SC31 Pro Diffuser Options
9 posts / 0 new
WolfPackMoon
Last seen: 1 year 1 month ago
Hey all! I’m new to the forums and brand new to flashlights of this caliber. I picked up a SC31 Pro and a SP40. I’m looking at getting a diffuser for the SC31, but would like to know what my options may be. I couldn’t seem to find a US based seller for the genuine Sofirn diffusers and would like to have something in hand fairly soon, and I’m worried that purchasing direct would take a while. Are there any other diffusers that may fit it?
Fescron
Last seen: 14 hours 14 min ago
I’ve bought a lot of flashlights from their Aliexpress store and the more expensive models consistently arrived to my house in Belgium in about 2 weeks Big Smile The C01S’s for example took some more time but if you really want to maybe you can buy the diffusers + another flashlight Wink Or maybe choose another shipping option or even message the store directly, I’m sure they can figure something out!
funwok
Last seen: 6 hours 26 min ago
A diffuser is usually and practically a semi-transparent piece of plastic. Which means if you are okay with DIY, you could almost always something from your household or grocery store which will fit the bill.
I have good luck with chewing gum or vitamin pill bottles and if you are into film photography the old 35mm film canisters work perfectly as a base for a DIY diffuser fitting the SC31. Usually a bit of cutting and sanding down the edges involved, but that’s a pretty easy and fast way to make your flashlight into a little lantern. Wink
amtaham
amtaham's picture
Last seen: 16 min 4 sec ago
You may to DIY or if the diameter of the SC31 Pro’s head is around 25 mm, this Nitecore NDF25 may fit. It is also fit on Lumintop FW3A.
“Come again, please, come again, Whoever you are. Religious, infidel, heretic or pagan. Even if you promised a hundred times, And, a hundred times you broke your promise, This door is not the door of hopelessness and frustration. This door is open for everybody. Come, come as you are.” ~ Mawlana Jalaludin Rumi
niajef
Last seen: 1 day 8 hours ago
you can probably just put some scotch tape over it
Lightbringer
Lightbringer's picture
Last seen: 7 hours 8 min ago
I just use ceiling-bounce to not have an annoying point-source at eye level.
An impromptu diffuser can be made by rolling some waxed-paper into a “dunce hat” and taping it onto the end of the light.
WolfPackMoon
!{width:50%}https://i.imgur.com/9tkjU8V.jpg!
That’s a great idea! I will see if I can find some somewhere locally.
WolfPackMoon
I did see somewhere that someone said the S2+ diffuser may work. Has anyone else tried it?
MascaratumB
MascaratumB's picture
Last seen: 5 hours 48 min ago
I always like to recommend this thread: https://budgetlightforum.com/node/70345
These are my “options”:
