brightest compact flashlight
13 posts / 0 new
killme.sh
Last seen: 1 week 5 days ago
is there a way to sort flashlights by their output and size?
looking for the absolute brightest and smallest there is at the same time for general airsoft use, does not need a long running time at the brightness, and does not need triggers already built in or a gun mount available,
Robin Dobbie
Last seen: 39 min 59 sec ago
Another way to look is to find the largest flashlight you want to handle, then look at the output of similarly sized lights that are reviewed by people who actually do light measurements.
Strong contenders in this area that people often talk about, here, are the Emisar D4V2 and the Fireflies E07, just to get started. I’m sure others will chime in with their favorite.
Firelight2
Firelight2's picture
Last seen: 6 hours 52 min ago
Those lights are indeed some of the brightest in their size range.
… but they aren’t throwers. They’re flooders and produce a wall of light for close and medium range.
If you want something that will illuminate at range, you aren’t actually looking for the “brightest” light. Instead you want one with the best throw.
Robin Dobbie
“Absolute brightest” and “general airsoft use” would, to me, suggest a more floody light than what would be considered a “thrower.” But I’m not going to lie, I sometimes wish my D4 was throwier. But just a little.
Katherine Alicia
Katherine Alicia's picture
Last seen: 10 hours 32 min ago
I`d pick (in no particular order) D4V2, Lumintop FW21 pro, and EC03.
Chicken Drumstick
Last seen: 39 min 46 sec ago
So what wins, smallest or brightest?
Katherine Alicia
Brightest light for smallest size, though the Lumintop FW21 Pro is probably the overall winner in my list.
Quadrupel
Quadrupel's picture
Last seen: 1 hour 11 min ago
So you want under barrel tactical flashlight with remote switch, right?
Chicken Drumstick
lol, but if something is smaller and not quite so bright is it better or worse Silly
Big Smile
Katherine Alicia
well then it would have to be worked out as a ratio, if it`s half the size and half the brightness then it`s just as good, I just can`t picture anything half the size of an FW21 pro putting out 5000lm. but if it`s twice the size and puts out 20,000lm that`s cool but it`s no longer little.
You`re just trying to confuse me aren`t you! Big Smile
Agro
Agro's picture
Last seen: 2 min 37 sec ago
Emisar D4v1 is just as bright as V2 and is smaller.
I like it especially with 18350 cell, really nice.
When I started the hobby I was really into maximizing output-to-weight (lm/g) and output-to-size(lm/mm³).
The lights mentioned here do fine in this regard.
But later I learned that output is not that important. What is important is the light output that actually hits the target. And to hit targets that are not trivially close you need good throw rather than good output.
Overall I find that higher output is more useful with throwier lights.
A pure flooder doesn’t have to be bright – the light scattering off objects will blind you and after certain output you won’t really see much more.
But a pencil-beam thrower with minuscule output which in theory allows you to see far is not my thing either. I’d rather have a large hot spot than to look through an eye of a needle.
Umpi2000
Last seen: 3 days 3 hours ago
EC01 with XHP50.2? It has a mix of throw and Lumens
dave1010
dave1010's picture
Last seen: 1 hour 13 min ago
This thread should help: https://budgetlightforum.com/node/72789
Or if you’re after throw https://budgetlightforum.com/node/73093
https://davestechreviews.wordpress.com/ / Email: <my BLF username>@gmail.com
