Test/review of Samsung INR21700-48X 4800mAh (Gray)
6 posts / 0 new
HKJ
HKJ's picture
Last seen: 14 hours 57 min ago
Samsung INR21700-48× 4800mAh (Gray)
DSC_3853
Official specifications:
  • Typical capacity: 4800mAh
  • Minimum capacity: 4650mAh
  • Maximum charging voltage: 4.2V (4.15V for cycle life)
  • Nominal voltage: 3.64V
  • Charge method: CC-CV
  • Charging current rate: 0.33C (1584mA)
  • Discharge cut-off voltage: 2.5V (3.0V for cycle life)
  • Cycle life: 3000 to 70%
Samsung%20INR21700-48X%204800mAh%20(Gray)-info
Another version of the Samsung 4800mAh LiIon cell with possible high cycle life.
DSC_3852
DSC_3854 DSC_3855
DSC_3856
DSC_3857
Samsung%20INR21700-48X%204800mAh%20(Gray)-Capacity
The two cells match very well and can handle about 10A
Samsung%20INR21700-48X%204800mAh%20(Gray)-Temp-10.0
Samsung%20INR21700-48X%204800mAh%20(Gray)-Temp-15.0
Samsung%20INR21700-48X%204800mAh%20(Gray)-Temp-20.0
Samsung%20INR21700-48X%204800mAh%20(Gray)-CapacityTimeHours
Samsung%20INR21700-48X%204800mAh%20(Gray)-Energy
Samsung%20INR21700-48X%204800mAh%20(Gray)-PowerLoadTime
Samsung%20INR21700-48X%204800mAh%20(Gray)-TripCurrent
Samsung%20INR21700-48X%204800mAh%20(Gray)-Charge
DischargeSamsung%20INR21700-48X%204800mAh%20%28Gray%29-pulse-1.0%2010%2010-IR
Conclusion
This is high cycle life batteries, but they must be treated carefully to get the long cycle life.
They are not high current batteries, but can handle a peak in current.
Notes and links
The battery was supplied by Vapcell for review.
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
JaredM
JaredM's picture
Last seen: 1 hour 43 min ago
I wonder if I can find these anywhere in the US for sale at a good price. I currently have 33Js on long term cycle life testing. I actually need to check the data but haven’t been in that lab for a while, last I knew of they were over 600 cycles and looking really strong with capacity retention at 93 percent. These numbers are rough from memory but I’ll pull the data and share it. If these 48X perform similarly in cycle stability, they are a true winner in my book.
What’s interesting and I’ve found in other places over the years in battery research is the SOC range that yields best stability is often the same “valley” in the IR vs Eocv curve. This sort of makes intuitive sense, but it’s going to be interesting to test the hypothesis with the latest liions. That addition to your data collection is really valuable to me. So thank you!!
Superstocker
Superstocker's picture
Last seen: 8 hours 51 min ago
Thanks HKJ! These look very nice.
jp9mm
Last seen: 3 months 4 weeks ago
I’ll be on the lookout for these
vapcell Dennis
vapcell Dennis's picture
Last seen: 2 days 14 hours ago
Beer amazing 48X There are two color versions
shadockan
shadockan's picture
Last seen: 1 month 3 days ago
IMO … if you want the … “best big” … battery , then the Molicel INR 21700 M50A it’s what you need …
