Test/review of Vapcell INR26350 2000mAh A20 (Red) 2020
4 posts / 0 new
HKJ
HKJ's picture
Last seen: 5 days 4 hours ago
DSC_3882
Official specifications:
  • Battery size: 26350
  • Battery chemistry: Li-ion
  • Voltage: 3.7V
  • Minimum capacity: 2000mAh
  • Maximum discharge current: 6A
  • Height: 35.00mm
  • Diameter: 26.10mm
Vapcell%20INR26350%202000mAh%20A20%20(Red)%202020-info
A 26350 sized LiIon battery, this is a uncommon size.
DSC_3881
DSC_3883 DSC_3884
DSC_3885
DSC_3886
DSC_3887
Vapcell%20INR26350%202000mAh%20A20%20(Red)%202020-Capacity
The two cells match nicely and can deliver the rated 6A, but not much more.
Vapcell%20INR26350%202000mAh%20A20%20(Red)%202020-Temp-7.0
Vapcell%20INR26350%202000mAh%20A20%20(Red)%202020-Temp-10.0
Vapcell%20INR26350%202000mAh%20A20%20(Red)%202020-CapacityTimeHours
Vapcell%20INR26350%202000mAh%20A20%20(Red)%202020-Energy
Vapcell%20INR26350%202000mAh%20A20%20(Red)%202020-PowerLoadTime
Vapcell%20INR26350%202000mAh%20A20%20(Red)%202020-TripCurrent
Vapcell%20INR26350%202000mAh%20A20%20(Red)%202020-Charge
Discharge-Vapcell%20INR26350%202000mAh%20A20%20%28Red%29%202020-pulse-0.5%2010%2010-IR%20backup
Conclusion
The batteries works fine, they are neither high current nor high capacity, but the size is not very common.
Notes and links
The batteries was supplied by Vapcell for review.
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
djozz
djozz's picture
Last seen: 23 min 13 sec ago
Thanks HKJ, these look a littlebit better than the unbranded lila ones that you tested a few years ago.
Notmyrealname
Last seen: 18 min 20 sec ago
Thank you HKJ. This looks like a better choice for the Fitorch P25 then the proprietary battery. I’m not sure how much current the new Astrolux EA01 XHP50.2 will draw but I’d use this for that light too (with 26350 tube), for lack of higher output choices. I ordered a blue unbranded LI26350 battery to try in my P25. It appears to be the same battery as the Vapcell and also the same as the purple 26350 previously sold. Of course with the Vapcell branding you are assured of a “A” quality battery and some warranty protection but the Vapcell version is hard for us to get here.
I feel sorry for people who don't have a hobby or interest to escape to.
Henk4U2
Henk4U2's picture
Last seen: 40 min 8 sec ago
Thank you HKJ. Looks like fine batteries if you want to put a 6V driver-emitter in a 1 × 26650 light.
You are a flashaholic if you are forced to come out of the closet, to make room for more flashlights.
