WTB Thorfire TG06S
Doesn't have to be pristine or have the box, but must be fully operational & include clip. The O-rings that came with it would be appreciated.
CONUS, remittance via PayPal.
EDIT - Please PM with availability.
slmjim
Either everyone is hanging onto theirs or there aren’t many around. My well patinaed TG06S is my go to for work situations. I usually like side switch lights but for work I prefer starting on high rear clickies. Just click on/off, no thinking. Surprising throw for such a small light.
In case you don’t find the TG06S, check this one: https://www.aliexpress.com/item/32832591911.html
Sorry to be messing here, but as that is probably a light difficult to obtain, I thought this could help :+1:
I might have one. I know I had two or three of them at one time. Just had abdominal surgery, so I can’t bend over to sort through the pile of boxes. I will try over the next couple days to find it if I still have one.
That looks like a dead ringer. I wonder if it is any good?
I have one, but it is currently not fully assembled. I’d offer to go find it, put it back together, and dig up the spare O-rings as well (I know where they are better than the light), but the last time I offered to scrounge up a light for someone it took… almost three months. So I guess I’ll PM you if I both find it and get it working.
You could also go for the original, the Jaxman E3
Well, as a host, I believe it will be pretty similar to the TG06S.
As for the driver, I bought the Alonefire X360 (similar to the Sofirn SF10) which has a similar UI , so I believe it will have H>M>L>ML + Strobe, with PWM. Not the best UI.
Mine came with a neutral white XP-G2, not bad at all in terms of tint.
But, as far as I could see the original TG06S is quite similar: ThorFire TG06S LED Flashlight
So, I am not 100% sure this X380 model is exactly as good as the TG06S, but it will be a close shot :+1:
Thanks for the link MB. Now I know where to go if mine dies. I like H,M,L,ML with no memory for quick “pull it out of my pocket without thinking and shining it in a corner or somewhere kind of light”. I tried SP10 for this but the UI does not work for me. I do like side switch lights for casual walks though. Two different uses. I hope strobe is hidden like the TG06S.
