Any ideas for a 1x18650 mechanical clicky host w/ 1cm or larger reflector opening?
8 posts / 0 new
Cythras
Cythras's picture
Last seen: 7 hours 45 min ago
I’ve got an Epistar 3v 110mm emitter array on a 20mm MCPCB I’d like to try out, but the dome is so damn large I can’t find a light to put it in. If possible I’d like an OP reflector, decent thermal path, and 17mm(preferred)/20mm driver support. Other single celled host suggestions are appreciated as well, though I would prefer something relatively pocketable.
EDIT: Having done some math, It looks like any reflector capable of completely surrounding an XHP70 (the entire die, not just the dome) should have a minimum diameter of 9.9mm and will probably work, So now I’ve just got to find something that fits that criteria. The closest I’ve got so far is the Convoy M21C and the some variants of the Manta Ray C8.2, both use drivers larger than what I have on hand and run on larger cells, but perhaps that’s the best I can do.
Edited by: Cythras on 11/19/2020 - 20:05
gchart
gchart's picture
Last seen: 3 hours 40 min ago
That’s a neat trick! How did they manage to fit a 110mm array on a 20mm MCPCB?
I’m guessing that’s maybe a 10 or 11mm emitter array? Have pics? Single 18650 clicky with a decent thermal path and 17mm driver support screams Convoy S2(/+) and perhaps drill out the reflector hole a little bit. The S2(/+) only uses a 16mm MCPCB so maybe a Convoy M1 or M2.
I know it’s “only” a 7070 LED, but here’s an example of something like that: https://budgetlightforum.com/comment/1014525
Cythras
Cythras's picture
It’s a… tight fit?
Sadly I don’t have the tools required to ream out a reflector, but the amount of material removal required to make it fit in an S2+ would be substantial. Most of Simon’s lights (excluding the XHP-70 ones) use the same size of spacer and have openings only 7mm wide. The SMO reflector in the C8+ specifically is 9mm in diameter and the closest I’ve got so far.
gchart
gchart's picture
Also… that thing has gotta be Angry BlueTM. 7000K – 8000K Shocked
Cythras
Cythras's picture
Yup… I’m not expecting it to be particularly nice to use, I just wanna play the output. At 72w, it should put out a reasonable amount of light Silly
Lightbringer
Lightbringer's picture
Last seen: 31 min 15 sec ago
Howbow a C8 host, drill out the reflector from the bottom, see how the beam looks?
Beam’s too ugly? Screw down the star and stick an aspheric with spacer up-top instead. Make it a semi-flooder.
Cythras
Cythras's picture
That’s going to be my last-ditch option right now, but my C8+ is currently being used to host the 9090 2×2 array LED from the same source. Sadly I don’t have the tools to properly ream out a reflector either, not even a hand drill (which wouldn’t be ideal to begin with).
g_damian
g_damian's picture
Last seen: 8 hours 33 min ago
Maybe you could use the same reflector that was used in this build: https://budgetlightforum.com/comment/1674995#comment-1674995
It should fit most of C8 like hosts.
