed to. I had similar problems with the early Q8/Narsil prototypes. Turned out the power spikes the driver gets when installing a battery, tightening up the cap, were causing the MCU to glitch. Think it was the brown out detection (BOD) fuse setting - had to enable it (https://www.engbedded.com/fusecalc/).
On page 19 here of the ATtiny85 datasheet talks about it.
azdesertdog
Last seen: 2 weeks 6 days ago
I received my E12R 2 days ago, seems to be decent light, easy to hold and work with and has a lot
of functions however, I am disappointed with the light output. I ordered and received the XPL2 HD 6500
emitters and while it does put out some light, it pails in comparison to my MF01MINI, my Lumintop EDC18,
my FT02S with the XHP70.2 6500 and, has even less output than my very old Skyray 6XT6.
Either the 12,000 rated lumens of this item are grossly overstated or, as an example, the FT02S must
be putting out a lot more because, as you can see, it totally blows the E12R out of the water.
I know this is a very unscientific test but, I took some average readings from my LX1020B Lux meter and the
results are as follows, These were all obtained from a distance of 5 feet, all with fully charged
batts and Samsung 40T 21700’s in the E12R the MF01MINI and the FT02S.
Fireflies E12R = 5000 lux
Skyray 6XT6 = 6000 lux
EDC18 = 10000 lux
MF01 MINI = 19000 lux
FT02S = 31000 lux
As I said, it’s a nice piece that does output some decent light but, since both it and the
FT02S are stated to put out 12,000 lumens, Fireflies must be very generous with their
lumen ratings.
Has anyone else found this to be the case?
Tom E
Tom E's picture
It's Anduril 2 so probably ships in "Simple UI" with a max of 6 amps. See the detail specs: ff-light.com - E12R page
Pavlo
be putting out about a lot more because, as you can see, it totally blows the E12R out of the water.
EDC18 = 10000 lux
FT02S = 31000 lux
lumen ratings.
How did you measure the lux with your meter. Did you point the light at the meter or ceiling bounce the light with your meter facing up against the ceiling?
The_Flashaholic
Tom E wrote:
It’s Anduril 2 so probably ships in “Simple UI” with a max of 6 amps. See the detail specs: ff-light.com – E12R page
My E12R and T9R both came with a default of Advanced UI.
gchart
gchart's picture
And mine came with Simple UI as default. Curious to hear that yours came otherwise… Anduril2’s stock config is for Simple UI to be the default and Loneocean’s config files don’t seem to override that setting.
The_Flashaholic
The Noctigon K9.3 came with Advanced as default too.
SKV89
EDC18 = 10000 lux
FT02S = 31000 lux
lumen ratings.
If you point your light direct at the meter, what you are measuring is the intensity and not lumens. Even my tiny TX25cvn with the 700lm W1.1 will measure higher than all the lights you listed. Even ceiling bounce measurements heavily favor throw lights. The E12R is a very floody light. I have both the E12R and MF01 Mini, the E12R definitely makes more lumens than the MF01 Mini.
Another possibility is you probably haven’t entered Turbo on the E12R. In order to get to Turbo, you have to double click after reaching top of ramp.
Sunnysunsun
Sunnysunsun's picture
Last seen: 6 hours 8 min ago
EDC18 = 10000 lux
FT02S = 31000 lux
lumen ratings.
Sounds like he’s not entering turbo. The light should be able to brute force the intensity over the edc18 on fet
azdesertdog
I held the lights 5 feet directly above the meter, no bounce.
Pavlo
Your test is measuring center lux, not lumens. A 200 lumen throwy beam will register more lux than a 12000 lumen floody beam.
Sunnysunsun
Referring to the E12R vs EDC18, the E12R should be throwier based on shear output and similar beam patterns. It’s likely he’s not entering turbo or maybe using a really bad cell.
azdesertdog
That was it, wow what a difference.
Thank you !! Big Smile
azdesertdog
Thanks to the group I found the problem, it shipped in simple UI
Feel better much better now. Thumbs Up
azdesertdog
Thanks again, as stated in another post. I was going into turbo but the light shipped in simple UI..
all is fine now.
