EasyB's 8th annual OL competition entry, modified light category
16 posts / 0 new
EasyB
Last seen: 2 hours 20 min ago
Introduction:
I made this light for trail running at night. I had been using a D4 with 2x WF1 and 2x WF2, along with a wowtac A2 with 5000K SST20 on my head. The headlight has a relatively throwy beam which I have pointed ~20ft up the trail. Then my handheld lights the path closer to my feet. The D4 with those throwy emitters provided a nice beam for up close as well as having a powerful turbo mode with ~40kcd for spotting wildlife or just having fun. But I realized I wanted more throw which became the motivation for this light. I had the idea of modifying a throwy light with an additional small reflector to make it dual beam; use the small reflector most of the time for lighting the path, but have the throwing power of the big reflector when I wanted it. But the light had to be light weight; the D4 was very nice in this respect since it weighs only ~110g with cell. I decided I wanted a C8 sized reflector (~1050mm^2) to get the throw I wanted, but after much searching could not find a light that was under ~140g without cell. So I decided to make my own.
The body:
I now have a drill press and I got some end mills, so I can do some metal machining, but no lathe so I decided to go the frankenstein route and cannibalize the difficult-to-make parts like the head and battery tube from lights I already had. Remember, one of the main motivations for this light is to be as light weight as possible, so that has guided the design. The head came from a Supfire L6 which is a 26650 sized C8 light with a pill. I cut off just the top part of the head which houses the ~32mm tall reflector. I used the end mill to even out the cut so the head sits flat and even on the shelf. I also milled out quite a bit of metal from the inside of the head to lighten it up, as you’ll see later. The wall thickness at the bottom is ~5mm, and I milled it down so it’s more like 2mm average. I made the shelf from 1/8” thick Al bar.
The other donor light is a cheap skywolfeye zoomie. I used the battery tube and tailcap. The zoomie bezel piece I used to house the driver and switch. It is JB welded to the shelf. This zoomie is “push-pull” so the battery tube has no external threads (it has internal threads for the pill). To get these parts to work in my design, I cut down the zoomie head (the part with the threads that mate with the zoomie bezel), and JB welded it to the battery tube. I wrapped the top of the battery tube with some copper tape to get a tight fit in the zoomie head. The switch cover is made from layers of bicycle inner tube. It has a good feel and is easy to press. In the last picture below I trimmed the top of the battery tube just to get the length right for an unprotected cell. The battery tube presses directly on the driver ground ring.
I trimmed the tailcap to reduce the length and weight. I capped the end with two pieces of 1/16” thick 1/2” wide Al bar adhered with JB weld. The contact plate is some 1.2mm thick copper shim that I bought in a set. I got lucky that the size just fit in the ID and makes contact with the battery tube.
I machined a little shelf that I adhered to the inside of the head using arctic alumina. I cut one TIR reflector from a carclo 10507 quad TIR (same as used in the D4). I machined a slot in the C8 reflector to fit around the little shelf. I positioned the little shelf as high as possible as to interfere as little as possible with the light to/from the C8 reflector. In the last picture below you can see the little TIR is close to but not touching the glass lens.
The driver:
I recently purchased one of the new constant current + DD drivers for my D4 from intl. outdoors, and I realized it would be perfect for this dual beam light. It has constant current modes for the SST20 in the small TIR and a separate direct drive FET channel for the SBT90.2. I would just need to modify the driver by separating the two channels to feed two separate LEDs. The driver has two identical looking FETs. To identify which FET is which I powered an LED in constant current mode and measured the temperature of each FET with an IR thermometer. The constant current FET is the hotter one. I desoldered the DD FET and isolated the FET drain (LED negative) pad on the driver using kapton tape. Then I soldered some copper tape to the FET drain, and installed the FET back on the driver, soldering only the source and gate connections. I adhered the FET using arctic alumina. I wasn’t sure how much heat the DD FET would produce and how much I had decreased the thermal path, so I covered the whole area with silicone. This would help dissipate some heat, but would also contain any wires from flopping around if anything got really hot and desoldered.
A size comparison with some other lights. I succeeded in making the light very light weight at 91g without cell. For comparison, the weights of the other lights, without cell, are:
C8: ~147g
D1S: 149g
My dual beam light: 91g
D1: 87g
D4: 61g
I added some rubber grips. Mountain bike inner tube for the head, and road bike inner tube for the battery tube. It’s nice to have a couple old inner tubes lying around; I always find uses for them.
It has worked great as a running light, but there is some room for improvement. The thermal path for the SST20 is not great. At 2.7A the output drops quickly. At 1.5A the output is stable. Luckily this broad beam doesn’t have to be very bright since it’s pointed closer to my feet. Double clicking goes to direct drive on the SBT90.2 at what should be around 130kcd (have not measured it yet).
Thanks for looking!
pinkpanda3310
pinkpanda3310's picture
Last seen: 1 day 20 hours ago
Welcome to the challenge EasyB. Very nice project, i’m liking these multi-beam style lights. Well done in making it light weight too Beer
Agro
Agro's picture
Last seen: 3 weeks 5 days ago
Wow EasyB, that’s quite a mod!
Any beamshots? I wonder how does the small TIR affect the reflector beam.
How does the firmware work? What used to be turbo now turns the large reflector on, right?
BTW, I’m curious that you use the reverse lighting strategy to mine.
I tend to wear a flooder headlamp and have a thrower in the hand.
Never tried the other way around as I thought I would have less control over the throw part of the beam and I felt controlling this one was more important.
But now I think I’ll try the reverse eventually.
YuvalS
YuvalS's picture
Last seen: 9 hours 13 min ago
Very inspiring and creative modification.
I am a big fan of dual beam lights,
Well done
My FW repository
My BLF/OL contest entries: 7th 8th 9th
EasyB
Thanks for the welcome and comments guys.
Thanks Agro. I will take some simple beamshots. There is a shadow in the spill of the big reflector beam, but no real affect on the hotspot area.
The FW is Anduril, unchanged from the intl. outdoor store. Yes, the turbo mode uses just the DD FET which I’ve routed to the SBT90.2. For the constant current modes the DD FET is off, and I’m using 2.7A as my ceiling and 6 stepped modes. I chose the number of steps just to get the current spacing right on the highest couple modes i.e. I usually want a ~1hr and a ~2hr mode for these types of activities. Though I will probably lower the ceiling since 2.7A is too much for the SST20 heat path.
Thanks for asking about the thrower vs flooder on head/hand strategy. I have also not given the reverse strategy an honest try, but here are some of my observations: like I said I have the headlight beam pointed about 20-30 ft ahead with my head in a natural position. Then without tilting my head I can move my eyes back and forth between close and far as needed. Then panning my head left or right and having the spot beam follow seems to work naturally. Additionally, having the handheld light illuminating close up helps to highlight the shape of things on the trail by creating shadows. Whereas things look a bit “flatter” when illuminated by the headlamp since there are no shadows.
MascaratumB
MascaratumB's picture
Last seen: 4 hours 52 min ago
Cool, welcome to the contest Cool Crown
MRsDNF
MRsDNF's picture
Last seen: 1 month 1 week ago
Wow. What can one say but crazy mod. Lots of wires on that driver. Well done. Beer
Rdubya18
Rdubya18's picture
Last seen: 1 day 1 hour ago
That’s a really cool idea . Nice build Thumbs Up
MtnDon
MtnDon's picture
Last seen: 1 hour 11 min ago
Good work; great to see you participate.
Scallywag
Scallywag's picture
Last seen: 5 days 8 hours ago
Quite the mod. A lot of sacrifices for this one! How is the SST20’s shelf attached to the body? JB Weld?
pinkpanda3310
Agro wrote:
Any beamshots?
gchart
gchart's picture
Last seen: 3 hours 19 min ago
Daaaaaang! Well done EasyB and welcome to the competition!
Skylight
Skylight's picture
Last seen: 4 hours 21 min ago
Really nice flashlight, EasyB. Crown Thumbs Up
Cool that you tried to keep it as light as possible. I would be intersted to hear how it handles the heat of the SBT90. The dual beam design is a great idea.
CNCman
CNCman's picture
Last seen: 1 hour 50 min ago
Very nicely done EasyB Thumbs Up
You said “ The constant current FET is the hotter one. I desoldered the DD FET and isolated the FET drain (LED negative) pad on the driver using kapton tape. Then I soldered some copper tape to the FET drain, and installed the FET back on the driver, soldering only the source and gate connections. I adhered the FET using arctic alumina. “
You guys who do these things bring a high level of modding to BLF . Cool
Thank You for joining the contest and sharing your skills Big Smile
EasyB
Thanks for the kind comments everyone.
Scallywag, I did sacrifice some lights for this mod, but I don’t think I was going to use those hosts for anything so I’m happy to use them for this light which I will use. The little shelf is attached with arctic alumina.
Skylight, the light will certainly get too hot after awhile on turbo, as you’d expect, but it is fine for how I use it. It’s not nearly as bad as my D4 which draws similar current (~17A).
I finally got out for a run and got some beamshots. I decided to do a little video. First it’s just the SST20 beam, then I switch to the turbo beam a couple times. The tree line is about 200m away. I locked the exposure settings during the video.
https://i.imgur.com/KynPzbM.mp4
Some shots in a cool “tree tunnel”. Left is wide SST20 beam, right is turbo beam. Same exposure settings.
I wanted to get some nicer video and shots, but hopefully these get the point across. Flat Stare
MtnDon
MtnDon's picture
Big Smile Thumbs Up
