Review: LG 18650 B3 2600mAh (Salmon)
4 posts / 0 new
HKJ
HKJ's picture
Last seen: 2 days 10 hours ago
DSC_0505
Specifications:
  • Capacity: Nominal 2600 mAh, Minimum 2500 mAh
  • Standard charge: 0.5C (1250 mA), 4.2 volt, cutoff 50mA
  • End voltage: 3 volt
  • Max. discharge current: 1.5C (3750 mA)
  • Operating temperature charge: 0 to 45 °C
  • Operating temperature dsicharge: -20 to 60 °C
LG%2018650%20B3%202600mAh%20(Salmon)-info
The cells is without any protection circuit. Note that my termination condition is 100 mA not the official 50 mA, this is probably the reason that my result is below 2500 mAh.
DSC_0519 DSC_0520
DSC_0506
DSC_0507
LG%2018650%20B3%202600mAh%20(Salmon)-Capacity
LG%2018650%20B3%202600mAh%20(Salmon)-CapacityTimeHours
LG%2018650%20B3%202600mAh%20(Salmon)-Energy
LG%2018650%20B3%202600mAh%20(Salmon)-PowerLoadTime
LG%2018650%20B3%202600mAh%20(Salmon)-TripCurrent
Each test does discharge the cell slightly, that is the reason for the seperation between the tracks and because they have no protection the test run all the way up to 15 ampere.
LG%2018650%20B3%202600mAh%20(Salmon)-Charge
Conclusion
This cell shows good test result, and I will rate it as a very good cell.
Notes and links
The batteries was supplied by cpf user "Candle Lamp" for review.
Edited by: sb56637 on 08/26/2014 - 17:46
sb56637
sb56637's picture
Last seen: 2 hours 42 min ago
Thanks very much! Frontpage'd and Sticky'd.
yavi
Last seen: 9 months 2 weeks ago
2600mAH with a termination voltage of 3V sounds good, Do you know where can be purchased?
HKJ
HKJ's picture
Not really, but try google and search for "lg icr18650-b3", then you will get some possibilities.
