E-Stream ES18650-26EP 2600mAh (Black)
Official specifications:
Nominal capacity: 2600mAh
Minimum capacity: 2500mAh
Nominal voltage: 3.65V
Discharge cut-off voltage: 2.75V
Maximum charge voltage: 4.2V
Standard charge current: 1.25A
Standard charge cut-off current: 125mA
Maximum continuous charge current: 5A
Maximum continuous charge cut-off current: 250mA
Standard discharge current: 2.5A
Maximum continuous discharge current: 15A
Maximum pulse discharge current: 30A
Weight: 47g +/-2
Cycle life: 1000 cycles to 80, 2000 cycles to 70 at standard charge/discharge
Cycle life: 500 cycles to 80% at 1C charge/3C discharge, 200 cycles to 80% at 1C charge/6C discharge,
A fairly low capacity battery that can deliver current (Note: Marking on battery is considerable lower than datasheet).
The two batteries tracks nicely and there is only a small drop in capacity at higher current.
Conclusion
This is not the battery to get for top capacity, but it handles higher current nicely.
It is interesting to see the cycle specifications for difference currents, high current draw is hard on the battery and the lifetime is very long at low current and slow charging.
I will rate it is a good battery.
Notes and links
The batteries was supplied by E-Stream for review.
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
