Keeppower 14500 950mAh P1495U (Blue-white) 2020
Official specifications:
Voltage: 3.60V
Rated capacity: 950mAh
Minimum Capacity: 900mAh
Discharge cut-off voltage: 2.50V
Charge voltage: USB 5V +/- 0.5V
Standard charge current: 330mA
Maximum constant discharge current: 2A
Protected 14500 with USB charging and not over sized.
The box contains two batteries, USB charge cable, instruction/date sheet and a plastic box for the batteries.
The supplied USB cable can charge two batteries at a time, but any micro USB cable can be used to charge a battery.
The two cells tracks fairly well and the over current protection prevents too high current.
The batteries can be charged on a regular LiIon charger.
But also with a USB charger.
Conclusion
These batteries are definitely not for high current, but works nicely at lower currents. The USB charging makes it easy to charge them mostly anywhere.
Notes and links
The batteries was supplied by Keeppower for review.
Graphical comparison to other LiIon batteries
Table with all tested LiIon batteries
