EMISAR D4SV2
59 posts / 0 new
Jimo
Last seen: 1 day 6 hours ago
 So you are using flat top batteries.  Thank you
Jimo
Kiki
Last seen: 11 hours 58 min ago
Yes, this and Vapcell 26650 5900mAh 20A cont, which is flat top too.
Jimo
  • Thank you for help.
Jimo
Artiet59
Last seen: 1 hour 12 min ago
polarweis wrote:
richbuff wrote:
polarweis wrote:
richbuff wrote:
I am very happy that I got mine, not green. White. W2. Turn on 4,020 lumens and 429 meters throw from this size flashlight is a thrill. I guess I should latch onto two more, while supplies last.
Did you have any other d4s before with different led? Sst20 got hot really quick and I was wondering about w2
No; and it gets hot real quick.  I use it on turbo just for a few seconds to illuminate an area and quickly identify points of interest, and then I throttle back to normal modes.
I think d4s is pefect light but a single big dye led with reflector has much range and better thermal performance(c8 type).
The new Astrolux ea01 is a little bit longer, but essentially the single led version of the Emisar d4s. No aux leds though, but does have lighted switch. I have both and they are awesome!
Check out some of my new lights (picture heavy) and quick first impressions of them here: https://budgetlightforum.com/node/77180
Artiet59
Although it might be more fair to say the Astrolux ea01 is like the single led version of the mf01 mini. I’m not trying to compare Emisar and Astrolux. But the ea01 is a really nice light
Artiet59
D4sv2 (sst20 / 5000k) and the EA01 (sst40 / 98,000cd / 2300lm)
Length is about 5/8” (15mm) longer
adam7027
Last seen: 10 hours 52 min ago
EA01 optics looks like super cool. If only this could be purchased with high CRI 4000-5000K-ish emitter…
Helios azimuth
Jimo wrote:
I need to know flattop or button top
I use flat top unprotected also, Shockli and KeepPower 5500mAh.
Artiet59
I have a convoy s11 with xhp50 5000k on order. I don’t think that is high cri, but I am hopefully going to reflow that led onto the ea01 board.
I would love a high cri option though
Artiet59
80s Fan
80s Fan's picture
Last seen: 2 weeks 1 day ago
I see the XP-L HI 4000k is not available. Can anyone tell me how the XP-G2 compares?
DrDevil
DrDevil's picture
Last seen: 1 hour 20 min ago
I like it. Nice neutral Tint, not High CRI, but nice. No green.
Here side by side with a Nichia 219C 5000K on the right
More interesting for you: Do you know Bluzies Beamshots comparison over at TLF?
https://www.taschenlampen-forum.de/threads/lampenliste-gesamt%C3%BCbersicht-von-a-bis-z.69320/
There you can compare a lot of different LEDs and Tints, also the D4SV2 XP-G2 S4 5D and the XP-L HI 5D is listed.
80s Fan
80s Fan's picture
Thanks DrDevil, good info.
WindyCity
WindyCity's picture
Last seen: 4 days 16 hours ago
I Got the Emisar and are on the bench for the EA01, is it better or does the Emisar beat it on every level and better to find a different type of light (got plenty on my Wishlist)
Artiet59
The only thing about the EA01 i hands down prefer over the d4sv2 is it does not heat up as quickly. The other aspects that could make ea01 better are situational (ea01 has more throw, that might not matter to someone), ea01 is less expensive (may not matter), ea01 has a lighted switch.
The d4sv2 has a more quality feel-my opinion, is smaller, may be brighter, has aux led’s on mcpcb, has high cri emitter options, etc. they are pretty different to equivalently compare.
Photon Master
I’m using 26350’s in my three D4SV2’s. I wonder how much more power I’d get going to a Shockli / KeepPower 5500mAh?
My two new ones are deep red and SST20 4000K. Love ‘em both!
WindyCity
WindyCity's picture
I am using the black version Liitokala’s also very pleased with them (bought it from the official store)
Photon Master
Sweet! Do you have a link to buy them?
WindyCity
WindyCity's picture
https://nl.aliexpress.com/item/32810391444.html?spm=a2g0z.12010612.81483...
Photon Master
That’s awesome thanks dude
Do you ever run 26350’s?
brightnorm
Last seen: 3 days 17 hours ago
Very happy with mine with WF2’s. Not only is it a ferocious thrower, the beam, though narrow, is not a pencil beam and is still wide enough to use as a general light if necessary. I also have one with 20’s as my “regular” D4sV2
brightnorm
Photon Master
Which light and build is this? Sounds awesome!
brightnorm
D4SV2 modified by Vinh.
brightnorm
Photon Master
brightnorm
Yes. The regular one, not the supercharged one.
brightnorm
Photon Master
Wow looks awesome. Is there a disadvantage to the supercharged version? What bezel would you suggest?
Artiet59
Is there a difference between the standard d4sv2 with W2 from Vinh and the one Hank sells? I know Vinh’s supercharged one is tweaked, but the SL standard d4sv2 with w2? Thanks
brightnorm
Lack of lens. I have no bezel preference
brightnorm
